Old 08-31-2008, 05:52 AM   #111 (permalink)
Member: Burned valve club
cbatters's Avatar
Drives: 91 Stealth RT/TT
Trader Rating: (12)
cbatters Level 2cbatters Level 2cbatters Level 2
Default Re: 1991 RT/TT - First Failure in 230K / 17 years
Originally Posted by Drweldin View Post
Clint,
Can you elaborate on the bypass valve, and how that works...?
Oil pump has built in spring loaded valve that acts as a pressure regulator for the oil. Once oil pressure gets up to ~90-100 PSI it opens and diverts excess oil back to oil pan. With a healthy pump and engine, you will have max pressure by ~4000 RPM on a warm engine. In the graph shown earlier, you wll see engine RPM contine to rise to 6000 while the oil pressure remains the same after ~4000 RPM.
Note: This valve also helps limit maximum pressure on cold start
Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone
Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side)
Overhauled: Starter, IAC, BISS, CV Boots
Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!)
A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger
Pending Projects: Steering Rack
cbatters is offline   Reply With Quote
Old 08-31-2008, 05:53 AM   #112 (permalink)
cbatters's Avatar
Trader Rating: (12)
Originally Posted by OhioSpyderman View Post
Clint,
Here's what I found..
MB631712 Hose Steering Oil RESEVIOR
The other two lines are labeled as RETURN and SUCTION, but unfortunately CAPS shows "**NO DATA**" for both of these parts...
Sorry, I tried.
Bob.
Thanks for trying.
Old 08-31-2008, 06:12 AM   #113 (permalink)
Trader Rating: (107)
Drweldin Level 4Drweldin Level 4Drweldin Level 4Drweldin Level 4Drweldin Level 4
Clint
Thanks
1992 Stealth RT/TT:
Drweldin is online now   Reply With Quote
Old 09-08-2008, 08:32 PM   #114 (permalink)
cbatters's Avatar
Trader Rating: (12)
Originally Posted by cbehnken View Post
rev it out to about 6K. If the oil pressure starts DROPPING instead of going up it is the pump. Same thing happened to my old NA with much less miles.
When you rebuild be sure to open up the oil pump. You'll be amazed at the wear the gear has cut into the pump case.
Looking forward to pics
I'll get some pics posted shortly.
1050 miles and it is beginning to make some all too familiar sounds. Oil pressure has not been right since I put it together and #4 is running way too loose.
I have a short block on the way but may need to get another 1000-2000 out of this engine so I am going to check bearing and replace the oil pump. Anxious to see what kind of wear there is on the pump and how much improvement I get in oil pressure by replacing the pump.
VERY interessted in pictures of failed pumps and cases where oil pressure improved with replacing JUST the oil pump. (Historically there are lots of posts where pressure improved when changing bearings and pump but I don't recall any threads where the only component chjanged was the pump.
Clint
Old 09-09-2008, 04:40 AM   #115 (permalink)
Former ROTY :-}
OhioSpyderman's Avatar
Drives: Back and Forth :)
OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7
Sorry to hear that you may not make your target mileage
Unfortunately for you (and fortunately for us), you are providing us with some very helpful info.
Still wish I was closer so I could give you a hand....
"Stay the course"
Bob.
95 Caracus Red Spyder VR4
92 Wheat Beige Metallic Stealth TT..Winter DD!!
OhioSpyderman Short Shifter (in both!!!)
Cianci FG Viper Hood/Aerocatch Pins
Quad Carbon Fiber Tipped Borla Catback
SBC-iD Boost Controller (in both!!!)
Stock 18" 6 Spoke Chromies
K&N FIPK
Indiglo Gauges
JimVR4's Remote Start/Top Op Computer
OhioSpyderman is offline   Reply With Quote
Old 09-09-2008, 05:15 AM   #116 (permalink)
H to the izzO
Hannibalzero's Avatar
Drives: Recklessly
Trader Rating: (55)
Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7
Clint
Just curious, but if you have that second shortblock on its way, why try to nurse along the current engine by installing a new oil pump? (Maybe I read that wrong?) It seems like the best move would be move would be to install the new engine ASAP (and maybe check the clearances on its bearings and pump gear while you are at it). From the sounds of things, I don't know if I'd trust bearing #4.
Old 09-09-2008, 07:53 AM   #117 (permalink)
cbatters's Avatar
Trader Rating: (12)
Daily driver so I am either driving it or wasting $50/day on a rental. I am also stubborn and want to know what is possible in terms of options for rod bearing damage.
