Old 09-22-2006, 09:26 AM   #1 (permalink)
JiNGlEsS1DeR's Avatar
Drives: 93 3000gt base
Trader Rating: (10)
JiNGlEsS1DeR is an unknown quantity at this point
Default boost controller?
HI, just wondering if you guys have any recommendations on an electronic boost controller that doesnt have boost spikes and is user friendly (just put in amount of boost you want)? Does any other ebc display the boost guage in psi beside the greddy profec b spec 2? How about the blitz dsbc? Thanks for the help all.
Hung Nguyen
- Hung N.
best time - 15.563 @ 90.64mph
go-atx-mtx conv. intake arm,intake filter,borla exhaust, underdrive pulley,topline engineering ground wires, jet performance ecu,
show-eibach springs,snake eyes,push button start
to be installed: safcii, gtech, testpipe
to be bought: decent clutch,datalogger w/m515, paint job
JiNGlEsS1DeR is offline   Reply With Quote
Old 09-22-2006, 09:35 AM   #2 (permalink)
Twin Power Pellets
pacman3000gt's Avatar
Drives: 94 Mitsu 3000GT VR4
pacman3000gt is an unknown quantity at this point
Default Re: boost controller?
Blitz DSBC is probably the best at handling boost spikes... but you must set the gain/ratio... you can't just put in a boost value.
I'm not sure about the newer ones though... the Blitz -ID versions or the newer Greddy profecs might have modules smart enough to handle it.
But regardless, It's not too hard to set the boost manually. So I wouldn't be too concerned with it. Is this for a friend? or are you trying to buy TT parts for your car for a conversion?
1994 Mitsubishi 3000gt VR4 - Black
AEM EMS | 700cc | Big16G | JPDC TD05 plates | FMIC | SouthBend DXD-F/UR Aluminum Flywheel | Blitz DSBC | Tanabe Hyper Medallion | Volk Racing LE37T | BFG KDW2 | R1Concepts Rotors
pacman3000gt is offline   Reply With Quote
Old 09-22-2006, 09:53 AM   #3 (permalink)
Trader Rating: (10)
its for my brother's vr4. also, has anyone tried the aem boost controller that just looks like a guage? thanks for the reply
Old 09-22-2006, 09:53 AM   #4 (permalink)
Racing
Barefoot's Avatar
Drives: 92R/T - converted ;)
Trader Rating: (31)
Barefoot Level 3Barefoot Level 3Barefoot Level 3Barefoot Level 3
The only unit I know of that displays PSI is the spec2, but I have not had much experience with any others.
Other than that, Its not so much a boost controller as a standalone unit, but the boost control feature of the Maftpro is very nice. Displays/logs PSI and allows you to simply enter desired PSI.
If I had to go back to a standalone unit, I would either get the profec B spec2, or the DSBC.
92 Dodge Stealth R/T AWD/TT (TD05) converted ( 11.894 @ 120.56 - 18 psi -> Video )
Barefoot is offline   Reply With Quote
Old 09-22-2006, 10:12 AM   #5 (permalink)
Slowest 3/S in chicago
DaveSlow's Avatar
Drives: 93 Black VR-4
DaveSlow Level 2DaveSlow Level 2DaveSlow Level 2
HKS EVC V also can read in psi depending on which model you buy. One reads in Kpa and the other in Psi. As for boost adjustment it's as easy a turning a dial.
DaveSlow is offline   Reply With Quote
Old 09-22-2006, 01:52 PM   #6 (permalink)
Since May 2002
EricVR4's Avatar
Drives: 92 VR4/05 Accord
Trader Rating: (25)
EricVR4 is an unknown quantity at this point
I have the SBC-id III and it can show it in psi, as well as a few different other values. Like the DSBC though, you have to set your boost with the set/gain, you can't just dial in "15psi" and leave it....that's my only complaint about the -id. The psi is different for each gear...I'll get one or two less psi in first and second than I will in 3rd and up since it's a ratio, but oh well. It's extremely easy to change though, and has 4 different channels you can use, that way you don't have to mess with finding the right ratio while you're driving, you just change the channel. I have one for wastegate pressure and one for around 1 bar, I don't use the other two for now.
It also fits perfectly in the a/c vent too....
Sold
13Ts | DSM SMICs | LS1 maf/maft | NBT OS/Spool | + lots of others
EricVR4 is offline   Reply With Quote
Old 10-26-2006, 12:48 PM   #7 (permalink)
USMC
vr4_rider's Avatar
Drives: '93 Vr4; '06 675cc
Trader Rating: (11)
vr4_rider is an unknown quantity at this point
hey, eric...can you get a closer pic of your boost controller in that vent?
So, with the greddy Spec II, you can just dial in the psi you want?
And with the MAft Pro, it comes with a boost controller?
Thanks,
T
Trung [1993 Pearl Black VR-4]
Appearance//1999 Front end//ground controls w/ adj. rear control arms//18x9 5Zigen 5ZR wrapped in 245 front, 275/35/ZR18 Falkens//DR Racing Black lugnuts
Mods//GReddy EBC Spec-II//Greedy Type-S BOV//Unorthodox UD pulley//ATR Downpipe//IPS Single Shot Magnaflow//255 Walbro pump//GReddy Profec Spec II EBC//JET tuned ECU//AutoMeter Boost gauge//HKS Turbo Timer//Gutted Hi-Flow DynoMaxx CC//Vac Reduction//EGR Block off//PRO-M 80mm MAS and MAF-T Tuner//EVO 8 560cc injectors //Shriver's datalogger
Turbos: 13Tx2
Current Problem(s): Cherries in the rear view mirror
In the Process: Nothing
Want to Trade/Buy: Cams and springs, non-OEM clutch and flywheel...
vr4_rider is offline   Reply With Quote
