Old 07-10-2008, 06:39 PM   #11 (permalink)
GTO2Stealth
freakosaurus's Avatar
Drives: GTO, Civic
freakosaurus is an unknown quantity at this point
Default Re: Before I light my car on fire
I replaced the bad caps on my ecu last weekend. they had leaked. I took electronics engineering technology in college so i am pretty sure that it works.
the cas wiring looks to be ok and i am definitely getting spark.
what is the plug on on the bank of 3 that attaches to the intake plenum nearest the firewall? (the plug closest to the firewall) I had to replace that connector. The wire appears to bugger off somewhere down on the other side of the rear head...
freakosaurus is offline   Reply With Quote
Old 07-11-2008, 11:45 AM   #12 (permalink)
GTO2Stealth
Drives: GTO, Civic
UPDATE:
upon closer inspection lest night after cranking, I found a little bit of oil coming down from my oil cap and when i took it off there was a little bit of smoke (burnt/unburnt gas). There was a faint smell of gas in my oil. Could this just be from too many attempts at cranking or is this blowby indicating bad compression? i'm getting a compression tester tonight.
Old 07-11-2008, 12:07 PM   #13 (permalink)
Senior Member
defgh1's Avatar
Drives: 99 VR4, 04Volvo V70R
Trader Rating: (9)
defgh1 Level 3defgh1 Level 3defgh1 Level 3defgh1 Level 3defgh1 Level 3defgh1 Level 3defgh1 Level 3defgh1 Level 3defgh1 Level 3
Originally Posted by freakosaurus View Post
UPDATE:
Most likely from multiple start attempts but compression test is good idea. The rear connector you was asking about is most likely for the Throttle position Sensor.
Doug H
91 Sandstorm TT, 431 AWHP, 433 ft-lbs. , Kormex 25 spline,LSD, RPS CC Clutch, 4 bolt conversion, Super 15Gs, Stage 3 heads, DSM Sidemounts, PST Driveshaft, Blitz DSBS, HKS Exhaust, 3SX Downpipe, Supra Pump, 780 cc PTE Injectors, SX Fuel reg. & dual feed, AEM, Duel WJO Wideband, HKS DL1, Alcohol Injection. Photos: -->
defgh1 is offline   Reply With Quote
Old 07-11-2008, 01:19 PM   #14 (permalink)
GTO2Stealth
Drives: GTO, Civic
Ok, well i'll post the results tonight. I'm looking for about 156 on my RT yes?
Old 07-11-2008, 01:36 PM   #15 (permalink)
Forum user
Monster Stealth's Avatar
Drives: 93 VR4 & 99 A4 1.8T
Trader Rating: (32)
Monster Stealth Monster Stealth Monster Stealth Monster Stealth Monster Stealth Monster Stealth Monster Stealth Monster Stealth Monster Stealth Monster Stealth Monster Stealth
Have you done a pressure test. When I rebuilt my engine i had a huge vac leak where manifold was not seating with the lower portion bc the rear bracket I used to pull the motor was bent a little. After I tightened that down it fired right up.
9B+93-13.2@108
GT368+E85...Summer 2009
the cake is a lie
Monster Stealth is offline   Reply With Quote
Old 07-11-2008, 01:42 PM   #16 (permalink)
GTO2Stealth
Drives: GTO, Civic
lol how do I do a pressure test?
Old 07-11-2008, 01:50 PM   #17 (permalink)
Senior Member
defgh1's Avatar
Trader Rating: (9)
Stealth 316 - Intake pressure tester
Old 07-11-2008, 02:13 PM   #18 (permalink)
GTO2Stealth
Drives: GTO, Civic
thanks, I think that I may have to do this if my compression test comes out good.
Old 07-11-2008, 05:54 PM   #19 (permalink)
Drives: 1992 Stealth RT/TT
khanike is an unknown quantity at this point
on other thing, i know you said the cams were in right, however, if you loosen the exhaust at where it connects to the turbos(front and back) and the car starts, then cams on the front head are reversed, the car will run(badly) and the intake will get hot right away. I know this from experience but if you switch them back all will be well (was for me anyway), it's worth checking into before you light the poor thing on fire.
khanike is offline   Reply With Quote
Old 07-11-2008, 06:02 PM   #20 (permalink)
My N/A is faster.
windsma's Avatar
Drives: BMW
windsma is an unknown quantity at this point
FIRE!
Originally Posted by GenericVR4owner View Post
Just get a vr4 and be done with it.
windsma is offline   Reply With Quote
