#1 (permalink) |
Member: Burned valve club
Was starting down the path to build Jeff's intake pressure tester tonight when I stumbled on a very simple way to do the same test.
![]() REQUIREMENTS 1. Aftermarket boost gage (I have a 0-2.5 BAR MAP sensor hooked up to my MMCd data logger) 2. Air compressor with pressure regulator 3. Heavy duty lawn / leaf plastic bag (leave it folded up) DIRECTIONS 1. Remove MAS from intake 2. Cover MAS with plastic bag (8 layers of plastic thick) 3. Reinstert MAS into intake 4. Tighten intake clamp 5. Pressurize intake to 20 PSI using fitting on plenum Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side) Overhauled: Starter, IAC, BISS, CV Boots Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!) A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger Pending Projects: Steering Rack Last edited by cbatters : 05-30-2006 at 08:04 PM. |
#2 (permalink) | |
turbojj
#4 (permalink) |
S.V.P. Club Founder
Cool.
#6 (permalink) | |
Clint |
#8 (permalink) | |
Planning to use the same technique to block off the two turbo connections to the Y pipe to test the BOV. Current pressure tester installed @ MAS does not test proper closed loop BOV operation. Adversity the mother of invention... Clint |
#9 (permalink) |
that sounds a hell of alot easier
The Vette guys want a Viper and the Viper guys want a Supra and the Supra guys want a Z06 and the Z06 guys want a 911 Turbo and all of them really just wish they had bought a 3000GT VR4 and called it done -IPSjeff
2003-5 ??COLOR?? Benz E55 AMG --- (Future Daliy Driver--still searching) 2003 Maroon Mazda 6 --- Daliy Driver #1 (soon to be sold) 1994 Forrest Green 3.5L Stealth RT --- Auto --- Daliy Driver #2 (soon to be sold) 1992 Forrest Green 3.5L Stealth TT DR 900's (AKA TBD) 1994 Jade Green Supra TT SP77 (AKA The Russian Rocket) |
#10 (permalink) |
below me
Hey, if it works it works
"Mad Hatter VR4: no ITB huh? I've done it a couple times
mugen3000: ive done it once with my ex mugen3000: for like 20 seconds mugen3000: then she ran away yelling that she had to poop mugen3000: and never again..." 1991 3000GT VR4 04' blue and white Gixxer 600 < 2003 Chevy 2500 My VR4 1 My VR4 2 My VR4 3 The best message I've ever gotten on myspace: "i know i uninvited you the other night but i had a dream that told me i should reinvite you again....so you can come here again on friday....as long as you refrain from using certain phrases such as "line me up some sweet ass"....k?? " |
