Car won't boost just removed from hibernation - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 06-12-2017, 07:42 PM   #1 (permalink)
Canadianboost is an unknown quantity at this point
Feedback Score: 0 reviews
Default Car won't boost just removed from hibernation
92 stealth won't boost past 5psi
40000kms stored for 10 plus years
Only recently driven for 40kms
New fuel filter
New coils and wire
New plugs
Timing adjusted to 5 with timing wire grounded
Leak tested found some and fixed
Turbos spin freely
Tried stock and manual boost controller
Both wastegates move when air pressure added
Aluminum y-pipe intake with hks Bov
Any other ideas/experiences appreciate
Canadianboost is offline   Reply With Quote Quick reply to this message
Old 06-12-2017, 08:19 PM   #2 (permalink)
Super Duper Mod
lawdogg's Avatar
Drives: deals
lawdogg Level 3lawdogg Level 3lawdogg Level 3lawdogg Level 3lawdogg Level 3lawdogg Level 3lawdogg Level 3
Feedback Score: 109 reviews
Default Re: Car won't boost just removed from hibernation
Factory boost gauge or aftermarket?
Assuming aftermarket. What happens if you pull the wastegate hose? That'll get the boost controller out of the equation. 5psi is around wastegate pressure of 6psi (iirc).
Originally Posted by GTO Assassin View Post
Originally Posted by ray pampena View Post
Cant we all just smile and get along?
No!
lawdogg is offline   Reply With Quote Quick reply to this message
Old 06-12-2017, 08:34 PM   #3 (permalink)
Aftermarket gauge
I've tried unhooking the wastegates and no runaway boost still the same
Old 06-12-2017, 08:39 PM   #4 (permalink)
Super Duper Mod
lawdogg's Avatar
Drives: deals
Huh, and it runs with the MAS plugged in? What happens if you unplug the MAS? Seems like a massive boost leak, or a massive exhaust manifold leak, or a pair of seized wastegates which you checked. Are they stock turbos?
Old 06-12-2017, 09:31 PM   #5 (permalink)
I will test for Boost​ leaks again. When I tested I did both turbos tracts seperatly with no y-pipe should I do it thru the mas instead and plug it at the TB.
Also what will.happen if I unplug the MAS what r you thinking​ it's reaction will be. Am I just testing MAS off at idle or driving?
Old 06-12-2017, 10:13 PM   #6 (permalink)
StealthyRT's Avatar
Drives: 92 RT/TT & 91 SL
StealthyRT is an unknown quantity at this point
Feedback Score: 10 reviews
If you unplug the MAF it will go into limp mode, if it runs okay, then your MAF is shot.
What happens when you hit 5psi?
Does it buck, and misfire?
You should be leak testing right after the MAF, and pressurize the whole system to make sure you find any leaks.
-Shane
"$1,000,000.00 ONE MILLION DOLLARS. TURBO LEGENDS NEVER DIE." -alldaysteve1
1992 Stealth TT
Rebuilt Motor, Test Pipe. Obx Down Pipe, Gutted Pre-Cats, Poly Mounts, EGR delete, Walbro 255, Greddy type-s, Profec B spec II, Tein S-Tech Springs, 3sx Pre Turbo Pipes, B&M 11x10 Oil Cooler, 99 Lifters, Forged 93 Crank, 3sx lightweight pully, GM 3" maf w/ MAFT, 98sl Flashable ECU, 550cc Delphi Injectors
1991 3000gt SL ATX swapped to MTX
Rebuilt Motor, 99 Lifters, Prothane Engine mounts, Test Pipe, 3SX STS, ̶t̶r̶a̶n̶s̶l̶a̶b̶ ̶s̶h̶i̶f̶t̶k̶i̶t̶, TT Plenum, intake resonator delete, 3SX Light Weight Flywheel, TT 1G Brakes, Clutch Damper Delete, Eibach 2810.140 ECS Lowering Springs
2003 SVT Focus - SOLD FINALLY
WTB:
StealthyRT is online now   Reply With Quote Quick reply to this message
Old 06-12-2017, 10:27 PM   #7 (permalink)
It actually runs really smooth all the way to redline even on boost. So I will boost even without MAS.
So I do or don't plug at the TB for pressure test?
Turbos are stock...
Old 06-13-2017, 08:46 AM   #8 (permalink)
StealthyRT's Avatar
Turbos are stock...
If its running smoothly its probably not a boost leak or MAS... Very strange though, maybe you have a plugged cat?
Old 06-13-2017, 11:58 AM   #9 (permalink)
Default
Cat looked visibly good mostly white but I could hollow it out if that might make a difference
Old 06-13-2017, 01:41 PM   #10 (permalink)
^^My name is April^^
dbest671's Avatar
Drives: Spyder VR4/SRT8/CTSV
dbest671 Level 2dbest671 Level 2dbest671 Level 2dbest671 Level 2dbest671 Level 2dbest671 Level 2
Feedback Score: 92 reviews
Turbos are stock...
do not plug the TB
dbest671 is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
Random Question
