Old 06-28-2008, 03:27 PM   #1 (permalink)
Member: Burned valve club
cbatters's Avatar
Drives: 91 Stealth RT/TT
Trader Rating: (12)
cbatters Level 2cbatters Level 2cbatters Level 2
Default 1991 RT/TT - First Failure in 230K / 17 years
My car let me down for the first time in 230K miles / 17 years. Heard some nasty valve train noise, pushed in clutch and then engine died. Pulled rocker arms from both heads and pressurized cylinders. Get some slight hissing so I may have smacked the intake valves. Crank spins smoothly
Timing was off by two teath on the rear intake valves but front was fine.
Current plan is to do a 60K and then see if the nastly noise is still around.
Appreciate advise on best sources for 60K components. (or PM me with deals if you have parts available.)
Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone
Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side)
Overhauled: Starter, IAC, BISS, CV Boots
Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!)
A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger
Pending Projects: Steering Rack
cbatters is offline   Reply With Quote
Old 06-28-2008, 04:20 PM   #2 (permalink)
Smash, Bang, AND Pow
stryfe's Avatar
Drives: The Flamethrower
Trader Rating: (8)
stryfe Level 1stryfe Level 1
Default Re: 1991 RT/TT - First Failure in 230K / 17 years
Clint
sorry to hear that, man. 8o( hope you get it sorted. that is one hell of a good run, though!
'92 3000GT VR4
13T's: 428awhp / 434awtq --- 12.44@114.76mph
13Ts | FMIC + PPE pipes | 550CC | 3" Exhaust | PST 1pc CFDS
EMU | Stock Chromies FTW | Spec Stage 3+
stryfe is offline   Reply With Quote
Old 06-28-2008, 04:42 PM   #3 (permalink)
Forest Gump
cbehnken's Avatar
Drives: 1992 Stealth TT
Trader Rating: (42)
cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7
rockville still has the best oem 60K bundle afaik.
Cherry hill triplex mitsu in new jersey can get some very good prices on oem.
Welcome to Cherry Hill Triplex Parts !
barring that you can always do parts dinosaur, but you won't save much.
Power: DSM 13G/DR650 Combo, EVO 560cc injectors, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback,
no cats, DN Y-Pipe, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead 8.07 @ 85.55 1/8th mile 1.84 60FT
Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete
Drivetrain: RPS Street Max, M.W. 300m O/S, Seattle F&R Poly Mounts
Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit
Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing/sideskirts/doorcaps
Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings.
Mobile 1 10w40, Redline MTL in trans, 85w90 Coastal GL5 in transfer case and rear
cbehnken is online now   Reply With Quote
Old 06-28-2008, 05:02 PM   #4 (permalink)
Member
massstealth's Avatar
Drives: 91rt/tt
Trader Rating: (16)
massstealth Level 1massstealth Level 1
Oh no Clint! Sorry to hear.
My timing marks were off a few month ago. Front bank intake off by 1 and exhaust off by 2. I rolled them back with a pencil and everything seems fine. (My ecu was junk and randomly shutting engine off like fuel cut.) If you need help, let me know. Im not at the shop anymore but have tools/will travel.
Bob
Rear ended by homeless drunk driver July 12 04
Please wait 13 seconds..
RPS full face clutch, Fidanza flywheel, ATR downpipe, TurboXS dual stage boost controller, K+N fipk, Turboxs h34 bov, Kormex 25 spline, recall transfercase. 180k service done thanks Clint. Soon>>>Hotwire + fuel pump, water/meth
Image hosted by Photobucket.com
SOLD
Now driving 38mpg Escort
massstealth is offline   Reply With Quote
Old 06-28-2008, 06:02 PM   #5 (permalink)
cbatters's Avatar
Trader Rating: (12)
Thx.
If you pressurize one of your cylinders to 125 PSI with all valves closed, do you get any air leaking or is it silent?
Also, any adviseor estimates of effort to remove the rear head. (I pulled the front ~90K ago but have never pulled the rear.)
Clint
Old 06-28-2008, 06:32 PM   #6 (permalink)
Former ROTY :-}
OhioSpyderman's Avatar
Drives: Back and Forth :)
Trader Rating: (44)
OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7OhioSpyderman Level 7
I just WISH there was something I could do to help you Clint
Rockville Mits (MITSUPARTSDIRECT.COM) is who I also always use. Mike Deal has been a pleasure to work with. If you don't have an account with them, call and tell them that your a 3SI member and they will give you wholesale prices.
I'm sure you have all the tools that I have, but if you need something (and I have it) its yours.
Good luck solving this ASAP.
(I miss you....in a non-gay way!!!)
Bob.
95 Caracus Red Spyder VR4
92 Wheat Beige Metallic Stealth TT..Winter DD!!
OhioSpyderman Short Shifter (in both!!!)
Cianci FG Viper Hood/Aerocatch Pins
Quad Carbon Fiber Tipped Borla Catback
SBC-iD Boost Controller (in both!!!)
Stock 18" 6 Spoke Chromies
K&N FIPK
Indiglo Gauges
JimVR4's Remote Start/Top Op Computer
OhioSpyderman is offline   Reply With Quote
Old 06-28-2008, 06:46 PM   #7 (permalink)
cbatters's Avatar
Trader Rating: (12)
Any positive experiences with aftermarket or is everyone still running OEM for the 60K parts?
Old 06-28-2008, 07:17 PM   #8 (permalink)
H to the izzO
Hannibalzero's Avatar
Drives: Recklessly
Trader Rating: (55)
Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7
Clint, it sucks to hear about the timing skip, but I am damn impressed you've gone 230k without any major problems. I know you maintain your car meticulously, but that is still a good run.
I'd recommend sticking with OEM parts from rockville. Although they've lost some good staff in the last year, their crew is still pretty good. Mike Deal does a great job finding the best prices for "car club" members.
Good luck with the heads.
Old 06-28-2008, 08:04 PM   #9 (permalink)
Drives: 92 VR-4
QSpectre Level 1QSpectre Level 1
I just got my 120k kit from IPS and most of the parts are OEM, the belts are Gates and CONTITECH (timing belt)... pretty nice kit.
1992 Fiji Blue VR-4
Working on getting it going for now!
Past Cars:
2003 Cobra (475 rwhp)
1999 BMW M3
1998 BMW 328is
1988 BMW 325xi
QSpectre is offline   Reply With Quote
Old 06-29-2008, 05:03 AM   #10 (permalink)
cbatters's Avatar
Trader Rating: (12)
I shattered a chunk from one of my #1 exhaust valves at ~170K and picked up two fully loaded heads with 43K but only bolted on the front head. I know what the effort is to do the front and should be easier now. (First time I had to drill out and re-tap one of the turbo-manifold bolts that snappped off. VERY hard steel.)
Best repair is probably to pull both heads, toss on low mileage rear head I have sitting in garage and repair any damage to the low mileage head on the front. (possibly robbing 6 intake valves from the head with the shattered valve.)
Two things I would appreciate:
1. Feedback on what other people experience when they pressurize a cylinder with all valves closed. (with heads and valves that have > 100K on them) mine are making uniform faint hissing sound on all cylinders
2. Link to thread or comments on removing rear head. Specifically, how big a PITA is it to disconnect turbo from manifold or can you leave head-manifold-turbo-connected and just unbolt from downpipe.
