Engine bay caught on fire - Page 2 - 3000GT/Stealth International Message Center
Old 11-19-2012, 02:17 PM   #11 (permalink)
Drives: 1992 3000gt vr4
ThatOneVr4 is an unknown quantity at this point
Feedback Score: 6 reviews
Default Re: Engine bay caught on fire
Thanks everyone, I'm sure it will be back on the road. I hope some rubbing compound will get the burnt off the inside of the hood.
I'll have to get some steel wool and polishing compound on the y-pipe.
The wires on the maf connector are fused together. The battery is melted on a few spots.
I hope everyone puts battery terminal boots/ protectors over their posts. Pretty much mine didn't have any rubber boot over the positive terminal and was the ultimate cause of the fire.
The hard line was glowing bright red and the positive wire is pretty burnt. It got so hot that the positive battery terminal was melting the lead like butter. The rubber from the BOV kept the fire burning.
I'd be lucky to just get a new maf connector, new positive terminal. New BOV hose, scrape the burnt metal and insulation. Then re-solder the wire and use electrical tape or shrink wrap the bare wires. Then see how it runs
1991 3000gt Vr4. Sold
1992 3000gt Vr4 Daily Driver
ThatOneVr4 is offline   Reply With Quote
Old 11-19-2012, 04:18 PM   #12 (permalink)
GET A GRIP
Hard AttacK's Avatar
Drives: 91 Stealth TT
Hard AttacK is an unknown quantity at this point
Feedback Score: 15 reviews
Thats the first thing i removed when i got both of my cars. It's retarded!!!
Originally Posted by mb3000 View Post
Summary:
Sleeper = excuse for not having the $ to build a well rounded vehicle.
Originally Posted by gatecrasher
DSM owner = king of how fast can i go for $26.
Hard AttacK is online now   Reply With Quote
Old 11-19-2012, 07:23 PM   #13 (permalink)
Djmba's Avatar
Drives: 1992 3000GT VR-4
Djmba is an unknown quantity at this point
Default
Pics???
Daily driven 1992 3000GT VR-4. Check out my rebuild and progress thread: http://www.3si.org/forum/f1/my-1992-...ebuild-543314/
Modifications as of 3/21/13:
3.1L, 0.050" oversized pistons, forged crank, 3SX lightweight crank pulley, K&N intake, CX Racing pre turbo pipes. SS Y-pipe, SS oil feed/return lines, DNP precat deletes, test pipe, ESP downpipe, DSM SMICs, Ninja Performance boost controller set to 13 psi, vacuum reduction, 6 puck clutch, Drweldin custom spark plug cover, Depo Racing gauges, custom leather seats, and MMCdroid OBDI-Bluetooth datalogging adapter. Everything built and done by me. More to come soon.
Currently building/on the shelf:
3.01L, 0.020" oversized pistons, forged crank, NA block, 13T turbos, KYB GR-2 struts, Tein S-Tech lowering springs.
Djmba is online now   Reply With Quote
Old 11-20-2012, 12:40 AM   #14 (permalink)
I'll get some pictures up in the morning.
Then just have to get some parts and wires from the junk yard if the 3000gt SL isn't crushed yet.
Old 11-20-2012, 10:41 PM   #15 (permalink)
Flasher
TwIzTeD_3kGt's Avatar
Drives: VR4, SL, R/T, SE
TwIzTeD_3kGt Level 1TwIzTeD_3kGt Level 1TwIzTeD_3kGt Level 1
Feedback Score: 22 reviews
I would say the problem was your loose battery. Where is your hold down?
TwIzTeD_3kGt is offline   Reply With Quote
Old 11-20-2012, 11:17 PM   #16 (permalink)
It never had one when I purchased it. I'll be buying one very soon.
Just have to find the solder iron and a wire brush and see if I can clean some of the wires, and solder a new connector for the maf. It might be up and running tomorrow.
Old 11-21-2012, 03:56 AM   #17 (permalink)
This is what the fire did to my BOV hose... burned a big hole in it
Engine bay caught on fire-100_0032.jpg   Engine bay caught on fire-100_0036.jpg   Engine bay caught on fire-100_0037.jpg
Old 11-21-2012, 11:08 AM   #18 (permalink)
Here are the last of the pictures.
Looks like it burnt a hole right into the hard line that caught fire..Hope a 3000gt SL has that same hard line.
Now it's time to fix this mess.
Engine bay caught on fire-100_0033.jpg   Engine bay caught on fire-100_0034.jpg   Engine bay caught on fire-100_0035.jpg
Old 11-21-2012, 01:05 PM   #19 (permalink)
NC Insurance Agent
jbeard1's Avatar
Drives: 1995 3000GT
jbeard1 is an unknown quantity at this point
Feedback Score: 1 reviews
Note to @op or anyone else... From a firefighter, if I seen someone trying to blow a fire out, I would probably smack them. You are only feeding oxygen to the fire. I have always kept a small fire extinguisher in my cars (mainly in case I roll on a vehicle fire without my fire engine being there... Only like 10 bucks at Walmart, and it will save you a lot of grief in the future God forbid you do have something more serious next time. Even smothering the fire with a hoodie will work (not flapping it around, because you're doing as much good as blowing it). Sure it will destroy the hoodie, but you'll be better off just buying a new jacket.
Nonetheless though, having a spare plan will save you from smoke inhalation. That shit is no fun, I know what you mean. Just thank God it wasn't worse, and you were able to get it out!!!
jbeard1 is offline   Reply With Quote
Old 11-21-2012, 01:06 PM   #20 (permalink)
NC Insurance Agent
jbeard1's Avatar
Drives: 1995 3000GT
On a lighter note though, I am sure if you could see under the hood while it was arching, it wouldve been a helluva show!
