Old 05-12-2008, 04:14 AM   #1 (permalink)
Official Member
BjornRune's Avatar
Drives: The big whale
Trader Rating: (8)
BjornRune is an unknown quantity at this point
Default Fuel Cut with 9b's
I just returned my engine back to stock/BPU after selling my td05 setup, since this is my DD and I don't ever plan on running race gas I figured I'd go with some 19T's instead. Anyway, I was out cruising with a friend and we thought we'd do a pull in 2nd just to see if the IC clamps would hold as I have an issue with a short coupler on one of the fmic pipes. Well, turned the sbc-id to wastegate pressure and set the gain to 5 just to start out low. Gunning it at around 2200 rpms and even before we hit 3000 rpms the boost came on hard and went through the roof at 18.2 psi Aside from nothing blowing off and being impressed by the rediculous spool time on those 9b's ( ) , I was wondering at what hz # you'll get fuel cut around those rpms? Or is it a fixed number regardless of rpm?
My friend (who was driving) got a little scared, fuel cut is pretty damn violent lol.
I obviously need to check if any vac lines from the SBC are pinched, or that the wastegates actually open at all lol. That aside, I sooo could get used to such instaspool turbos compared to the larger E16G, as I don't plan to track or race the car any at all. Except for the usual assrape murderings of local poser ricers. And bmw 316 owners, seems to be a lot of them around here.
Cliffs :
SBC is iffy, boost spike to 18.2 psi , fuel cut but everybody lived to tell the tale.
-Bjorn-
1994 VR-4 black powerhouse
1994 VR-4 Green DD
Originally Posted by 05SDI
The good news is I need a new motor
BjornRune is offline   Reply With Quote
Old 05-12-2008, 06:57 AM   #2 (permalink)
Forest Gump
cbehnken's Avatar
Drives: 1992 Stealth TT
Trader Rating: (42)
cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7
Default Re: Fuel Cut with 9b's
the problem is the loggers can only see ~1600hz from the ECU. Fuel cut doesn't occur until somewhere over 2000 AFAIK.
This is why it is hard to determine exactly where fuel cut is going to occur. Reported IDCs where fuel cut occurs have often been well over 100%. If you calculate the IDCs by hand and reach around 100% you are right on the edge.
Power: DSM 13G/DR650 Combo, DSM 450 cc bluetops, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback,
no cats, DN Y-Pipe, Polished Plenum and Valve Cover, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead
Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete
Drivetrain: RPS Street Max, M.W. 300m O/S
Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit
Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing
Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings.
Looking for 2nd gen Stealth or 3000GT rear bumper
my sideskirts and door caps for sale, PM me.
cbehnken is online now   Reply With Quote
Old 05-12-2008, 03:37 PM   #3 (permalink)
Official Member
BjornRune's Avatar
Trader Rating: (8)
Thanks for the reply. That's interesting, I wasn't aware of the loggers not being capable of showing more than 1600hz, do you know if that is the case with all loggers?
I suspect my IDC were way past 100%, as I've hit 101-104% according to the logger a few times in the past without any incidents. Probably riding on the edge there as you mentioned. Time to move up on the fuel scale and get some 550's and the lot methinks. I have a maft-pro with speed density just sitting on the shelf as well, should be great once I finally get it in the car hehe.
About the boost spike, turned out the vac hose to the rear wastegate was cracked badly so I replaced that and was able to maintain stable boost pressure. I should probably just get some hardlines, I see more vac hoses that are cracked a little as well
And to think I just replaced them all about two months ago when I did the vac reduction, those rubber hoses just flat out sucked!
Old 05-14-2008, 10:54 AM   #4 (permalink)
Wrench Pimp
Drives: 93 Base, 91 VR4
Phattlard is an unknown quantity at this point
How does fuel cut work on our cars
Free Image Hosting at www.ImageShack.us
Phattlard is offline   Reply With Quote
Old 05-14-2008, 10:58 AM   #5 (permalink)
Forest Gump
cbehnken's Avatar
Trader Rating: (42)
when airflow hits the ECUs pre-programming maximum the ECU simply pulls fuel to prevent more airflow than the stock fuel system can handle from entering the engine.
This was designed on a stock motor with perfectly healthy injectors and fuel pump, so by the time you hit fuel pump you may have already hurt your engine from running lean.
I have personally hit fuel cut several times when I was on 360s without any noticeable damage, but you are at your own risk to depend on it to save you.
That is why you absolutely must have a logger. Even if your damn car is stock spend the money on a logger and see how your engine is doing.
Old 05-15-2008, 11:36 AM   #6 (permalink)
Yank in Yorkshire
bjmsam's Avatar
Drives: 94 Stealth TwinTurbo
Trader Rating: (11)
bjmsam Level 5bjmsam Level 5bjmsam Level 5bjmsam Level 5bjmsam Level 5bjmsam Level 5
Also see here.
Jim's Stealth in the Bavarian Alps, 2001Jim Matthews - Yorkshire, England, UK
Team3S, 3SI #30, GTOUK #155
http://www.the-matthews.com/stealth.html
Jet Black '94 Dodge Stealth R/T Twin-Turbo AWD AWS 6-spd
Active Suspension Damping, Active Exhaust Delete, 5300K HIDs
Ek2MFG dual-flex downpipe, Zorstec custom SS cat-back dual
A'PEXi Super AVC-R Mk-I, MHI TD04L-13Gs, K&N FIPK, IPS SS Y-pipe
A'PEXi Super AFC 5-knob, 450cc Black Tops, MirageCorp Logger
Mobil 1 & Redline fluids, Hotwired Denso 1020 Pump, IPO/SX AFPR
SCE 332x32/322x28 cryoed StopTechs, Wilwood proportioning valves
Winter: stock alloys 17x8.5-46, Hankook Icebear W300 235/45VR17
Summer: Enkei RPM2 17x9-40, Yokohama AVS ES100 245/45ZR17
Track: Enkei RPM2 17x9-40, Yokohama A-032R Hcomp 275/40R17
My reliable daily driver since Feb 1997!
bjmsam is offline   Reply With Quote
Old 05-15-2008, 07:26 PM   #7 (permalink)
Wrench Pimp
Ok I read that there, but What are people doing when they go with larger turbos? They must be flowing alot more air how are they getting around fuel cut?
Old 05-15-2008, 07:46 PM   #8 (permalink)
venik's Avatar
Drives: vr-4
venik Level 3venik Level 3venik Level 3venik Level 3
they either have a piggy back or an AEM standalone, with a piggyback the car doesn't know you have bigger injectors in, it just thinks you're flowing less air. Naturally the ECU still doesnt see that 2000 hz mark or whatever.
1993 Pearl White VR-4 twin 16g
venik is offline   Reply With Quote
Old 05-16-2008, 08:12 AM   #9 (permalink)
Yank in Yorkshire
bjmsam's Avatar
Trader Rating: (11)
Also see here.
Old 05-16-2008, 01:12 PM   #10 (permalink)
Wrench Pimp
good read. thanx bro
