Old 07-01-2008, 08:44 AM   #1 (permalink)
rippin up lil FWD cars!!
twinturbvr4's Avatar
Drives: 93 3000GT VR-4
Trader Rating: (13)
twinturbvr4 is an unknown quantity at this point
Default Changing lifters
Hey guys, just a real quick question. My front head is ticking only, is it wise to replace ALL the lifters at the same time, or is it ok to just replace the front ones.. ie, is it bad to run 99 lifters on the front head and stock ones on the rear?
16Ts, ATR downpipe with high-flow cat, MBC (in cockpit), Kormex'd, 560cc's, Walbro Pump, MAFT GenII, 3.5" GM MAF Blow-through, HKS SSQV '07, EGR Blockoffs. Rebuild in process, machine work done by Beezer Machine, Upper Darby, PA not sponsored unfortunately
twinturbvr4 is offline   Reply With Quote
Old 07-01-2008, 10:12 AM   #2 (permalink)
Senior Member
defgh1's Avatar
Drives: 99 VR4, 04Volvo V70R
Trader Rating: (8)
defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7
Default Re: Changing lifters
It would be better to replace all the lifters at once, but having the 99 lifters on the front head and stock ones on the rear should be OK.
Doug H
91 Sandstorm TT, 431 AWHP, 433 ft-lbs. , Kormex 25 spline,LSD, RPS CC Clutch, 4 bolt conversion, Super 15Gs, Stage 3 heads, DSM Sidemounts, PST Driveshaft, Blitz DSBS, HKS Exhaust, 3SX Downpipe, Supra Pump, 780 cc PTE Injectors, SX Fuel reg. & dual feed, AEM, Duel WJO Wideband, HKS DL1, Alcohol Injection. Photos: -->
defgh1 is offline   Reply With Quote
Old 07-01-2008, 10:46 AM   #3 (permalink)
Trader Rating: (13)
Doug H
Agreed, if it doesn't cause any damage or anything, I'd do the fronts now, as they are the ones giving the problem, and maybe ill come across another half set down the line and do the rears
Lack of excess $$ + necessity to change fronts only...
thanks for the input
Old 07-02-2008, 01:20 PM   #4 (permalink)
Senior ***** Member
Drives: 92 Stealth RT/TT
MacGyver is an unknown quantity at this point
Is it hard to change out the lifters on a DOHC?
MacGyver is offline   Reply With Quote
Old 07-02-2008, 02:55 PM   #5 (permalink)
Senior Member
defgh1's Avatar
Trader Rating: (8)
http://www.stealth316.com/misc/insta...ew_lifters.doc.
Doug H
Old 07-02-2008, 11:24 PM   #6 (permalink)
Senior ***** Member
Thank you, sir.
Old 07-07-2008, 09:56 AM   #7 (permalink)
Trader Rating: (13)
Yea, doesn't look too terrible, kind of time consuming though, especially for first try..
