Old 11-27-2007, 11:25 PM   #1 (permalink)
Certified White Boy
92stealth15g's Avatar
Drives: 1992 Stealth RT/TT
92stealth15g is an unknown quantity at this point
Default fuel injectors and pump
hey, the previous owner of my car said that my car has 550cc injectors and a supra fuel pump.. i am not sure if this is true or not.. i was wondering if there was an easy way of telling if they are upgraded or not?? my avc-r says that my Inj is around 90% at low rpms and drops to 73%ish at WOT. i assume that is how much of the injector is free but im not sure. any advice would be grateful.
"Clutch-Eater"
-1992 Dodge Stealth R/T Twin turbo AWD, Dynamic Racing stage II heads, 99 lifters, 6-speed Getrag from 99 vr4, SPEC Stage 4 clutch, TEC 15g's, Greddy blow off valve, Dejon Powerhouse Blow-Thru Intake Pipes, DSM sidemounts, Denso fuel pump, 550cc fuel injectors, Apexi SAFC, HKS VPC, Apexi AVCR, msd ignition dis-4, MSD 8.5mm wires, NGK coppers 1 stage colder, alamo y-pipe, custom exhaust from turbos back, highflow cat, Lowered, Nitto tires.
"Knockin' Beater"
-1996 Mitsubishi Eclipse GS
Originally Posted by TitanGenesis View Post
"That thing got a hemi?"
"No, it's got a V6 TT with AWD sup?"
92stealth15g is offline   Reply With Quote
Old 11-27-2007, 11:38 PM   #2 (permalink)
LeRoyDL's Avatar
Drives: 1992 R/T TT Conv.
Trader Rating: (51)
LeRoyDL is an unknown quantity at this point
Default Re: fuel injectors and pump
well, injectors you can tell on the front bank pretty easy... look at the color or if they are marked / branded.. fuel pump.. well you really need to pull it out to tell. I would guess the supra is louder then stock, so you maybe able to get an indication by ear, I have a walbro and you can hear that bitch outside the car... to tell for sure you need to look though
1992 Stealth R/T
Drive Train/Performance:
Aem FPR (Rob's adapter), DR650r's, Borla Cat-Back, Dejon Intake / Blow Through Setup, GM Maf / Maf-T, Greddy E-Manage (Blue), Greddy E-01 Boost controller, Greddy Type RS BOV,
Maximal Performance Solid Motor Mounts, MSD Ignition Wires, Optima Yellow Top Battery, Spec Stage 3 6 puck Clutch, Walbro Fuel Pump, Wiseco Pistons.
Exterior/Appearance:
1999 3000GT Front Bumper, Headlamps and Turn Signals, Second Generation Stealth Hood, Side Skirts/Door Caps, Rear Bumper and OEM 96 Wing.
Interior:
Cianci Triple 60mm Gauge Pod (matching passenger side replacement), Charcoal roof/pillar conversion, Greddy Counter Weight Shift Knob,
Greddy Silver 60mm P/H/W Gauges (center replacement and gauge pod), LC-1 Wide Band, M515 PDA/MMCD Data Logger,
Seattle Roller Bearing Short Throw Shifter.
Other
List getting to big, really to much shit to list.
Suspension/Wheels:
Black Racing Pro N1 17x9 Wheels, Cusco Front and Rear Strut Bars, Cusco Front Strut mounts, Ground Control Coil Overs (Stock ECS Struts), Stealth TT Brake Upgrade.
Soon To Come:
A drivable car!!!!
To Do:
Finish building/Install motor, Install Water/Meth Injection, Tune Properly, Paint and Install AWD Conversion parts (after motor break in/tuned).
LeRoyDL is offline   Reply With Quote
Old 11-28-2007, 02:43 AM   #3 (permalink)
Certified White Boy
hmm.. my injectors are black with a hint of what looks like rust.. it had a number on it.. i think it was 195500-1370 i think.. those are denso 550s i think, so that would be correct.. the fuel pump isnt too noisy as far as i can tell.
