Old 05-09-2008, 08:15 PM   #21 (permalink)
Never finished
1viciousVR4's Avatar
Drives: Nowhere Fast
Trader Rating: (28)
1viciousVR4 is an unknown quantity at this point
Default Re: 3SX TD05 Kit Install/Progress
In your 1 pic, the stud sticking off the bottom of the precat that bolts to the down pipe....did those exhaust studs come with your kit? If not what size are they cause I need them for my rear precat and am not sure of the size thanx...
Originally Posted by streamlnauto View Post
Figured I would do a write up as I go about installing this kit.
First off, got the kit, everything looks great, I did a quick mock up install of all the parts before coating and everything lined up right the first time.
I then had the manifolds Jet-hot coated with their extreme sterling coating 1700 degree stuff.
For a little added strength I custom made a bolt on brace for the rear, I am going to do something similar on the front manifold by modifying the factory turbo manifold stay bracket as well. A little added security never hurts!
Note: For the rear manifold, one of the studs needs to be shortened by about 1/2" to clear the manifold, pretty easy to do with a cut off wheel, be sure to leave a nut on the stud before you cut it so that when you remove it it will de-burr the threads.
More to come later- waiting on valve covers and some replacement lifters before I go any further.
99 Chevy Silverado 2500
93 3000GT VR4
So far: 3sx TD05 E16g Turbo Kit, polished Greddy FMIC with IPS tdo5 extensions, Poopra pump, 3sx pulley, MSD wires, NGK coppers, Maximal powdercoated valve covers, polished plenum, Tial Q bov, Hallman Pro RX MBC, Maximal solid mounts, Maximal test pipe, JIC catback, Tein s-techs, Mod-Express 8k HID, Nelson TC bracket, PST CFDS, Fidanza flywheel, RPS Max street, Deft CF hood.
Still Need: AEM EMS, injectors.
1viciousVR4 is offline   Reply With Quote
Old 05-09-2008, 11:23 PM   #22 (permalink)
streamlnauto's Avatar
streamlnauto is an unknown quantity at this point
no they didn't come with it, they are 12mm x 1.25 I think, ACE hardware has them.
streamlnauto is offline   Reply With Quote
