Re: Biss leak
Well i removed the TB and found the gasket to be on wrong and fixed that. That leak went away. I also tightened all the IC pipes,and switched out/greased the O-ring on the rear turbo. I still have the strange hooting/choo choo noise. If i go WOT i don't hear it, but if i add partial throttle it fluctuates, getting higher in pitch as rpms and boost builds. Also when the BOV does goes off it sounds alot more high pitched and audible than it did before. I plan on pressure testing as soon as i get home to my compressor. but that wont be until Wednesday.