Old 11-28-2007, 03:02 AM   #4 (permalink)
''the professor''
i3igpete's Avatar
Drives: GoPigGo v2.0
Trader Rating: (100)
i3igpete Level 1i3igpete Level 1
avc-r isn't a fuel controller, it's a boost controller. so that % isn't injector duty cycle; you'd need a logger or something like an EMU/E-01 combo to display that.
what it's reading is just what the boost solenoid is doing, since the avc-r has rpm-based duty cycle maps... 90% at low rpm to hold the wastegates shut to spool up the turbos faster, but tapers down to 73% at higher rpms to prevent overboost.
Maddog Performance Engineering
Put some south in your mouth
i3igpete is offline   Reply With Quote
Old 11-28-2007, 04:12 AM   #5 (permalink)
Certified White Boy
i knew it wasnt a fuel controller.. but that makes sense now.. i also have the SAFC.. but that still doesnt tell me what i need to know.
Old 11-28-2007, 04:15 AM   #6 (permalink)
''the professor''
i3igpete's Avatar
just look at the fuel settings on the afc. if you're at roughly -35% across the board, you've got 550's in there. he'd be stupid to swap the stock injectors back in there and leave the leaned-out setting.
as for the fuel pump, the only real way to tell is to pull it out of the tank and see; the denso pumps are pretty quiet. the other "easy" way you could find out is dump race gas into your tank and pull the wastegate hoses. if you've got the stock pump in there, you'll swing lean and sputter/knock above ~17psi or so. not very safe, of course.
Old 11-28-2007, 03:13 PM   #7 (permalink)
Certified White Boy
alright, i ran the number on the fuel injectors and it says they are denso 550s but the safc isnt -35% but it is running really rich. is it possible that the injectors are upgraded and the pump isnt?
Old 11-28-2007, 06:13 PM   #8 (permalink)
rock on, yeah rock on
spfan's Avatar
Drives: 4 x 22,000 lbs jets
Trader Rating: (6)
spfan is an unknown quantity at this point
the supra pump doesn't make as much noise as the "whine"-bro. that's why some select it instead of the walbro. why else pay twice as much for essentially the same power potential?
perhaps if you posted your safc settings, we'd be able to help you more easily. and yes, if you haven't checked it, it's always possible that something is or isn't upgraded.
Dyno Collection Thread
1993 Dodge Stealth ES, White, April 2002 - April 2005, SOLD 1 of 53
1993 Dodge Stealth TT, Black, Since April 2004, 1 of 5 ever made more rarity info
2003 Subaru Forester 2.5X, Blue, Sept. 2005, Daily Driver with 165 HP of Fury! At least it's AWD.
305 awhp, 325 awtq(BPU minus full catback exhaust)Mods at that time
13.02@104.67 (9bs, dp, fipk, 15.5 psi, bov, no cats, streetmax clutch, 1.77 60', decent conditions, full weight (even spare tire/jack)
13.09@105.08 (1.80 60', same conditions as above)
Beyond BPU: (meaning upgraded turbos/fuel/etc) before engine rebuild Mods at that time
12.38@113.00(20 psi, 110 octane, massive knock above 6k rpms)
12.41@115.10(ditto)
After Rebuild (by IPS): Current Mods Dyno Tune by IPS
12.8@108 (12.5 psi dropping to ~11 @redline, 2.0 60', pump gas, my tune)
spfan is offline   Reply With Quote
Old 11-28-2007, 09:47 PM   #9 (permalink)
Certified White Boy
its like -14ish across the board. it still runs rich tho.
Old 11-29-2007, 05:16 PM   #10 (permalink)
spfan's Avatar
Trader Rating: (6)
well yeah, if you have 550cc injectors and the correction is -14%, then yeah it's gonna run rich
