Old 05-09-2008, 02:04 AM   #1 (permalink)
Mr. Cheese
92RT-TT's Avatar
Drives: 92 RT/TT & 92 RT/TT
Trader Rating: (14)
92RT-TT Level 192RT-TT Level 1
Default DSM sidemounts+9B/13G+450cc inj+SAFC=What boost?
Here is my question for all you experts out there, I just bought some DSM 450 blacktop injectors, an SAFC, and A hotwire kit and in a day I'll have a walbro 255 too. My plan is to buy a 13G and do a 13G/9B combo.
Correct me if I'm wrong but normally wont a 9b just blow hot air past I think I've read people say 15 psi? But the 13G should be good for a little over that, so my question is, if I put on some DSM sidemount intercoolers, could I run 15-17 lbs of boost and not have the 9b killing any of the 13g's gains at the high boost levels?
My reasoning (which may be flawed, I'm a noob at this stuff ) was that while the 9b probably would be pushing alot of hot air, the dsm smic would cool it down and then the 13g's boost would make for that and allow me to still post some good power gains over running this combo just at 14-15 psi.
Thanks for taking the time to look at this, I'm a noob when it comes to upgrading these cars really so I'm just going off of what I've read and what assumptions I've made (hopefully correctly lol).
And the reason I am running or will be running a 13g/9b combo is because I am trying to be semi-cost efficient. I've got a couple other projects in the works so I cant devote 100% of my car money to this, but I still want to modify it a little and have some fun
1992 Dodge Stealth RT-Twin Turbo
64,000 miles, Stored Winters, AEM Tru-Boost, Greddy Type S BOV, DNP Y-Pipe and Intake Pipes, Palm MMCD, Tein S-Tech Springs, Brembo Rotors, MSD Wires, K&N FIPK, EGR Delete, Vacuum Reduction, Cianci 3 Gauge A-Pillar, 5zigen FN01R-C 18x9.5's wrapped in BFG KDW 265-35-18's. 13% Tint, 12 Disc CD changer, Greddy Turbo Timer.
92RT-TT is offline   Reply With Quote
Old 05-09-2008, 05:37 AM   #2 (permalink)
Drives: 1993 Mits 3000gt VR4
q2418130103p is an unknown quantity at this point
Default Re: DSM sidemounts+9B/13G+450cc inj+SAFC=What boost?
take what i say with a grain of salt, I also dont really know.
I believe one of hte few benefits of running 9b/13g combo is that they deliver their power in different power bands, the 9b will have power in lower rpms, while the 13g will have power in higher rpm ranges.
as far as what pressure to run... try a low number and go up until you start excessivly knocking (or rather when you timing starts getting pulled hard)
Want to Buy:
  • Door Interior with no bubbles
q2418130103p is offline   Reply With Quote
Old 05-09-2008, 06:45 AM   #3 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7
Every car is different. Start with reasonable boost, log, and increase slowly until you lean out or knock.
If you just want a very general idea, I run 1.1 kg/cm2 on virtually the same setup.
Clint
The Pansy Patrol
1994 Mazda Protege DX: 253K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech Panther Plus, Miata wheels, other crap here and there, arguably the fastest piece of shit in New England and no one can do anything about it
Struggly is online now   Reply With Quote
Old 05-09-2008, 08:59 AM   #4 (permalink)
Mr. Cheese
92RT-TT's Avatar
Trader Rating: (14)
Clint
thanks you two... yeah thats sounds like the safest bet... just log and turn it up slowly.
Old 05-09-2008, 09:01 AM   #5 (permalink)
Mr. Cheese
92RT-TT's Avatar
Trader Rating: (14)
sorry if this is a really noob question... but how many psi in lbs is 1.1kg/cm^2? I tried looking it up via google and no luck lol???
Old 05-09-2008, 10:31 AM   #6 (permalink)
Dare to be Stupid
92StealthTT's Avatar
Drives: 92 Stealth RT/TT
Trader Rating: (23)
92StealthTT Level 192StealthTT Level 1
Online Conversion - Pressure Conversion
1.1 kilogram-force/square centimeter = 15.645 677 668 pound/square inch
92StealthTT is offline   Reply With Quote
Old 05-09-2008, 09:46 PM   #7 (permalink)
Mr. Cheese
92RT-TT's Avatar
Trader Rating: (14)
thanks for the link and the info
