#2 (permalink) |
Forum user
Do you have a 1st gen or 2nd gen car?
Performance
6G72 Rebuilt w/ 3SX Stage 3 Heads (+1mm intake/exhaust) - ARP Headstuds, Wiseco 8.5:1 Forged Pistons & Kevlar Timing Belt - TD04 9B - Greddy Profec B Spec 2 Boost Controller – Greddy Turbo Timer - SSQV BOV - K&N FIPK - Dejon Tool Y-Pipe - Dejon Tool Intake Pipes - OEM 360cc Injectors - IPO Hotwire Kit - EK2 Fuel Rail Loop – eBay 3” Downpipe w/ custom Flex Section - IPO UD Pulley – RPS MAXX Street Clutch - Maximal Xcase Bracket - MSD 8.5mm Plug Wires - NGK Copper Plugs - Maximal Performance Front & Rear Solid Motor Mounts - 3SX EGR Block Off Plates - Vac. Reduction - AC Delete – Cruise Control Delete - ProSport Gauges (Boost, EGT) - Odyssey PC680 Under Fuse Box Sitting in garage: EVO 560cc Injectors - MAP ECU - WRX 13T Turbos - Krank Vents - Walbro 255 Suspension/Wheels/Brakes OEM 17” Chrome Wheels – 245/45/17 Michelin XGT Z4's Sitting in garage: RS*R Springs – Bilstein Struts – Maximal Adj Control Arms Exterior/Interior/Dress-up Autometer 2x52mm Gauge Pod - 99 Rear Center Garnish – Weevil Custom Boost Controller/Turbo Timer Mounting Plate – Snake Eyes Delete Sylvania Silverstar H4666ST – Powder Coated Upper/Lower Intake Manifold, Front/Rear Valve Covers, Y-Pipe, Waterneck, & Alternator Bracket 6G72 Engine Manual - M-Spec Vac Reduction Diagrams - My Picasa Web Album |
#4 (permalink) |
Forum user
Just get an eBay DP like this one, and get a 3" flex section from performance-curve.com. Get them welded together, and your good to go. Even though the DP says 94+, I have yet to see one that will work on a 2nd gen precat flange. Everyone I have seen is for a 1st gen.
#5 (permalink) |
I have a stillen on my 1st gen. works perfect and its pricey.
His - Red 93 RT/tt
Mods: Hallman's MBC @ 16 psi psi, turbo XS type H BOV, stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, slightly gutted mas, dsm SMIC's, ACPT 1 piece CFDS, Tein S springs, pte 580 inj's, safc neo/SITC, 13t's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer. Hers - BPU Green 94 vr4 |
