Catch Can INSTALLATION. The Final Debate. - Page 9 - 3000GT/Stealth International Message Center
Old 01-28-2013, 01:30 PM   #81 (permalink)
Always Learning
mikeyVR4's Avatar
Drives: 2013 WRX Prem 4D WRB
mikeyVR4 is an unknown quantity at this point
Feedback Score: 8 reviews
Default Re: Catch Can INSTALLATION. The Final Debate.
Originally Posted by Forest Gump View Post
That is essentially what I said. Run the rear valve cover hose to a catch can or install a breather filter. If you have a ton of blow by then you may have to clean the breather filter occasionally. That is where a catch can will keep things a little cleaner.
Do you think it will be okay if my catch can does not have a breather on it? The vacuum will remain sealed.
mikeyVR4 is offline   Reply With Quote
Old 01-28-2013, 02:14 PM   #82 (permalink)
Drunk as a lord
Forest Gump's Avatar
Drives: 1995 Stealth TT
Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2
Feedback Score: 100 reviews
the catch can has to vent somewhere or you are just plugging the hole in the valve cover.
Forest Gump is offline   Reply With Quote
Old 01-28-2013, 03:23 PM   #83 (permalink)
never finishes anythi
drgonzo3000's Avatar
Drives: 93RT/TT & 1/2 92R/T
drgonzo3000 Level 1drgonzo3000 Level 1
Feedback Score: 46 reviews
Connect it back to the intake bubble as it should.
The vacuum comes from the intake side of the PCV system. The point of the catch can is to catch/condense the oil coming from the valve cover and stop it front getting back into the intake track and gumming up the intake/rear turbo...
93 Stealth TT - 10:1@16psi
Snow Perf Meth,3sx DP, Megan SS Exhaust, FuelLab FPR, Walbro FP, MP Solid Mounts, All 16an Lines, Intrax Springs,
AWS/ABS/Cruise Delete, MP Rear Control Arms, SS Brake Lines, 99 Front Conversion, 2nd gen Rear Bumper, Complete interior LED Swap
drgonzo3000 is offline   Reply With Quote
Old 01-28-2013, 03:37 PM   #84 (permalink)
I'm a Member
Drives: GTO 1996
MichaelMR2 is an unknown quantity at this point
Feedback Score: 6 reviews
Yep, just like I said in post #5.
Another Day Another Dollar
MichaelMR2 is online now   Reply With Quote
Old 01-28-2013, 04:03 PM   #85 (permalink)
Always Learning
mikeyVR4's Avatar
End thread now!
Old 01-28-2013, 04:12 PM   #86 (permalink)
Adam7's Avatar
Drives: With Both Hands
Adam7 is an unknown quantity at this point
Feedback Score: 2 reviews
Not if you run it inline with the hose. it will act the same as stock with the benefit of catching contaminants. Same goes for the the front.
1998 3000GT SL: Current build - TT conversion w/chromed ECU. IPS downpipe, testpipe, Borla catback, Catless, polished Ypipe, Injen filter, Kurama intercooler hose's, 3sx fuel loop, Stm filter to rail, hotwired fuel pump, Greddy+Mishimotto catch cans, Hallman pro MBC, msd 8.5wires, 18x9 Saleens w/Nitto's, Powerslot rotors, Hawk pads, polished plenum, 5k hid's, clear corners, marqui window tint, Tenzo racing seats, weight reduction(289lbs),gasket matched TB/upper/lower plenum,polished exhaust manifold,hdr front lip,UP rear strut bar,Autometer sport comp gauges(center vent & pod) AEM WBO2
Adam7 is offline   Reply With Quote
Old 01-28-2013, 04:15 PM   #87 (permalink)
Drunk as a lord
yeah that is exactly what I ran.
The rear is the most important because it sends all the oil through your turbos and then through the intercooler piping.
Old 01-28-2013, 04:36 PM   #88 (permalink)
Adam7's Avatar
Mikey, you could put the breather filter on the rear as Ray and others said and put your Catch can(since you already have one) inline the pcv hose, and have best of both worlds, Zero blowby entering your engine.
I still stand by adding a can inline the pcv hose. Alot of blowby comes out of the pcv valve to the lower intake, making its way to the combustion chamber. Thats just as important to me.
Old 01-28-2013, 04:42 PM   #89 (permalink)
Roybatty's Avatar
Drives: kids around town
Roybatty is an unknown quantity at this point
Feedback Score: 4 reviews
OP (and other) mentioned he is changing intake to blow thru with dejon and gm maft setup. He won't have the bubble to get back in line with.
So, what would you recommend to keep vacuum? Run line from catch can to rear turbo intake tubing? Add a barb to dejon/gm maft intake?
Edit ... I see Dejon preturbo intake tubing has a nipple in it...
Dejon Pre-Turbo Intake Pipes PreTurbo Pipes 3000GT Stealth*-*Mitsubishi 3000GT*/*Dodge Stealth Parts
Roybatty is online now   Reply With Quote
Old 01-28-2013, 04:52 PM   #90 (permalink)
Always Learning
mikeyVR4's Avatar
As to add on from what Ray said. I think I will run it like this which is pretty much what forest also said.
RVC > Catch Can
Other Catch Can Port > Breather.
This will catch the oils and help my system breath like stock (as if you were using the stock pre-turbo pipes).
I am just gonna try to keep it as stock as I can since there is WAY too many opinions on what will mess up VSS and what will not.
