Abs Light On? - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 10-03-2005, 10:12 AM   #1 (permalink)
Drives: 1995 Stealth RT/TT
NeedPower is an unknown quantity at this point
Feedback Score: 1 reviews
Default Abs Light On?
Hey Guys....
Light won't go off. I changed the fuse located under the hood, was hopign that would do it.
Any ideas what else I can do to get the light off---have you guys heard of this before?
Tks for any inputs!
Tyson
95 RT/TT Stocker
NeedPower is offline   Reply With Quote Quick reply to this message
Old 10-03-2005, 10:42 AM   #2 (permalink)
sabastian458's Avatar
Drives: 92 VR4 & 03 Evo GSR
sabastian458 is an unknown quantity at this point
Feedback Score: 2 reviews
Default Re: Abs Light On?
have you checked to pump for cracks or leaks? my integra had a leak and caused the light to come on. on my 3000gt my light came on and all i did to get it to go away was turn the car off and start it back. does yours stay on all the time?
sabastian458 is offline   Reply With Quote Quick reply to this message
Old 10-03-2005, 10:52 AM   #3 (permalink)
Official Member
BjornRune's Avatar
Drives: The big whale
BjornRune is an unknown quantity at this point
Feedback Score: 8 reviews
Could be the abs speed sensors in the hubs too.
Black 1994 VR-4
Green 1994 VR-4
Blue 1998 GTO MR
Green 1994 VR-4
15G's, AEM EMS, 550's and the lot.
Originally Posted by 05SDI
The good news is I need a new motor
BjornRune is offline   Reply With Quote Quick reply to this message
Old 10-03-2005, 11:24 AM   #4 (permalink)
IM OLD SCHOOL
SunDown13X's Avatar
Drives: A Racing Machine!!!
SunDown13X Level 3SunDown13X Level 3SunDown13X Level 3SunDown13X Level 3SunDown13X Level 3SunDown13X Level 3SunDown13X Level 3
Feedback Score: 11 reviews
have you tried resetting the code? unplug battery for a few mins... the plug back in... that fix my problem a few months ago... (my car loves to piss me off LOL)
Car of the Month May 2007////1994 Mitsubishi 3000GT VR4 - Sold & forever missed
Originally Posted by RidinSealth93
ok so im a stupid ricer cause i cut my springs.. when they go ill replace em. its not bad advice, he said cheap, so i told him cheap. mine have been cut for over a year and i have no problem. oh and btw, YOUR A PRICK! pull the stick out of your ass..
SunDown13X is offline   Reply With Quote Quick reply to this message
Old 10-03-2005, 11:50 AM   #5 (permalink)
LS...+1
Drives: 2002 Corvette
HARD DRIVER is an unknown quantity at this point
Feedback Score: 3 reviews
If the abs motor (located behind and to the side of the passenger headlight ass.,)runs after the car is cut off, your abs motor could be stuck on. Mine had that happen (sounds like a buzzing after car has been cut off), I tapped it a few times with a screwdriver and it went off and hasn't done it since approx. 3 months ago.
2002 Corvette 2002 Mustang GT
HARD DRIVER is offline   Reply With Quote Quick reply to this message
Old 10-03-2005, 11:59 AM   #6 (permalink)
Member: Burned valve club
cbatters's Avatar
Drives: 91 Stealth RT/TT
cbatters is an unknown quantity at this point
Feedback Score: 12 reviews
Advise exactly when the ABS light turns on. (does the light stay off until you start driving?)
ABS control module does some diagnostics when ignition is turned (relays / contiunuity / fuses) but waits to test the HU until after the car is moving.
Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone
Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side)
Overhauled: Starter, IAC, BISS, CV Boots
Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!)
A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger
Pending Projects: Steering Rack
Best Auto Insurance | Auto Protection Today | FREE Trade-In Quote
cbatters is offline   Reply With Quote Quick reply to this message
Old 10-03-2005, 12:01 PM   #7 (permalink)
IM OLD SCHOOL
SunDown13X's Avatar
this happen to me also... but it was fix'd after I had unplug'd the batt.
Old 10-03-2005, 12:06 PM   #8 (permalink)
cbatters's Avatar
Motor stuck on is almost always the power relay. Easy to replace but a bit expensive ($125) MUCH easier than replacing the HU.
Clint
Old 10-03-2005, 12:50 PM   #9 (permalink)
Thanks for all the feedback guys...I love this board.
TO answer a few of the questions:
(1) No noise after I turn off the car
(2) The light comes on with a slight flicker right after I start the car.
It stays on solid the whole time I am driving it.
I will try to unplug the battery---acutally had it unplugged a few months ago
when it died etc...and this is when it started acting up (or soon thereafter). Hopefully this will fix the problem.
Is the motor close to the fuse for the ABS? Just windering what it looks like, how I might know it is the ABS motor.
Thanks again,
Tyson
Old 10-03-2005, 12:55 PM   #10 (permalink)
cbatters's Avatar
Thanks again,
Tyson
Please confirm that the ABS light stay on even if you never move the vehicle. (Points to connnector/rela/sensor problem, not HU motor which is tested after the vehicle starts moving)
Clint
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
