Old 10-24-2008, 09:25 AM   #1 (permalink)
VR4-2FAST4U-PR's Avatar
Drives: '96 VR4, '94 850T
VR4-2FAST4U-PR is an unknown quantity at this point
Default Electrical Issue
Hi folks!
I replaced the alternator in my VR-4. Now when I accelerate to 3K rev's all the lights in the panel start flashing/blinking. I also notice the vessel lights stay kind of "on (faded)" when the car is running????
I checked the grounds connection and they look fine.
Any idea how can I fix this???
Thanks,
Vick
1996 VR-4 Pearl White,
Blitz DSBC-I-D (15psi), FIPK, FMIC, Intake & 2" IC hard pipes, UD Stock Light PulleyThree Gauge Pod: 3SX Dual EGT,A/F,Boost Gauge, HKS SS BOV, Racing Pedals, 6 Indigo Gauges, Chappor VR-4 Decal, No Pre-cats, DNP Downpipe, 3SX Real Control Arms, 3SX Chrome Cap Covers, CF Dash Kit, Dual Cannon Custom Exhaust, Bozz Performance Front Lip, Veilside Wing
Redline Fluids, RPS Max St Clucht, 550cc, Apexi S-AFC, Hot wired Supra Fuel Pump, Blitz FATT, MSD Knock alert
[IMG]
1994 Volvo 850 Turbo
Intense Performance Intake, OMP Strut Bar, UD light Pulley, Upsolute Performance Chip (14psi), 3 Gauge, Stillen DP, Pod: EGT, Boost, A/F, 3" Catback, Custom RIP
Member 1201
VR4-2FAST4U-PR is offline   Reply With Quote
Old 10-24-2008, 09:32 AM   #2 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2
Default Re: Electrical Issue
Sounds like a bad voltage regulator, which is internal to the alternator.
Is it a new unit or a used one?
R.I.P.
Old 10-24-2008, 09:33 AM   #3 (permalink)
It was a new one and was tested.
Old 10-24-2008, 09:34 AM   #4 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
Was the car doing the same things with the old alternator?
Old 10-24-2008, 09:36 AM   #5 (permalink)
No, everything was fine until it dies.
Old 10-24-2008, 09:39 AM   #6 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
Huh.
What voltage are you seeing under normal operation?
Have you double checked all connections onto the new alternator, as well as fuses and the cable from the battery to the fuse box?
Old 10-24-2008, 09:51 AM   #7 (permalink)
Hummm, I haven't look into that yet because I post to get an idea on what to do. I'll check this weekend and post back again next week.
Thanks for all your help on this matter.
Vick
Old 10-24-2008, 10:03 AM   #8 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
Good luck Vick! I hope it's just a simple loose connection or something.
