Hey guys, I have a 94 vr4 that needs a long block. I found a 91 engine that is rebuilt. It doesn't come with the oil pan or valve covers, plenum or anything. Can I drop this engine in the car. Or will I need other stuff to make it work? Let me know asap.
Camshaft position sensors are different. You will have to either wire to use the 1G one or make a bracket to use the 2G one. You will also need a 1G oil pan since it doesn't include one.
Not at all a drop in swap with all the 1G stuff you don't have... Not worth the downgrade to a cast crank and 2 bolt block IMO...
Related Threads
6.6M posts
61.9K members
Since 1999
