#21 (permalink) | |
Member: Burned valve club
Unless you tested for leaks before you replaced the rocker arms (or you uninstalled the lifters and purged the oil from the lifters) there is a good chance some of the valves were being held open by the lifters. (Since I got heart failure when I saw near zero compression following my front head replacement a couple years ago, I always purge the oil from the lifters to make sure the valves close and I can get reasonable compression measurements. They start up very noisy due to excessive clearances but quiet down in a few minutes.) Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side) Overhauled: Starter, IAC, BISS, CV Boots Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!) A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger Pending Projects: Steering Rack Last edited by cbatters : 07-02-2008 at 03:58 AM. |
#22 (permalink) | |
3SX FTL
I agree that all cylinders sounding the same is a good thing. If you had some valve damage, it would be unlikely for all 3 to sound the same. You said 1 cam on the rear bank was off 2 teeth, and the front bank was fine? I assume the crank pulley was lined up correctly...? You also mentioned a spun bearing a few posts back. Just speculation, or a legitimate concern? Have you inspected the oil? Clint
The Pansy Patrol
1995 3000GT VR-4 but real niggaz don't give a fuck: V1, comprehensive denastificizzle, vishizzous accessory biznelt mod, K&N, Greddy Profec B S-P-to-tha-izzec II, S-AFC, Walbro 341, DSM 450s, n AEM UEGO; battery relocizzle K-R-to-tha-izzank Vents, EK2MFG fizzle rizzle loop n plenum spaca, lethal_vr4 manual gang bangin' rizzay, SKVR4 AWS delete, polyurethane motor mounts, adjustable control arms, SS brakes lines, n EGR blockoffs; Custom brakes lines wit cockpit-mounted adjustable proportion'n valve, 332mm Stoptechs, Carbotech Brotha Plus/Porterfield Rizzle ATE Pusha Blue, OZ Gang Bangin' F1 Plus 17x9.5 +36mm, Yokohama AVS ES100 275/40/17, Tein Fizzle w/EDFC n SCE Casta/Camba Plates, SCE oilpan, DSM sidemounts, DN Precat Eliminizzles 13G/9B combo (9psi springs), J-spec final drive, RPS flyhweel n Spec II clutch, IPO propane, ATR downpipe, tizzest pipe, n Single Shot1994 Mazda Protege DX: 260K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech XP8/AX6, 15x7 +30 Kazera KZ-M w/ Avon Tech Ra slicks, other crap here and there (like an air filter that doesn't have 1/4 of a million miles), arguably the fastest piece of shit in New England and no one can do anything about it ![]() |
#23 (permalink) | |
My plan was to use the air pressure to hold the valves shut while changing VSS, but found that I could do it with the piston at TDC, and no pressure.
-Ron
'91 Stealth TT purchased Aug 2004 ![]() |
#24 (permalink) | |
Clint |
#25 (permalink) |
Forest Gump
Well, if you pressurize the cylinder with 100 PSI and have only 5% leakdown (good race engine spec) you'd still have 5 PSI of pressure getting past the rings. That should be audible to anyone. Figure a more realistic figure of 10-15% for a high mile stock engine and you have a lot of air going past the rings.
![]() Power: DSM 13G/DR650 Combo, EVO 560cc injectors, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback, no cats, DN Y-Pipe, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead 8.07 @ 85.55 1/8th mile 1.84 60FT Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete Drivetrain: RPS Street Max, M.W. 300m O/S, Seattle F&R Poly Mounts, EK2 ExoCage Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing/sideskirts/doorcapsm Scanmaster 3 Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings. Mobile 1 10w40, Redline MTL in trans, 85w90 Coastal GL5 in transfer case and rear |
#26 (permalink) | |
Just in case I strike out at the Mitsu parts store, does anyone in MA have a timing belt and tensoner they are willing to sell? Clint |
#27 (permalink) |
Pearl White 92 Stealth TT
Before I started my 120k I found that my front intake cam was 2 teeth clockwise and my rear intake cam was 2 teeth counter-clockwise. I went along with my 120k (timing belt/oil pump/lifters/VSS) and then at the end checked my compression. I got 150's across the board with a COLD test which really surprised me.
So if I were you I would wait on the new tensioner/timing belt and get the timing marks all lined up and start her up. You could probably get away with using the old tensioner/t-belt for a little while if you are still able to slide the pin in the tensioner after waiting the 5 minutes and the belt doesn't have any cracks. Edit: Checking the compression before starting it up again is what I meant to say but you knew that. Maybe I just start to become dumber after 1 AM? Also I would check to see if your cam seals are leaking because they could have potentially led to the belt slipping a few teeth (one of mine was badly leaking). And yes I did hear hissing while doing my compression test and had each piston be at TDC rather than using air pressure. Best of luck Mike Last edited by mike92stealthtt : 07-03-2008 at 09:18 PM. |
#28 (permalink) | |
1. Install a new timng belt and tensioner 2. test compression 3. Fire up the beast and see if the noise is still there Note: I have done 2 - 60Ks on the car myself and am 20K overdue for a third so I want to install a new belt. Also, I swapped front head at ~170K with a fully loaded head that only had 40K on it and have another fully loaded head to toss in the rear if I have valve damage. (I have always wanted to toss in the new head - just have not had the time. Clint Last edited by cbatters : 07-03-2008 at 05:37 AM. |
#29 (permalink) |
Still scrounging around for parts.
Does anyone in Easter MA have a 60K set of parts that I can borrow and replace when my OEM parts arrive next week? (I have found some ag\ftermarket parts but still short a couple cam seals and would prefer to use a Mitsu OEM timing belt.) Clint |
#30 (permalink) |
Finally got around to installing timing belt and firing up engine. Same nasty sound.
Facts: 1. 150 PSI +/- 2 PSI across 1-6 2. Disabling spark on cylinders one at a time had no affect on sound 3. Vacuum is rock stable at 20 in/hg 4. Sound is REALLY loud and nasty. Sounds like it is coming from rear bank near #2 cylinder. 5. Once in a while the sound stops but then resumes Appreciate any input. Clint |
