Old 06-10-2008, 01:37 PM   #1 (permalink)
Rom3BreaK's Avatar
Drives: Mitsu 92 VR4
Trader Rating: (7)
Rom3BreaK Level 1Rom3BreaK Level 1
Default EBC install ALMOST THERE SO CLOSE quick help
Ok, I've been referencing this picture for help:
http://www.3si.org/forum/attachments...please-ebc.jpg
courtesy of VR4_Rider's thread.
My EBC is digital and has a boost gauge BUILT IN.
Could somebody try to edit this picture so that it applies to me? Is all I need to do disregard the boost gauge in this picture and call it a day?
Also, this picture shows different diameter tubing- 4 and 6mm. From the plenum to the EBC is it a must that I have the 4mm tubing and not 6mm? I may have the different tube but I'm just curious.
Thanks a lot for any responses, I'm doing this right now so any help is awesome!
1992 VR4, Java Black Pearl paint ('04 STI) with combo '92/'96/'99 custom front end, Fittipaldi Force wheels, RPS Max pressure plate with street disk, P.I.T. BCU+ EBC, Gutted pre-cats, Greddy type RS BOV, K&N intake.
Currently working a minimum wage job to get my 3s back to 100% (again) as well as pay for tuition....AKA the stereotypical proud 3si member.
Rom3BreaK is offline   Reply With Quote
Old 06-10-2008, 02:02 PM   #2 (permalink)
Rom3BreaK's Avatar
Trader Rating: (7)
Default Re: EBC install ALMOST THERE SO CLOSE quick help
Sorry for the bump but I need this finished tonight, thank you.
Old 06-10-2008, 02:33 PM   #3 (permalink)
Drives: 93 FD, 95 Vr-4
binary89 is an unknown quantity at this point
What boost controller do you have?
The picture you have shows a EBC configured to read boost, the boost gauge is just a add on. This hose usually is a Teflon hard hose. As far as your solenoid connection you can use a 4mm or 6mm, connect a 4mm hose to a 6mmm etc... Just make sure the connection is tight.
Yes ignore the Boost Gauge
Rides
1995 White VR-4 : Blitz SBC ID III, Greddy Type RS, Stillen Intake, 3SX Downpipe, 3SX Pre-Cat Eliminators, 3SX 8000k HID Kit, MirageCorp Hybrid Datalogger
1993 Blue Rx-7 : StreetPort + 3mm Apex Seals, PFS Tunned Purple ECU, Walbro 225lph Fuel Pump, Greddy Rubix injector controller, 3" Turboback exhaust, Exedy Twin Plate Clutch, Fiske FM5's with Eagle F1's
binary89 is offline   Reply With Quote
Old 06-10-2008, 02:36 PM   #4 (permalink)
Deigea's Avatar
Drives: '94 3000GT VR4
Deigea is an unknown quantity at this point
which EBC is it? I did a vac reduction when installing mine (blitz spec R), so it might've been a bit simpler. As for the lines, I think I have the one coming off the y-pipe going to the solenoid and the one on the back of the plenum going to the boost guage on the device.
Pearl Yellow 1994 3000GT VR4 - Sorta Running / Red 1992 Stealth Base - Daily Driver
3S West Coast National Convention, Oct. 17-19, 2008 - www.3swcnc.com
Deigea is offline   Reply With Quote
Old 06-10-2008, 03:16 PM   #5 (permalink)
Rom3BreaK's Avatar
Trader Rating: (7)
Hey guys thanks for replying, I'm testing out the P.I.T. (performance import trends) BCU+, I've also seen it on The boost controller store site called a "DeeZee" boost controller:
Performance Import Trends
Edit: I still would like to know everything for sure, but there's no hurry anymore. I'll just finish it up early tomorrow I suppose. Thank you.
Old 06-10-2008, 03:46 PM   #6 (permalink)
I've never heard of it, let us know if it works well.
Old 06-10-2008, 03:51 PM   #7 (permalink)
Rom3BreaK's Avatar
Trader Rating: (7)
Yep, I've had more than a few people tell me they're interested in it because it's relatively cheap. I'll post up a review after I've tried it out for a little while.
