#1 (permalink) |
Hey guys. Anyone know what would cause excess clutch pressure? Heres what happened. Rebuilt a 93' VR-4, and after driving it for two weeks, tranny started making noise. Took it to the guy I know at the dealer whos had a couple VR-4s and he said that there was excess clutch pressure, and it wore out the Thrust washers, and then the block started getting eaten into.
Dealer told me I need a new short block. Once the block is fixed, then I need to figure out what caused this to happen. I would guess the flywheel was not re-ground properly, or mabe a defective pressure plate(I intalled a brand new OEM clutch assembley) so.... this puzzles me as to how I could drive the car 100 miles, and then wear out the washers. The crank was magnafluxed, new rod bearings, new thrust washers, new everything..... So now Im not sure If i should rip apart the block again and have it repared( if thats even possible) or if I should find a new short block...... Whats your guys's take on this..... ever heard of this happening? |
#2 (permalink) | |
3S Motorsports
it has nothing to do with the clutch/flywheel etc... It's just that once the thrust bearings are shot, you will have excess crank thrust (side to side [actually front to back] movement) And yes this will kill your engine. Good luck -Steve edit: you will most like;y not be able to reuse the block or the crank. the pistons and rods will probably be fine.
3S Motorsports Is Open For Business
(631) 676-2448 Running the First Pampena 3.5L Stroker http://www.3smotors.com -Steve ![]() |
