Engine bay caught on fire - 3000GT/Stealth International Message Center
Old 11-19-2012, 01:19 AM   #1 (permalink)
Drives: 1992 3000gt vr4
ThatOneVr4 is an unknown quantity at this point
Feedback Score: 6 reviews
Default Engine bay caught on fire
I got done cleaning my IAC and when togo for a test drive, great news it fixed the car stalling issue.
Then all of a sudden when I went to loop back to head home, I hit the brakes and the car died. WTF? I see smoke coming from under the hood, I hurried and popped the hood. What do I see a big flame of fire under my MAS, next to my BOV.
That damn positive battery wire is fired to crap, the hard line was glowing red.
I guess when I hit the brakes the battery slid and was arching on the metal hardline. It melted the insulation on the positive terminal. The underside of my hood is black.
I don't know much, as I had a 3.5 mile walk back home. I just got back, and fixing to tow it back with another car
If only the battery terminals were on the other side of the battery or I had a damn terminal cover on the post!
I'm hoping I can get away with replacing the positive terminal, checking the hose on my BOV and see how badly burnt my MAS sensor is. I'm sure the wires are melted together.
I sure did have fun trying to blow it out with my lungs and inhaling smoke. The fire kept starting back up.
1991 3000gt Vr4. Sold
1992 3000gt Vr4 Daily Driver
ThatOneVr4 is offline   Reply With Quote
Old 11-19-2012, 02:52 AM   #2 (permalink)
Mystic Fiji Road Trackers
Neno's Fiji TT's Avatar
Drives: 1992 TT, 1992 R/T
Neno's Fiji TT is an unknown quantity at this point
Feedback Score: 1 reviews
Default Re: Engine bay caught on fire
Same exact thing happened to me. I was luckily arriving at home when it happened. Mine burst into flames though. HAD to use alot of water. Thank goodness all is ok though. Just replace damaged wires and hoses / lines.
Neno's Fiji TT is offline   Reply With Quote
Old 11-19-2012, 02:56 AM   #3 (permalink)
Might just get away with a new MAS connector. I'll need a new BOV hose.
Might need a new MAF if too much current ran thru the connector and fried something. I'll need a new positive terminal.
Then I'll see how it runs. Off to the junkyard in the morning.
Thanks for the support. I'm glad it wasn't worse too.
Question if it comes down to it, a 93 3000gt SL Stock MAF Mass Air Sensor wouldn't work on a 92 3000gt vr4 would it?
I hope it's just fine and all I need it so solder a new connector to the MAF. I'm sure the 93 SL MAF connector will work on the vr4, but the whole meter box will not.
Old 11-19-2012, 07:29 AM   #4 (permalink)
striker3's Avatar
Drives: 93 VR4
striker3 Level 1striker3 Level 1
Feedback Score: 2 reviews
sounds like you need a good battery tie down setup while you're picking up parts.
striker3 is online now   Reply With Quote
Old 11-19-2012, 08:42 AM   #5 (permalink)
pimprn Negative 3
The current is not going to effect your mad..... Basically you got a dead short just look for fire damage and replace whatever's butned and you should be good.
pimprn is offline   Reply With Quote
Old 11-19-2012, 08:43 AM   #6 (permalink)
pimprn Negative 3
That's messed up btw I'm going to get an enclosed battery holder now your my inspiration...
Old 11-19-2012, 08:48 AM   #7 (permalink)
Djmba's Avatar
Drives: 1992 3000GT VR-4
Djmba is an unknown quantity at this point
Feedback Score: 15 reviews
Default
Sucks to hear man Hopefully there wasn't too much damage. I always keep a fire extinguisher in my car. It gives me peace of mind.
Daily driven 1992 3000GT VR-4. Check out my rebuild and progress thread: http://www.3si.org/forum/f1/my-1992-...ebuild-543314/
Modifications as of 3/21/13:
3.1L, 0.050" oversized pistons, forged crank, 3SX lightweight crank pulley, K&N intake, CX Racing pre turbo pipes. SS Y-pipe, SS oil feed/return lines, DNP precat deletes, test pipe, ESP downpipe, DSM SMICs, Ninja Performance boost controller set to 13 psi, vacuum reduction, 6 puck clutch, Drweldin custom spark plug cover, Depo Racing gauges, custom leather seats, and MMCdroid OBDI-Bluetooth datalogging adapter. Everything built and done by me. More to come soon.
Currently building/on the shelf:
3.01L, 0.020" oversized pistons, forged crank, NA block, 13T turbos, KYB GR-2 struts, Tein S-Tech lowering springs.
Djmba is online now   Reply With Quote
Old 11-19-2012, 09:22 AM   #8 (permalink)
Drives: 1991 3000gt 99 cov
tigger is an unknown quantity at this point
Feedback Score: 29 reviews
that sucks
cut---strip---fluz ---solder---heatshrink and.........repeat
you will get it back on the road
TD05 Twin EVO 16gs , Blitz NUR Spec cat back w/ testpipe, M's Fuzzy logic boost controller , Arc-2dr, Pte 680s , Supra pump, Apexi Sitc, Act max street Clutch
tigger is offline   Reply With Quote
Old 11-19-2012, 09:24 AM   #9 (permalink)
haha...... so do I. and my wife thinks thats a problem
Old 11-19-2012, 09:45 AM   #10 (permalink)
Djmba's Avatar
Default
Both of my parent's engines caught fire. Granted, they were pushing much more HP than my VR-4, but I learned my lesson. Lol.
