Old 10-10-2004, 03:13 AM   #11 (permalink)
Z15A Tweaker
Trevor's Avatar
Trader Rating: (20)
Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4
Default Re: Dual Setrab oil coolers installed (pics)
Yeah...6cm2-14b's. I might try 7cm2 housing after I make a few trips to the track to get a baseline with the 6's. I bought 4.5 14b's and had the best parts built into a pair of really good ones. Should get them back from the builders around the 16th.
I hear what you're saying John...you didn't loose me. I probably read it in the same place that you did (Maximum Boost). My buddy originally convinced me to tilt them outward and since it was 2:30 in the morning I didn't put up much of a fight. Before I put the front end back on I'm going to bend them inward.
96 Dodge Stealth R/T TT w/59k
10.396 @ 138.94 (C16+Meth)
10.898 @ 130.00 (91+Meth)
Trevor is offline   Reply With Quote
Old 10-10-2004, 03:19 AM   #12 (permalink)
"The Fisherman"
pyun's Avatar
Drives: around scaring birds
Trader Rating: (75)
pyun is an unknown quantity at this point
trevor, can you post a pic with both the installed coolers?
pyun is offline   Reply With Quote
Old 10-10-2004, 03:49 AM   #13 (permalink)
Z15A Tweaker
Trevor's Avatar
Trader Rating: (20)
Old 10-10-2004, 03:56 AM   #14 (permalink)
Verified Asian
Sean3S's Avatar
Drives: 94 TT
Trader Rating: (37)
Sean3S Level 1Sean3S Level 1
Beautiful looking setup Trevor, be sure to keep us posted on your new icy oil temps
'94 RT/TT
13T's | PTE FMIC - PPE Pipes | 560's | Supra FP w/ 8ga Hotwire | MAF-T 1.37 & LT1 Blow-Through | E-Manage Blue w/ Boomslang Harness | HKS DLI | Stillen Downpipe | Gutted Rear Pre-cat | Borla Catback | Tial BOV | AEM FPR & Rob Beck Adapter | DejonTool Intake Pipes | PWR Radiator w/ IPS Pipes | FAL Fans | MP Motor Mounts | 99 Lash Adjusters | Clevite 77 Rod & Main Bearings | Leatherseats.com Dk. Graphite w/ Red Center Seats | Sparco Flash 5 Black w/ Red Alcantara | Spec Stg. 2 Clutch & 3SX Clutch Line | 3SX Crank Pulley | Bob's SS Shifter & All Solid Bushings | eK2 EGR Blockoffs, Fuel Line Loop, Injector & Harness Cover | PST 1 Pc. CFDS | Volk LE37T | Falken FK452 | Megan Racing Coilovers | Adj. Rear Control Arms | Slotted Rotors w/ Hawk HPS Pads | GReddy Profec B | AEM UEGO WB | GReddy PWH Boost, EGT, GReddy OP, FP, Temp | Hybrid Logger | McColluch 5300K HIDs | Shaved '99 Bumper & Turns | PRM Style Hood
295.7 AWHP / 310.3 TQ @ 1 Bar - BPU @ TX04
Collecting Dust - Setrab Oil Cooler, Snow Stage 2 Meth, Brake Lines, Solid Diff Bushings
Some Day - ABS Delete, Ducting
Sean3S is offline   Reply With Quote
Old 10-10-2004, 02:00 PM   #15 (permalink)
vehicular thaumaturgist
Multiades's Avatar
Drives: 1994 Stealth TT
Multiades is an unknown quantity at this point
Nice one Trevor. When you first said you didn't want to give away WHICH brand oil coolers you were using I guessed Setrab. Only the best, huh.
The ducting on your FMIC/condenser/radiator (whew that's a thick layer of stuff for cooling) is awesome. I've got nothing but a radiator in the front section of my car, which would be perfect for a FMIC at some point (I happen to like my nice, affordable DSM sidemounts for the time being).
-Chris
The Pansy Patrol - a 3000GT/Stealth car blog with how-tos
Pearl Yellow 1994 R/T TT w/84k - FOR SALE! new 4-Bolt factory short block, DR StgII heads, Titan TD05 headers, 14B turbos w/ ported 7cm^2 housings, 3" minimum-bend catless exhaust, SCE oil pan, RPSII clutch, Fidenza flywheel, OZ F1 Plus 17x9.5" wheels, Kumho Ecsta MX 245/45 tires, Drweldin DSM SMICs, 3SX engine mounts (Maximal solid front), GReddy 60mm P/H/W boost, Carbotech Panther Plus & Bobcat pads w/ slotted/drilled rotors, KSport GT-Pro coilovers, Maximal rear camber arms, SCE balljoints, ABS delete w/ cockpit-mounted Wilwood proportioning valve, AC delete, EGR/evap/dashpot delete, cruise/vacuum-tank delete, '95 Lexan headlights, McCulloch 4300K HIDs, GReddy Type-S BOV, solid shift bushings; Misc Parts: Walbro341, 20# fixed-back seats, Accelerated Moto catch can
Multiades is offline   Reply With Quote
Old 10-10-2004, 02:30 PM   #16 (permalink)
Paid Member
SK VR4's Avatar
Drives: naked
Trader Rating: (18)
SK VR4 is an unknown quantity at this point
Originally Posted by John Monnin
Trevor's air deflectors
.../--B
R----B
R----B
R----B
R----B
...\--B
Theoretical air deflector that MIGHT help
..|--B
R----B
R----B
R----B
R----B
..|--B
EDIT: Clear as mud, I will have to make real pictures or delete this post so i don't look like an idiot.
wow, someone bought into maximum boost WAYYYYYY too much.
SK VR4 is offline   Reply With Quote
Old 10-10-2004, 09:56 PM   #17 (permalink)
Wrenchmonkey #839
John Monnin's Avatar
Drives: crappy SHO
Trader Rating: (29)
John Monnin Level 2John Monnin Level 2John Monnin Level 2John Monnin Level 2John Monnin Level 2
Heh! I put my disclaimer in
It made sense once I thought about it, but it is the opposite of what most people do. I am just try to make Trevor do all of my research for me
For sale 6G74 Modified to install in 3Shttp://www.3si.org/forum/f68/f-s-com...9/#post5613940
John Monnin is offline   Reply With Quote
