Old 06-09-2008, 08:55 PM   #1 (permalink)
Fijiblue92vr4's Avatar
Drives: 92 VR4
Fijiblue92vr4 is an unknown quantity at this point
Default fmic question
this link isnt the same product as the group buy we had for a fmic alittle while back is it?..cause i read that alot of people had alot of boost leak issues with that kit
3000gt FMIC kit: Pricematchedparts
92 VR4
98 Danger Ranger DD
Fijiblue92vr4 is offline   Reply With Quote
Old 06-13-2008, 03:48 PM   #2 (permalink)
Drives: 92 VR4
Default Re: fmic question
bumpity bump come on i know alot of people went in on that fmic group buy
Old 06-13-2008, 03:53 PM   #3 (permalink)
what would dave thomas do
Gramdollar's Avatar
Drives: 93 pearl white vr-4
Gramdollar Negative 2
import power couldn't be happier with his and he's running like 24 psi or something like that. i think he modified a few pipes a bit to go with his setup but i think all in all people are pretty happy with this kit.
i don't really see too much potential for boost leaks because the pipes are bead rolled and come with t-bolt clamps. i'm goin with it the second i feel like droppin 600 bucks.
and besides... 600 bucks. who can argue with that
Gramdollar is offline   Reply With Quote
Old 06-13-2008, 06:36 PM   #4 (permalink)
Drives: 3000gt VR4
Trader Rating: (24)
Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7
The kit is fine, just make sure you get a good seal on the couplers (use t-bolts), pay attention to the rear turbo seal, and pressure test. The pipes aren't leaking its just adjusting your couplers to make sure they get a good seal.
1998 VR4: SS Downpipe, Borla Cat-Back, Open Element Air Filter, ACPT CFDS, DN Intake Pipes, Front & Rear Strut Tower Bars, Deftracing 575 Hood, Blitz DSBC, Vacum Redution, Krank Vents, Titan Headers w/ Big TD05 16G Turbos,
Patryn is offline   Reply With Quote
Old 06-14-2008, 06:24 AM   #5 (permalink)
3000GT MR's Avatar
Drives: with MR gears
3000GT MR is an unknown quantity at this point
the rear turbo outlet pipe does leak im pretty sure the common fix for that is RTV. im trying to find a fatter o-ring that will seal better
94 VR4
99 conversion with 6K HIDs and PIAA fogs, DN downpipe, SAFC, 450cc, walbro 255lph hotwired, Greddy profec @17psi, MR gears, RPS 6-puck clutch, fidanza flywheel, hybrid logger, dejon preturbo, MAFT 2.xx W/lt1 3inch blow throw. K&N and custon carbon fiber heat sheild, HKS ssq, blitz turbo timer, 18" TSW kyalamis wraped in proxy 4's, polished Y-pipe, polished strut bar, seattle short throw, vac line reduction, misc REAL carbon fiber trim and misc gauges..ect
ON THE WAY: FMIC, 15G/17G combo, MAFT-PRO, 560cc, Solid engine mounts, full 120K, Custom catback exhaust,Carputer, and brake upgrade.
3000GT MR is offline   Reply With Quote
