Check Engine Light - How To Diagnos?? - 3000GT/Stealth International Message Center
Old 01-06-2008, 11:07 PM   #1 (permalink)
92SLVR4's Avatar
Drives: 92SL-TT+AWD Swapped
92SLVR4 is an unknown quantity at this point
Feedback Score: 15 reviews
Default Check Engine Light - How To Diagnos??
My check engine light came on about 300 miles ago and I tried to go to autozone to get it diagnosed but they said since its under 95 they cant do it. I dont have a diagnostic scanner but my friend told me theres a way to find out on an OBD1 ECU by doing some kind of trick to make the check engine light flash a certain amount of times and that'll tell you whats wrong. Anyone know how I can find out whats wrong?
It came on about 300 miles ago and nothing has changed since, no difference in idle, no weird noises, no difference in performance, nothing. Anyone have any suggestions??
92SLVR4 is offline   Reply With Quote
Old 01-06-2008, 11:15 PM   #2 (permalink)
Rockstar
ViperZ's Avatar
Drives: 92 DR650 RT/TT
ViperZ is an unknown quantity at this point
Feedback Score: 33 reviews
Default Re: Check Engine Light - How To Diagnos??
http://stealth316.com/2-diagconn.htm
http://stealth316.com/2-diagcodes91-93.htm
It's really easy, just follow the steps.
92' Stealth R/T TT-DR-650s, Greddy FMIC, MAFT, SAFC2, Greddy profec B spec 2, HKS turbo timer, Dejon pre-turbo intake pipes, PST aluminum driveshaft, Maximal Tcase bracket, 25 spline trans, Fidanza Flywheel, Spec stg 3 clutch, 3sx underdrive pulley, Solid motor mounts, 550cc injectors, Walbro 255, Fuel lab FPR, Fuel rail loop, braided fuel lines, plenum spacer, Borla catback, Megan DP (giggidy ), gutted precats, 19" SSR D5Rs, Drilled/slotted rotors, Tein S Techs, Aluminum STEALTH door sills and spark plug cover, Dual ARM-1's, Autometer gauges, Front mount oil cooler, 3sx dual pass radiator w/ flexlite fans, RFL BOV.
ViperZ is offline   Reply With Quote
Old 01-06-2008, 11:17 PM   #3 (permalink)
Rockstar
ViperZ's Avatar
Arrow Re: Check Engine Light - How To Diagnos??
oh and btw, this can only be done on first gens. (91-93). After that I believe is when you could turn the key and read the number of times the check engine light blinked. I'm guessing that your O2 sensor is bad.
Old 01-07-2008, 02:06 AM   #4 (permalink)
ASE Mechanic
RyeH's Avatar
Drives: In circles
RyeH is an unknown quantity at this point
Feedback Score: 3 reviews
Yeah ViperZ is right. What it basically is, is a jumper that will make the engine light flash a number of times....how it flashes is your code. Its like morris code. You will get quick flashes then slow flashes. You count the slow as tens and the quick flashes as ones. ie. __ __ - - - would be 23. and 23 will be the code. You will then have to look up what the code means then go through a dio tree to figure out exactly what caused the fault code.
1991 Dodge Stealth R/T (RIP)
1992 Mitsu 3000GT SL (sold)
1992 Mitsu 3000GT SL (project Restore)
RyeH is offline   Reply With Quote
Old 03-21-2008, 12:01 AM   #5 (permalink)
m3-vr4 is an unknown quantity at this point
Feedback Score: 0 reviews
Originally Posted by ViperZ View Post
hi viperz and others who read this.
I how, if you dont have the device shown on the site, would you go about self checking diagnosis from the "morse code" check engine blinking. BTW those two sites were good. but i dont see how you can check with out the device.
thanks
m3-vr4 is offline   Reply With Quote
Old 12-01-2009, 07:54 PM   #6 (permalink)
Drives: 94 Stealth RT NA
instant is an unknown quantity at this point
So can anybody verify "turning the key" method to get the CEL blinking the codes? I can't get it to work.
instant is offline   Reply With Quote
Old 12-06-2009, 11:58 AM   #7 (permalink)
is key method possible for a 94?
Old 06-10-2010, 01:44 PM   #8 (permalink)
Drives: 91 stealth r/t, 03R1
come2venus is an unknown quantity at this point
i know this may be completely off topic but it seems like you know a lot and I've been looking for a while and still haven't found a problem that resembles mine.
i'm driving at low speeds (0-10) and my car (91 stealth r/t automatic) starts hesitate kind of like when you have a manual transmission and you don't give it enough gas. My check engine light and my abs lights blink then go away ... the car either shut offs and goes through it two or three times then run fine again...
do you have suggestions for me?
come2venus is offline   Reply With Quote
