Old 09-27-2009, 04:02 PM   #1 (permalink)
Drunk as a lord
Forest Gump's Avatar
Drives: 1992 Stealth TT
Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2
Feedback Score: 70 reviews
Default Engine Knock at mid-range RPM
All of a sudden I am getting high knock counts around 3-4000 RPM that I haven't really had before.
Things I have changed recently are moving to IK24 plugs from 7 series NGK coppers, but I am not sure if this problem was before or after this.
I'm am between 10 and 20 counts. The car pulls a ton of timing and feels like a dog.
I've been doing some testing and I've found I can reproduce it anytime I want by holding the car with the brakes in 2nd at 3000 RPM and going full throttle.
Obviously you don't want to do this for long or you'll overheat the brakes, but it allows for an easy way to safely hold the car at high load at a specific RPM.
I can reproduce the knock everytime by holding it at 3K RPM. Boost is approx 16-17 PSI and I am running 365CC of 50% meth.
I've played with the AFRs and now have it running much richer at 3000 than the factory map. I'm running about 11.7:1 at 3K and the factory map calls for as high as 12.9:1 at high load in this rev range.
I've found it has reduced the knock counts, but I really shouldn't have to run this rich at this point.
Can anyone share what AFR they are targeting around 3-4K ? The rest of my tune above 4500 looks like 10.8 - 11.2 :1, but once the knock starts at the low revs it will not abate in the upper RPM ranges until the pull is aborted.
I'm considering moving to a 650cc meth nozzle, but I do not think I should have this heavy of knock counts with the 360cc nozzle.
I actually had very little knock this summer even down in Memphis when it was 100, so I am a little baffeled at this point.
One thing I am worried about is I may have some real mechanical engine problem that is causing the knock counts, but from what I understand about the knock sensor this type of noise is not the same frequency and shouldn't show up.
I have very good oil pressure, no smoking, and no lifter tick, but maybe under heavy load I am having some rod noise, but I sure can't hear it.
The other thing is maybe I have a single injector causing problems, but again I didn't see any plugs that looked leaner than the others when I had them out last week. I also do not seem to have a miss and the engine is getting the same MPG it always has. When the car isn't pulling timing it feels strong as hell.
 Power:DR-19Ts, 550s, AEM FPR, Emanage Blue, K&N, Downpipe, ATR Catback, DevilsOwn meth, UDP, SSQV, EVC5, Walbro, FMIC, DEJON intake pipes
Best 1/4 12.56 @ 111.6 1.97 60FT Best 1/8th et 8.00 mph 89.73 1.80 60FT (old setup)
Suspension: Konig Villians, Pilot A/S, Tein S-Techs, Hawk HPS Pads, 2G brakes AWS Delete
Drivetrain: ACT HDMM, 300m O/S, PST 2 piece Al/Steel Driveshaft, 4 Poly Mounts, EK2 ExoCage
Etc: Leatherseats.com Charcoal/Grey Interior, 99 front end/lights/wing/sideskirts/doorcaps, Scanmaster3, AEM WB, 3sx 2" radiator
Samco hoses, Smokin'vr4 sub box 10" MTX sub, Pioneer Amp, JVC KD-ADV49 Ball bearing STS Greddy Boost/Oil/Water gauges
Forest Gump is offline   Reply With Quote
Old 09-27-2009, 04:22 PM   #2 (permalink)
Forum user
levani041491's Avatar
Drives: 1996 3000GT&1991 vr4
levani041491 Negative 1
Feedback Score: 9 reviews
Default Re: Engine Knock at mid-range RPM
off topic but are you unning on cast crank ?
levani041491 is offline   Reply With Quote
Old 09-27-2009, 04:41 PM   #3 (permalink)
Drunk as a lord
yes, for the last 150K miles. Bearings and oil pump replaced at 138,000
Old 09-27-2009, 04:44 PM   #4 (permalink)
Forum user
do you have anyproblems with it ?
Old 09-27-2009, 05:30 PM   #5 (permalink)
Drunk as a lord
uh, no. Your crank shaft is either in one piece or not. It either has journals out of round that have destroyed your bearings or it doesn't. It isn't like one day it could give you problems and the next it would be alright.
Some of the cast cranks had casting flaws and they would break, but the "good" cast cranks seem to take low power just fine. Since mine has been running for almost 20 years it really isn't the first thing on my list of worries.
Old 09-27-2009, 07:03 PM   #6 (permalink)
Paid Member
JayWilRTTT's Avatar
Drives: 1992 Dodge Stealth
JayWilRTTT is an unknown quantity at this point
Feedback Score: 12 reviews
I would try putting the old plugs in and see if anything changes. Like you said you were running fine before on the same amount of meth. Also maybe check out your meth nozzle and sytem to make sure its working properly. Good luck
JayWilRTTT is offline   Reply With Quote
Old 09-27-2009, 08:45 PM   #7 (permalink)
Not here for the tuna.
lawdogg's Avatar
Drives: dirty
lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2
Feedback Score: 86 reviews
Do you have solid mounts?
Maybe put race gas in and see if it disappears?
il faut voir pour savoir
Old 09-28-2009, 05:57 PM   #8 (permalink)
keithmac Level 1keithmac Level 1
Feedback Score: 4 reviews
I run 11.5:1 in that are with no problems, normally 4000rpm region which gives the most problems (dip down to high 10`s their to stave off knock).
Bit of an odd problem how it`s come on in the colder weather?. 360cc 50% meth seems on the low side but as you say you`ve not had the problem before.
On thing is these engines are prone to knock if loaded up in low rpms, quite a few people have found this.
AOL`s stolen my picture!.
JDM GTO TT, Emanage Ultimate - 780`s, E85
Hotwired Walbro - 13g`s - K&N - Blitz SSBC
13g`s - 12.4@115
TD04-16g`s - 12.5@117 (work in progress!).
keithmac is offline   Reply With Quote
Old 09-28-2009, 06:00 PM   #9 (permalink)
Drunk as a lord
I have poly front and rear mounts and stock sides.
I think I'm going to up the meth nozzle size and see if it gets squared away. I wanted to run the smallest one possible to make tuning easier, but I don't think this is enough.
I also have my doubts I'm really getting 93 octane at the place I go to. It is the only station I know of that sells 93, so I'm starting to think it is really 92 like everyone else has...
Old 09-28-2009, 06:01 PM   #10 (permalink)
Drunk as a lord
thanks for the info. I didn't know it was common to run that much richer at low RPMs than the factory setup runs.
Overall the car is running great like this, but I'm going to switch to a 650cc nozzle to try to quell this knock.
