Federal Mogul (sealed power) bearings.... good or bad? - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 11-17-2003, 10:30 PM   #1 (permalink)
dragon is an unknown quantity at this point
Feedback Score: 0 reviews
Question Federal Mogul (sealed power) bearings.... good or bad?
Are these good bearings? I can get them for relatively cheap ($64 for rod and main bearing together), but if they are not as good as clevite's, then I'll go with clevite. Any suggestions?
Joe Rixon
91 VR4, built internals, bored .30, balanced and blueprinted, 357 magnums, RC550s, walboro 255lph, Fuel Pump Rewire, S-AFC, MAF Trans, pocketlogger, DIY WB, AVCR, Accel Coils, no precat/main cat, RPS stage 3. EGT, A/F, Boost Gauges, Greddy Turbo Timer, Fittipaldi Rims.
Soon: new BOV, Propane inj., downpipe.
dragon is offline   Reply With Quote Quick reply to this message
Old 11-17-2003, 10:41 PM   #2 (permalink)
Ninja Performance
Import Power's Avatar
Drives: Vicki Insane
Feedback Score: 224 reviews
Default Re: Federal Mogul (sealed power) bearings.... good or bad?
I used them for crank bearings and piston rings...knock on wood everything is great!
My battle with Multiple Myeloma/Non Curable Blood Cancer
91VR4-3.0L-Stock heads and Cams-835AWHP 747AWTQ Daily Driver 10.31@142mph on street tires
SLTT-10.9 @ 142MPH Stock NA engine and NA heads/Cams
T4 AWD 9.21 @ 154.98 (Chris Hill Driver/Builder/Tuner Car Owned by 3SX)
T2 FWD 10.19 @ 140.31 (Chris Hill Driver/Builder/Tuner Car Owned by 3SX)
T4-159.23 MPH Ran on 6G72 3.1L! (Chris Hill Driver/Builder/Tuner Car Owned by 3SX)
T4-995AWHP Uncorrected 6G72 3.0L C16 (Chris Hill Driver/Builder/Tuner Car Owned by 3SX)
T2-820FWHP 3.1L 27psi C16 (Chris Hill Driver/Builder/Tuner Car Owned by 3SX)
Import Power is offline   Reply With Quote Quick reply to this message
Old 11-17-2003, 11:09 PM   #3 (permalink)
turbojj's Avatar
Drives: '94 VR4
turbojj is an unknown quantity at this point
Feedback Score: 1 reviews
I prefer to use (2) sets of Clevite 77 Tri-metal bearings for fully grooved main bearing inserts, along with the Federal Mogul rod bearings. These bearings are a softer material that the Tri-metal bearings. They work very well for rod bearings. If you have the rods resized, magnafluxed and shot peened, and use ARP or other high tensile strength rod bolts, you will have a reconditioned rod superior to the factory new replacement rods. If you go to all this trouble though, you might want to go ahead and have the machinist pin the rod caps and drill the lower rod insert to fit on the pressed in pin. This will prevent a spun bearing from occurring unless there is catastrophic failure of the rod, rod bolt, or bearing insert.
turbojj is offline   Reply With Quote Quick reply to this message
Old 11-17-2003, 11:14 PM   #4 (permalink)
I'll take the case!
LRStealth's Avatar
Drives: A Big Nail.
LRStealth is an unknown quantity at this point
I'm sure it really doesn't make a bit of difference. It's not the bearing that matters, but the layer of oil that the part is riding on. My personal preference is Clevite. You can get rods and mains at Autozone for $65 as well. I couldn't find any Clevite thrust washers in town, so I got Federals from O'Reilley's for $10.
Here's a pic showing both rod bearings side by side. The oil hole on the Clevite is SLIGHTLY larger and is dished out a bit.
Federal Mogul (sealed power) bearings.... good or bad?-clevite-vs-federal.jpg
LRStealth is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
