Old 04-22-2009, 01:42 PM   #1 (permalink)
flyintiburon85's Avatar
Drives: 96 VR4
flyintiburon85 is an unknown quantity at this point
Default Car Wont Start.....Period, Help!!!!!
after having some timing belt issues and compression issues, got the heads rebuilt rechecked the compression, it was about 135- 140PSI enough to at least start the car
after throwing everything back together, i had the PTU and coil pack replaced
The car still wouldnt start, Check the timing again, still lined up, checked spark, checked fuel pressure, checked compression and everything was good, car still wouldnt start
swapped out again the PTU and coil pack and the ETAC module, still wouldnt start check all fuses all wires everything, the only thing not checked was the cam and crank sensor could that be an issue to why its not starting
flyintiburon85 is offline   Reply With Quote
Old 04-22-2009, 02:01 PM   #2 (permalink)
Knock Knock
coreyb26's Avatar
Drives: 91 Vr4
coreyb26 is an unknown quantity at this point
Default Re: Car Wont Start.....Period, Help!!!!!
If you have fuel compression and spark on time it should start. Make sure your timing isnt 180 off.
coreyb26 is online now   Reply With Quote
Old 04-23-2009, 12:45 PM   #3 (permalink)
Drives: 96 VR4
when we set the timing there were no spark plugs in so it wasnt making any compression.....does that matter or could it still be 180 degrees off
Old 04-23-2009, 01:35 PM   #4 (permalink)
Knock Knock
coreyb26's Avatar
Drives: 91 Vr4
No it doesnt. It could still be off
Old 04-23-2009, 04:38 PM   #5 (permalink)
Zelda Freak
jonfish490's Avatar
Drives: 92 Stealth TT
jonfish490 is an unknown quantity at this point
Sorry if I'm wrong about this but I thought timing could not be 180 degrees out on any model above 92. I don't know from experience since I own a 92, but, the only thing I can think of is if the plate is installed behind the crankshaft sprocket and the connections are made to your cam and crank sensors.
Mods
4 Bolt block, Forged crank, 3SX rods, Wiseco pistons .030" over CR 8.3:1, "Ebay" FMIC, Head and Main Studs, 99 Lifters, 15G's, (ABS, AC, EGR, Cruise control) Deleted, Modified alternator belt, Fidanza Flywheel, Spec Stage 4+ Clutch, Vacuum reduction, Gutted cats, 3 inch full exhaust, Greddy Pro Spec B Boost controller, TurboXS Type H-RFL BOV, K&N Intake
Future: Carbon fiber driveshaft, Light weight wheels, 4WS delete, 550cc injectors, apexi neo, Walbro 255lph fuel pump
If you have any of the above and would like to sell, message me.
jonfish490 is offline   Reply With Quote
Old 04-24-2009, 08:57 AM   #6 (permalink)
Knock Knock
coreyb26's Avatar
Drives: 91 Vr4
You could be right about that. Curious thing is he has spark, fuel and compression thats why think he is sparking on a stroke other than the compression stroke. Time for me to check the manual. O and dont replace more stuff till you know whats wrong. Dont throw money away.
Old 04-24-2009, 09:46 AM   #7 (permalink)
No sheep are safe tonight
valhallaz's Avatar
valhallaz is an unknown quantity at this point
Having fuel pressure doesn't mean it's getting fuel. Are the injectors cycling? Is it a turbo? Are the injector resistors plugged in?
If you had spark, fuel, and compression, it would start. If you have spark and compression, then your problem is fuel.
And our plugs fire on both compression and exhaust stroke. Can't be 180 off.
valhallaz is online now   Reply With Quote
Old 04-24-2009, 10:16 AM   #8 (permalink)
Knock Knock
coreyb26's Avatar
Drives: 91 Vr4
Agreed on checking the injectors I over looked where he said pressure not pulse. Forgot about the wasted spark system. Still need to check timing with a light .
Old 04-24-2009, 02:36 PM   #9 (permalink)
Drives: 96 VR4
well i checked the fuel rail and there is definetly pressure as it bursted in my face lol.....we cranked it with the sparkplugs out and there was fuel and air coming right out so i think the injectors are working
i ran an OBD scanner and came back with a crankshaft sensor malfunction
Old 04-24-2009, 02:39 PM   #10 (permalink)
Knock Knock
coreyb26's Avatar
Drives: 91 Vr4
Maybe you installed it incorrectly, I hear its a common mistake.
