Old 10-09-2004, 06:12 AM   #1 (permalink)
Z15A Tweaker
Trevor's Avatar
Trader Rating: (20)
Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4
Default Dual Setrab oil coolers installed (pics)
Details are in this thread:
Details on my new oil cooler setup
96 Dodge Stealth R/T TT w/59k
10.396 @ 138.94 (C16+Meth)
10.898 @ 130.00 (91+Meth)
Trevor is offline   Reply With Quote
Old 10-09-2004, 09:46 AM   #2 (permalink)
Mellon's Avatar
Drives: 91 TT Stealth 05 EVO
Trader Rating: (18)
Mellon is an unknown quantity at this point
Default Re: Dual Setrab oil coolers installed (pics)
it's a shame you're having to go through all that trouble just to get the temp back to factory I hate spending money on parts that don't make me go faster (brakes lol)
that's a bitchin setup though, looks very nice. Do you have shields on the side of the front mount to keep air from escaping past it?
- Chris
05 EVO and 91 Stealth R/T TT
**video**
Upload your 3/S videos here http://3svideo.vidiac.com and post www.racevideoforums.com
Intake: E16G turbos, DR Stage III heads, DR Race cams, Unorthodox Cam gears, Stock MAS, 6" K&N air filter, HKS SSBOV, Vacuum Reduction, custom 2.5" intake pipes and Dejon FMIC
Ignition: MSD 8.5mm spark plug wires, NGK non-resistor non-projected R5671A-8 gapped at .026, HKS Twin Power DLI
Electronics: Greddy Turbo Timer, Greddy E-Manage Blue, Greddy Profec E-01, MMCD and Palm, LM-1 Wideband + RPM Converter
Fuel: Blitz 720cc injectors, Denso 310lph fuel pump, Fuel pump Hotwire , relay bypass, IPO SX Fuel Pressure Regulator and Kenne Bell Boost-a-pump
Exhaust: Titan TD05 Headers and 02 housings, EGR Blockoff Plates, ATR downpipe, Twin Borla mufflers
Driveline: RPS MAX 6-Puck Clutch and RPS Flywheel, 17" Enkei RPF1 (16lbs each), Nitto 555 Extreme, TEIN S-Tech springs and KYB GR2 Struts
Other: Unorthodox Underdrive Pulley, Krankvents
Mellon is offline   Reply With Quote
Old 10-09-2004, 11:37 AM   #3 (permalink)
Z15A Tweaker
Trevor's Avatar
Trader Rating: (20)
Like this?
Old 10-09-2004, 11:44 AM   #4 (permalink)
Regulator...
mikes2nd's Avatar
Trader Rating: (32)
mikes2nd Level 1mikes2nd Level 1mikes2nd Level 1
no big pressure loss?
thats what i was worried about.
I relocated my stocker to the front with earls lines
mikes2nd is offline   Reply With Quote
Old 10-09-2004, 11:52 AM   #5 (permalink)
pengulns2001's Avatar
Drives: Dodge Stealth R/T TT
pengulns2001 is an unknown quantity at this point
nice that looks incredible well done whats the pressure at?
pengulns2001 is offline   Reply With Quote
Old 10-09-2004, 12:05 PM   #6 (permalink)
Z15A Tweaker
Trevor's Avatar
Trader Rating: (20)
You're not going to have a big pressure drop with them in parallel like that. The oil now has two paths to choose from simultaneously instead of being foced thru one cooler (of less efficient design I might add). It's like adding another lane to a highway. Now granted there's going to be some minimal additional pressure loss from the longer lines but running two coolers will MORE than make up for it.
If I were to have run them in series then I'd have a hell of a pressure drop.
I'm not going to be starting the car for at least a week...still waiting on the turbos to come back from the builders.
Old 10-09-2004, 12:20 PM   #7 (permalink)
while its sitting like that do you think you could take a pic of the front manifold/turbo area for me it would help me out a TON and i see you have a y pipe going into your intercooler do you reccoment that or having a dual inake intercooler
Old 10-09-2004, 06:07 PM   #8 (permalink)
Wrenchmonkey #839
John Monnin's Avatar
Drives: crappy SHO
Trader Rating: (29)
John Monnin Level 2John Monnin Level 2John Monnin Level 2John Monnin Level 2John Monnin Level 2
Sorry to go off topic but what turbos are you going to? From the disco Potato thread it sounded like you were considering something similar to a 14B?
P.S. The setup looks nice. If you still have overheating problems you might want to add a electric fan to the oil coolers, but since you have 2 now that might get expensive.
One thing that I am considering is a side mounted A/C condensor. It would have to be 3 or 4 rows thick to compensate for the overall decrease in size, it would require a separate fan and it still would probably not work as good as stock but it would allow the stock radiator to be a 1/2" thicker. I know some engineers at SCS (they make A/C units for our trucks, and a lot of retrofit kits for classic cars) IF I every get serious about this I will have them run the numbers to see if it would work at all.
For sale 6G74 Modified to install in 3Shttp://www.3si.org/forum/f68/f-s-com...9/#post5613940
John Monnin is offline   Reply With Quote
Old 10-09-2004, 06:09 PM   #9 (permalink)
No longer a 3/S owner.
VR-4Maniac's Avatar
Drives: 1988 Oldsmobile
VR-4Maniac is an unknown quantity at this point
I don't want to speak incorrectly for Trevor, but I believe he is going with 14Bs.
Matt
1991 VR-4 - Stock - Crashed by a friend and totalled.
1993 VR-4 - 11.76@119, 11.77@122 - Sold to a new, appreciative owner.
VR-4Maniac is offline   Reply With Quote
Old 10-09-2004, 06:21 PM   #10 (permalink)
Wrenchmonkey #839
Drives: crappy SHO
Trader Rating: (29)
Trevor do you have a picture of your intercooller air deflectors with the front bumper on?
I have read that it is better to have the opening in your bumper smaller than your intercooler/radiator. The theory is that the intercooler slows down air flow so much that air wants to go around it. If the bumper opening larger than the radiator the air can flow away from the intercooler because the taper of the air deflectors lets the air go sideways and right back out the bumper opening around the edges. The air trying to go around the intercooler has to fight the air coming into the bumper going rearward but it does not have to fight as hard to go sideways so some of the cooling air gets away
But if the bumper opening is smaller than the radiator when the air tries to go sideways it it forced back to the center so air trying to go around the radiator has to fight both the air coming flowing rearward and the air going sideways.
I would not suggest making your bumper opening smaller but is it possible to mount flat plates to the sides of your intercoolers to make that surface wider so that your deflections shields get wider as they go rearward. Your photo above showed your deflection shields getting narrower as they go rearward.
Does this make any sense at all? I have a very difficult time explaining things like this.
I have no proof this will help at all, it could only help when the car is moving, when you are idling in traffic the angle of the deflection shields will not help at all.
I'll try to do some ASC art to clarify
Trevor's air deflectors
.../--B
R----B
R----B
R----B
R----B
...\--B
Theoretical air deflector that MIGHT help
..|--B
R----B
R----B
R----B
R----B
..|--B
I am trying to show that the Radiator(shown by R's) and the Bumper (showed by B's) can stay the same size but the shape of the air deflectors can be changed to force more air to go through the radiator, theoretically
EDIT: Clear as mud, I will have to make real pictures or delete this post so i don't look like an idiot.
