car wont idle - 3000GT/Stealth International Message Center
Old 01-04-2013, 12:05 PM   #1 (permalink)
Drives: 91 vr4
15913000gt is an unknown quantity at this point
Feedback Score: 0 reviews
Default car wont idle
I have a 91 vr4, do, bov boost controller. The car will start but refuses to idle, if I give it gas it will run, as soon as I take my foot off the gas is drops rpm and dies, instantly, like the y pipe is off. The gasket on my ynpipe was folded so I fixed that, reset the ecu. That didn't do anything. Why could this be??
15913000gt is offline   Reply With Quote
Old 01-04-2013, 12:23 PM   #2 (permalink)
^^My name is April^^
dbest671's Avatar
Drives: Spyder VR4, SRT8
dbest671 Level 2dbest671 Level 2dbest671 Level 2dbest671 Level 2dbest671 Level 2
Feedback Score: 72 reviews
Default Re: car wont idle
the isc/iac... there are at least 100 threads on this exact issue.
dbest671 is offline   Reply With Quote
Old 01-04-2013, 12:25 PM   #3 (permalink)
Drives: 91 vr4
Ohh, I'm sorry I didn't realize this was that common, I had iac issues before, cleaned it and it worked fine after that.
Old 01-04-2013, 12:45 PM   #4 (permalink)
never a dull moment
DCIV's Avatar
Drives: 93vr4 & 92vr4
DCIV Level 2DCIV Level 2DCIV Level 2DCIV Level 2
Feedback Score: 13 reviews
Could also be a massive boost leak.
Coop
Two many mods to list.
Old 01-04-2013, 01:08 PM   #5 (permalink)
dbest671's Avatar
I would do a pressure test and check the resistance on the ISC. If it is original, one of the coils probably went dead, VERY VERY common. I would say over 50% of the ISC that comes on the TBs I get have a dead coil.
Google "stealth316 ISC" it will tell you how to test the ISC resistance.
Old 01-04-2013, 01:27 PM   #6 (permalink)
Drives: 91 vr4
I did that about two months ago so it shouldn't be all that bad. I think its going to be a terrible boost leak,it could be the y pipe again, is there a secret about putting the stupid thing back on. Or is it really that terrible,never time I have to put it back non I feel like I'm having a bad dream and just hope i wake up
Old 01-04-2013, 01:36 PM   #7 (permalink)
dbest671's Avatar
Check to make sure that gasket is not ripped/torn.
Is the ISC original? I would check that FIRST because a bad ISC can destroy an ECU.
Checking the ISC takes all of 5 minutes, and you can do while you are reinstalling your y-pipe after checking the gasket for rips/tears.
Old 01-05-2013, 06:44 PM   #8 (permalink)
Drives: 91 vr4
Ibdont think its an IAC valve, the count on my blogger is changing and when I pull the mad sensor it idles, low, like 500-600rpm but none the less it idles, and dies instantly when the maf is plugged in.
Old 01-05-2013, 07:17 PM   #9 (permalink)
LeeJones27's Avatar
Drives: JDM GTO '93 TT Con'
LeeJones27 is an unknown quantity at this point
could be a bad thermistor in the maf, mine was so rusty it practically turned to dust and all i did was touch it and it snapped off, when the maf is plugged in can you drive the car or does it jerk, almost like its running out of fuel?
when it happened to mine it wouldnt idle
93 Jap Import TT 13g Conversion, Awd Aws, Adjustable FPR, 3" De-Cat Exhaust
LeeJones27 is offline   Reply With Quote
Old 01-06-2013, 04:12 AM   #10 (permalink)
Drives: 91 vr4
Nope nit backfires as soon as you come close to boost, getting it around the block to the front of my house to work non today, doing about ten, accelerating to 15ishnto shift to second since I hate cruising in first,MIT backfired like sixntimes
