Car won't boost just removed from hibernation - Page 3 - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 06-15-2017, 04:15 PM   #21 (permalink)
Canadianboost is an unknown quantity at this point
Feedback Score: 0 reviews
Default Re: Car won't boost just removed from hibernation
Just an update I've killed all the leaks now.
I tested the wastegates under pressure and they start to open around 8psi
So then I put my vacuum pump on the wastegates and under vacuum I can pull 14 psi in 2nd gear. So to remedy should I pull the turbos and inspect the internet parts of the wastegates or just try and adjust the rods the front seem to be held firmly shut but the rear is obviously hidden. Has anyone successfully adjusted the rear without pulling it out?
Canadianboost is offline   Reply With Quote Quick reply to this message
Old 06-16-2017, 11:12 AM   #22 (permalink)
Super Duper Mod
lawdogg's Avatar
Drives: deals
lawdogg Level 3lawdogg Level 3lawdogg Level 3lawdogg Level 3lawdogg Level 3lawdogg Level 3lawdogg Level 3
Feedback Score: 109 reviews
I wonder if anything is rusted seized from sitting so long? Might be worth it to pull them and check everything out ... but then, that's a lot of work.
Originally Posted by GTO Assassin View Post
Originally Posted by ray pampena View Post
Cant we all just smile and get along?
No!
lawdogg is offline   Reply With Quote Quick reply to this message
Old 06-16-2017, 10:01 PM   #23 (permalink)
Definitely going to pull them. Hopefully they just need cleaning. Any other suggestions would be greatly appreciated
Old 06-19-2017, 05:21 PM   #24 (permalink)
Soo whomever put on the hyper medallion exhaust didn't remove the rear precat and no light shines thru it. So I'm hoping hollowing this will fix my low boost problem. Also the rear wastegates looks good and closed tight.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
Random Question
