91 tt. I need help. Think my ecu is bad - 3000GT/Stealth International Message Center
Old 11-13-2012, 02:32 PM   #1 (permalink)
Haha0624 is an unknown quantity at this point
Feedback Score: 0 reviews
Default 91 tt. I need help. Think my ecu is bad
I bought my car a few months ago. It was running very good then last month my car started bucking and idling rough but it would only do it for a minute or two and then be fine... Now it's rough idle and runs on only 4 cylinders.. I did the good old volt meter to check ecu codes.. I got a 53 no fire on 3&6, ptu bad, check wire harness... I opens the ecu and found no blown caps just one that was loose. So I threw some soldier on it. Fixed the car for about 30seconds and it went back to shit. At the same time I notice the ecu had already been remand. Now even when I put new caps in the ecu the car still runs like shit.
Is there anyone in Illinois that has a known good ecu that I could borrow.i could pay alittle money to rent it.
Any other help would be greatly appreciated. Thank you
Haha0624 is offline   Reply With Quote
Old 11-13-2012, 02:51 PM   #2 (permalink)
Busted Knuckle Garage
Hot943kGT's Avatar
Drives: 91 RT/TT
Hot943kGT is an unknown quantity at this point
Feedback Score: 1 reviews
Default Re: 91 tt. I need help. Think my ecu is bad
Hey, disconnect the ECS controller and see if it runs right. Ecs controllers go bad like ECUs do and send bad signals to the ECU.
Dave
91 Stealth TT- Pampena Stage 2 short block, rebuilt heads, Solid mounts, MBC, Vac reduc, hotwired FP, Blitz FATT, 4.5" FIPK, TurboXS BOV, Stainless Downpipe, Race pipe, Borla exhaust, AHDS, 500 lb clutch, JDM 25 spline 5 spd/tcase, Short Shifter, EVO leather knob, 18" Mazdaspeed wheels, Front Splitter, in dash touch screen bluetooth/navigation/DVD...
94 3000GT DOHC Base -nitrous express proton series w/ upgraded solenoids, Robomods, dash mounted datalogger, in dash touch screen navi w/bluetooth, IPT end clutch, high performance trans cooler, Translab shift kit. (could not afford to repair after crash) SOLD
DD = 99 Jeep XJ -white (stock for now)
Hot943kGT is offline   Reply With Quote
Old 11-13-2012, 02:58 PM   #3 (permalink)
It's already disconnected and I have a new ptu..
Old 11-13-2012, 03:38 PM   #4 (permalink)
Hot943kGT's Avatar
Drives: 91 RT/TT
The only other thing I can think of off the top of my head that made my car run as you describe was the fuel relay. It gets corroded and the fuel relay ends up sending a weak signal to the fuel pump and in turn your car runs like a heap... If I can remember anything else, I will chime back in...
Old 11-13-2012, 03:49 PM   #5 (permalink)
Country Twin Turbo
Nater3kgtVR4's Avatar
Drives: 91VR4 - CNTRYTT
Nater3kgtVR4 is an unknown quantity at this point
Feedback Score: 14 reviews
I agree, Check the MFI relay on the interior passenger side of the center console. Also Check all your fuses that is usually square one.
1991 VR4 - TD04-19THL, DR Stg3 heads, All forged lower end, Adj. Cam gears, Boost Exh. cutout, Walbro 341 HW'd, 720cc inj., AEM FPR, Hallman MBC,
Clone ECU and Chrome V2 - Tuning for 20-PSI on 91 Pump at the moment
Nater3kgtVR4 is online now   Reply With Quote
Old 11-13-2012, 08:09 PM   #6 (permalink)
The Mfi relay deals with the injectors.. How would that cause no spark to 3&6. If I remember correctly the last time I did a volt check on the #11 pinout on my ecu I got little to no voltage even when getting the rpms up to 3000.. I am just lost.. There was a time when I had the ecu plugged in to the car with the cap off and I could wiggle or even hold one of the capasitors a certent way and the car would try to run better
Old 11-13-2012, 08:16 PM   #7 (permalink)
Super Duper Mod
lawdogg's Avatar
Drives: at half throttle
lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2
Feedback Score: 93 reviews
Sounds like a bad driver on the circuit board. Get in touch with rymer21280, he is the ECU man.
Old 11-13-2012, 08:26 PM   #8 (permalink)
I'm half tempted to just eat some money and get the vr4 clone ecu... Does anyone think that would be a mistake on my part
Old 11-13-2012, 11:02 PM   #9 (permalink)
Super Duper Mod
lawdogg's Avatar
What is the VR4 clone ECU?
Old 11-14-2012, 12:44 AM   #10 (permalink)
CHRIS75's Avatar
Drives: 93 3000GT VR-QUATTRO
CHRIS75 is an unknown quantity at this point
Feedback Score: 24 reviews
Do this man specially by the symptoms you describe. He has worked on many of our ecu's, really great, fast and low cost too.
Sometimes caps can look good but they may be already messing around.
Originally Posted by blizzy View Post
he was probably used to driving his civic and he punched 2nd hahahahaha
F1 ... Where Nascar & Indi Drivers Dream To Compete
Welcome Back Michael.
CHRIS75 is offline   Reply With Quote
