craziest issues ive ever seen - 3000GT/Stealth International Message Center
Old 03-21-2012, 11:02 PM   #1 (permalink)
Drives: 91 vr4
15913000gt is an unknown quantity at this point
Feedback Score: 0 reviews
Default craziest issues ive ever seen
today i started my car, and it backfired and ran absolutely terrible. i figured id let it run see if it would fix itself. and it did, when the car warms up it stops backfiring and idles good. anyone else had to fix this? if so what is it? what can it be? please any help would be usefull, i have no idea whats going on
15913000gt is offline   Reply With Quote
Old 03-21-2012, 11:19 PM   #2 (permalink)
mb3000's Avatar
Drives: 3000gt
mb3000 Level 1mb3000 Level 1
Feedback Score: 29 reviews
Default Re: craziest issues ive ever seen
What year is the car.
Help Chris win his fight against Multiple Myeloma!
Click Here to See His Story
mb3000 is offline   Reply With Quote
Old 03-21-2012, 11:21 PM   #3 (permalink)
Amsterdamn
Turbo Beast's Avatar
Drives: '78 Trans Am
Turbo Beast Level 1Turbo Beast Level 1
Feedback Score: 9 reviews
Is there any maintenance record?
The VR4 is far, but not forgotten!
Turbo Beast is offline   Reply With Quote
Old 04-02-2012, 05:10 PM   #4 (permalink)
Drives: 91 vr4
its a 91 vr4. i replaced the caps on the ecu if your going to ask that, and i have 115k timing belt oil and water pump just done, wich is when this started, timing is good checked it a million times, the only upgrade is a 3 inch downpipe. but thats it
Old 04-02-2012, 11:53 PM   #5 (permalink)
mb3000's Avatar
Drives: 3000gt
http://www.stealth316.com/2-fuelpumprelaybypass.htm
Old 04-03-2012, 10:07 PM   #6 (permalink)
Drives: 91 vr4
ill check it tommarrow, but would this make me run rich? also thanks alot for the reply i would have never thought that that could be it
Old 04-03-2012, 10:11 PM   #7 (permalink)
mb3000's Avatar
Drives: 3000gt
The extra voltage from this mod is minimal at best. For more voltage you're going to need a hotwire, but that's beside the issue.
Old 04-03-2012, 11:32 PM   #8 (permalink)
3S Surgeon
jstarr427's Avatar
Drives: '91 VR4
jstarr427 Level 1jstarr427 Level 1
Feedback Score: 7 reviews
Try pressure testing the intake when it's cold. I've seen cars run like shit because of vacuum leaks, when stuff warms up it expands, sealing said leaks.
'98 Base Caracas Red 1 of 6: Purchased 3/08, Sold 11/11
'91 VR4 Jamaican Blue 1 of 12: Purchased 10/11: BPU+, Freshly Rebuilt 4 bolt, Comp. Clutch stage 2 w/14 lb flywheel, 3sx pre-turbo intakes, EGR delete/vac reduc, 2g brakes, Tein S.tech springs, DSM SMIC's, gutted precats, 3sx Downpipe, 3" test pipe, M2/ Borla Exhaust. To be installed: new subframe, 4ws delete.
I do 3S work locally! PM me for more info.
jstarr427 is offline   Reply With Quote
Old 04-03-2012, 11:47 PM   #9 (permalink)
mb3000's Avatar
Drives: 3000gt
Great post. I've experianced the same thing myself.
Old 04-04-2012, 07:53 PM   #10 (permalink)
Drives: 91 vr4
i pressure tested it after i blew an intercooler pipe off on the highway. everything is good, it held pressure and when i tooke the blow gun off it all the air shot right back at me. i am at a total loss, maybe from lack of knowledge of the car. but it seems to me like im overlooking something small but its obviously important. ohh and i tested the vacum lines on the throttle body for leaks too. theyre fine.
