Re: 1st gen datalogging info
Yes I have the UEGO trying to hook it up to SM3. I read that the scales didn't match, but the values were still accurate? I don't remember where. I'll try it the easy way (analog) first. I think the UEGO comes with a table for voltage and corresponding AFR, I'll have to check.
The EGRT scaling options in MMCd are: "3.0, 2.5, or 2.0 BAR; Wideband O2; EGRT; 0-5V"
The EGRT "input" on MMCd 1.8g says: "Allows selection of scaling for user provided sensors connected to unused EGRT input on 1G Federal ECU." "WBO2 is scaled so a 0-5V input = 8.0 - 22.0 AF." EGRT-->AFR is the only choice if using just MMCd, and there is only one scale for AFR.
The sm3 has nice data substitution options. The default nbo2 display can be changed to show AFR through the analog input. When logging, the data channels can be swapped also: "Data Substitution Battery. Displays AirFuel Ratio data on external loggers BATTERY VOLTS" Apparently, logging the battery volts with this option set will in fact show the AFR.
***EDIT***
OK Install, testing, and setup is done. Anyone who doubted the usefullness of the SM3...the thing is awesome. The analog input does not need to be scaled, the AFR is the same at all times as AEM. Now I have AFR and knock at a glance!! And, the SM3 can be set to output this AFR as battery volts when logging with MMCD. This setup is so sweet, I can't believe how well it works and how even I could figure out how to set it all up. You might have to buy a cable($10-$20), but that's way better than buying and installing more sensors.
If anyone wants help logging their WB with sm3/mmcd just let me know, the options on the sm3 can be a bit tricky. Hope this is helpful.
