Old 05-07-2008, 07:00 AM   #11 (permalink)
Forest Gump
cbehnken's Avatar
Drives: 1992 Stealth TT
Trader Rating: (42)
cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7
Default Re: 3SX TD05 Kit Install/Progress
if you pull the oil returns and crank the motor with the ECI fuse pulled it will prime the engine.
Engine off = no exhaust to turn the turbo, but engine cranking = oil pressure. Crank it until oil comes of the returns and you are golden.
cbehnken is offline   Reply With Quote
Old 05-07-2008, 09:36 AM   #12 (permalink)
Moderator
TooFast4Radar's Avatar
Drives: The real 94/96/99
TooFast4Radar Level 7TooFast4Radar Level 7TooFast4Radar Level 7TooFast4Radar Level 7TooFast4Radar Level 7TooFast4Radar Level 7TooFast4Radar Level 7TooFast4Radar Level 7TooFast4Radar Level 7TooFast4Radar Level 7TooFast4Radar Level 7
That's exactly what I do, too. It's the easiest way to prime the oil system and it takes literally seconds to do.
- 94 R/T Turbo
- 93 VR-4
- 94 R/T
TooFast4Radar is offline   Reply With Quote
Old 05-07-2008, 07:33 PM   #13 (permalink)
streamlnauto's Avatar
streamlnauto is an unknown quantity at this point
Originally Posted by thaichops View Post
I'm in the process of doing the same install. But I have run into a small road block with the coolant lines. Would you mind giving me a little insite as to what you you used and where you got the materials for you coolant lines?
I used -6 nylon braided line, 4 90 degree fittings, and 4 -6 to M14 adapters. I got it all locally but Summitracing.com is a great place to get what you need, I recommend the summit brand fittings because they are about 1/2 the price of earls or russel fittings, I probably spent $180 making the damn lines lol, if I were more patient I could have done it all for around $100 with the summit fittings.
Its really not that hard to do, I recomment the nylon braided stuff over the stainless braided because its easier to work with, just don't have it touching the hot side of the turbo, it will slip onto the stock coolant nipples, use some little stainless worm gear clamps and you are good.
The rear turbo on the side nearest the engine is the hardest one because there are clearance issues, I am not happy with the way the line rests so I am going to use a custom banjo bolt like these.
On the same site has the m14 adapters I used as well.
14mm Alum. Banjo To 1/4 Fitting Kit ( coolant , oil , fuel ) - $19.97 : Himni Racing, Turbocharger, Turbo, Garrett, Turbo Kit, GReddy, Mazda RX-7, HKS, Apexi, TiAL, TurboXS, TurboSmart, Flange, Turbonetics, Exhaust, Intercooler, ACT, Intake
streamlnauto is offline   Reply With Quote
Old 05-07-2008, 07:41 PM   #14 (permalink)
Originally Posted by gltasn View Post
make sure you prime your turbos before you start them. i noticed your oil line installed allready. i would remove and add oil. it will take an hour but it will start to go into turbo and you can add more. do this 3 times before starting. i even took a tube(heater hose) and put one end around oil inlet and blew into hose to force oil into turbo. if you dont you could seize turbo upon start. j sin
I did pre oil my turbos. By the time the engine is primed there will be plenty of lubrication throughout the system.
I always pull my crank and cam angle sensor harness so there is no spark / fuel during the priming stage, pretty much the same thing.
Old 05-07-2008, 07:43 PM   #15 (permalink)
Originally Posted by Import Power View Post
Don't run any
If you can, why not? It will only prolong the life of the turbo, as well as help to keep the cold side temps down.
Old 05-08-2008, 03:46 AM   #16 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (210)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
you can, won't hurt anything
But many people, including myself, have run them for long periods of time with no coolant lines with no ill effects
AEM Factory Trained Tuner
91VR4 Black-5027s-3.0L-Stock heads and Cams- 770AWHP 670AWTQ uncorrected 33psi E90 Daily Driver
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Old 05-08-2008, 04:10 AM   #17 (permalink)
Master Of Disaster
Gray Haze's Avatar
Drives: 3S's Since Feb 2002.
Trader Rating: (26)
Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7
use a 9/16ths banjo hose end, and then the correct m14 banjo bolt. Seals up fine.
1992 3000GT VR-4 #15 of 24. The ORIGINAL Sandstone Gray '99 Conversion.
Personal Rate of Return from 01/01/2008 to 10/09/2008 is -50.8%. Forget early retirement for sure.
www.3stech.org - Now with 100% less invite codes! Free Registration!
Gray Haze is offline   Reply With Quote
Old 05-08-2008, 08:01 AM   #18 (permalink)
VR4Drive92's Avatar
Drives: Black VR4
VR4Drive92 Level 5VR4Drive92 Level 5VR4Drive92 Level 5VR4Drive92 Level 5VR4Drive92 Level 5VR4Drive92 Level 5
I always poor oil into the turbo before the first start.
Even when you are turning the motor over, the shaft still spins. Granted, it does not spin at a high rate of speed compared to the normal operational condition but it does spin.
But if pressed for time, then the other method will do just fine.
May the Boost be with you....
Look me up on Forza 2 Motorsports Live : A BAD 9 YEAROLD
._________________________
|.....Overnight.....................| ||
|........Japan Parts................||'|";,___.
|_..._...____________======||_|_|...,]
VR4Drive92 is offline   Reply With Quote
Old 05-08-2008, 01:35 PM   #19 (permalink)
Well, a long period of time is not a matter of a couple years imo, I would say long term would be 30-50k miles or more, I would just say they built them with coolant passages for a reason, it would be interesting to do a dyno pull on the same car with and without coolant lines, I would bet the intake charge would be a bit cooler with than without.
Old 05-08-2008, 03:35 PM   #20 (permalink)
air never passes thru the chra
your chra would have to be substantially hotter to dissapate enough heat into the comp housing to effect dyno numbers. And I don't see that happening.
