LinkBack | Thread Tools |
#1 (permalink) |
Hobo on a ham sandwhich
Hokey, So... I developed a hesitation and before I could diagnose it, I went up to about 5000 rpm after this hesitation.
As soon as this happen, it freaked out. It became super sluggish. As in, rev to 2000 to let the clutch out and after it was depressed, I started at 1000 rpm... bad. Anyway. I didn't install anything new, i've just been driving to and from work. No biggies. Has 150k+ miles, KnN and a spec 3 clutch... thats it. Has new plugs, wires. Never overheated. Does have, i think, 2 cylinders down. Maybe just one. I was never very good at telling... Anyway, no power, boost gauge shows up to 14 psi on the stock gauge, drives like shit. WHERE DO I START? I was thinking maybe a boost leak? Knock sensor maybe? I'm somewhat keen on dsm's not on these... |
#2 (permalink) |
Certified White Boy
does it rev up and down at idle? Mine did this and it was because it was low on coolant. The coolant flows through the throttle body, so it tries to compensate by running wierd when there is air. Just thought i would throw this in here.. maybe it will help.
"Clutch-Eater"
-1992 Dodge Stealth R/T Twin turbo AWD, Dynamic Racing stage II heads, 99 lifters, 6-speed Getrag from 99 vr4, SPEC Stage 4 clutch, TEC 15g's, Greddy blow off valve, Dejon Powerhouse Blow-Thru Intake Pipes, DSM sidemounts, Denso fuel pump, 550cc fuel injectors, Apexi SAFC, HKS VPC, Apexi AVCR, msd ignition dis-4, MSD 8.5mm wires, NGK coppers 1 stage colder, alamo y-pipe, custom exhaust from turbos back, highflow cat, Lowered, Nitto tires. "Knockin' Beater" -1996 Mitsubishi Eclipse GS |
#3 (permalink) |
Killer Whale
First dont listen to the stock boost guage. Get an aftermarket guage. the stock one doesnt read real boost. Check for a vacuum leak. If you cant find anything get a compression test. That should tell alot.
Dejon dual intakes and Ypipe, Synapse B.O.V., Gen2 Maft w/3.5" sensor(blowthru),oohnoo dualcore FMIC, RandomTech Cat,3SXdownpipe,Ips singletip exhaust, Maximal solid motormounts,13T's,Gtpro headers(powdercoated) w/precat elims,Supra Fuelpump,550cc's,AEM Fpr,IPS hotwire kit,AEM AFR guage,Newvolt ignition amp,IK27 plugs, Southbend DXD-FE clutch,Fidanza flywheel,SSclutch line,300M output shaft. 289awhp and 298awtq on stock boost @11.3AFRlimited by bad VSS's on stock sidemounts Next ported heads ![]() |
#4 (permalink) | |
Compression was 120-130 on the front bank, minus the middle cylinder, which was dead. I'm not pushing any more boost than stock so a boost gauge is out unless its necessary. Oh and since you mention the boost gauge.... I know all about the basics. I'm not by any means a newb. I've been into dsm's for years before the vr4. On the boards, daily. I tried searching but i dont even know how to describe it in one or two words... No, not low on coolant. Not revving up and down at idle. My idle is actually amazingly steady... |
#6 (permalink) |
Mr. Chocolate...
Datalog?
![]() 1997 Black Top Red Mitsubishi 3000GT VR4 - 93k miles and 100% stock Cars Owned: 1992 Dodge Stealth RT (sold) 1992 Mitsubishi 3000GT VR4 #1 (parted) 1992 Mitsubishi 3000GT VR4 #2 (sold) 1993 Mitsubishi 3000GT VR4 (KIA) 1994 Mitsubishi 3000GT VR4 (sold) 1994 Mitsubishi 3000GT Base - awd/atx (sold) |
#7 (permalink) |
Grr.... my god damn datalogger cable is all screwed up, it wont connect to anything... Gotta figure that one out too....
My metaphorical fan is brown and starting to smell |
#9 (permalink) |
Forest Gump
could be a bad ecu if your datalogger will not connect and you have bad hesitation. Pull it apart and look for damage.
![]() Power: DSM 13G/DR650 Combo, EVO 560cc injectors, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback, no cats, DN Y-Pipe, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead 8.07 @ 85.55 1/8th mile 1.84 60FT Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete Drivetrain: RPS Street Max, M.W. 300m O/S, Seattle F&R Poly Mounts, EK2 ExoCage Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing/sideskirts/doorcapsm Scanmaster 3 Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings. Mobile 1 10w40, Redline MTL in trans, 85w90 Coastal GL5 in transfer case and rear |
#10 (permalink) |
Thats the second person to tell me that. I also wanna add that the car feels like its without the turbo's. I get no kick in when i hear them spool. I does accelerate a little better but i'm thinking its because its getting up in the rpms so naturally.
I just got another dsm, i can't get my datalogger to connect to that one either so... I dont think its my logger or the cars, i'm thinking its the cable. Thanks for the input. |
