Hey guys was wondering what your settings were what cut you used and such mine are as follows and i can only get like 3-4lbs of boost any help would greatly be appreciated.
2 step medium cut
alt spark trim -40 degrees
alt fuel trim 0%
alt off above 8500 rpm
alt on above 4000 rpm
alt on above -2 psi
alt off below 60.2 TPS
alt on above 65% TPS
Alt overboost 15psi
two step settings are:
fuel cut 7500
ignition cut 5000
2 step medium cut
alt fuel trim 0%
alt on above -2 psi
Alt overboost 15psi
fuel cut 7500
ignition cut 5000
