Old 05-12-2008, 07:18 AM   #1 (permalink)
pearlyellow's Avatar
Drives: 2002 acura mdx
Trader Rating: (6)
pearlyellow is an unknown quantity at this point
Default car cranks no start mechanic forum members needed
ok I have a 96 eclipse GST 16g, I know this isnt a 3s but the dsm forums suck and ive been on here for a couple of years.
the car cranks and wants to start. If I spray carb cleaner in the intake mani it will run for 10-15 seconds and starts.
so far I have replaced
fuel fliter, pump, fuel regulator, plugs, I have checked the injectors for resistance, the pump relay,coils, wires and ive checked the grounds
things I think it could be are
coolant temp sensor
cam sensor
crank sensor
ecu
My thoughts were if the car starts with carb cleaner if it was a sensor or ecu problem the car wouldnt start and run at all. Im lost with this car any help would be great ive done a alot of searching.
pearlyellow is offline   Reply With Quote
Old 05-12-2008, 07:24 AM   #2 (permalink)
Trader Rating: (6)
Default Re: car cranks no start mechanic forum members needed
compression test is 147-151 across
Old 05-12-2008, 08:51 AM   #3 (permalink)
stans3000gt's Avatar
Drives: 1992 VR-4, 1993 SL
stans3000gt Level 1stans3000gt Level 1
Try pulling the injectors out and have someone crank the engine over a few times to see if they are spraying fuel out (keep them away from our face). Also check to make sure that the timing is fine. One more thing I can think of right at this moment is the crank or cam sensors try to get good one from a friend or test the existing one. Last few things, just check for small mistakes are the spark plug wires in order, pull the plugs out and see what they look like after you tried cranking it a couple times.
Is the car cranking easily or does it seem out of timing and it pauses after a few cranks?
stans3000gt is offline   Reply With Quote
Old 05-12-2008, 10:31 AM   #4 (permalink)
Trader Rating: (6)
car cranks smooth and runs with carb cleaner so I think its fuel related, the plugs are dry and have spark. I'm gona buy a crank and cam sensor and install. I will post results if anyone else has any ideas please post, thanks for the input I'm going to pull the rail and see if the injectors are spraying.
Old 05-12-2008, 11:26 AM   #5 (permalink)
Master Of Disaster
Gray Haze's Avatar
Drives: 3S's Since Feb 2002.
Trader Rating: (25)
Gray Haze Level 3Gray Haze Level 3Gray Haze Level 3Gray Haze Level 3
ECU wont spark without crank/cam signals.
Have you checked to see if you have power at the injectors?
Checked to see if the fuel pump is running ?
1992 3000GT VR-4 #15 of 24. The ORIGINAL Sandstone Gray '99 Conversion.
A slow strangle with your feet on the floor.
www.3stech.org - Now with 100% less invite codes! Free Registration!
Gray Haze is offline   Reply With Quote
Old 05-12-2008, 11:39 AM   #6 (permalink)
never a dull moment
DCIV's Avatar
Drives: 92 VR4
Trader Rating: (12)
DCIV level 6DCIV level 6DCIV level 6DCIV level 6DCIV level 6DCIV level 6
Check to make sure all your grounds are good. I had a problem with a honda like that and it was my grounds.
Coop
To many mods to list.
