Old 06-30-2008, 05:53 PM   #21 (permalink)
Member: Burned valve club
cbatters's Avatar
Drives: 91 Stealth RT/TT
Trader Rating: (12)
cbatters Level 2cbatters Level 2cbatters Level 2
Default Re: 1991 RT/TT - First Failure in 230K / 17 years
Originally Posted by 3Sfever View Post
I just noticed this thread. Back when I was replacing my VSS, mine made a hissing sound when I applied pressure to cylinders also. It seemed to be leaking past the rings, not valves. The engine was cold, which I imagine made it worse. Your engine is cold also, I would assume
Good luck. No fun when things like this happen to daily driver.
How many miles on your timing belt tensioner? (the device with spring and plunger). Mine was shot at 150k. not sure if it was original or not.
Thanks for the heads up..
Unless you tested for leaks before you replaced the rocker arms (or you uninstalled the lifters and purged the oil from the lifters) there is a good chance some of the valves were being held open by the lifters.
(Since I got heart failure when I saw near zero compression following my front head replacement a couple years ago, I always purge the oil from the lifters to make sure the valves close and I can get reasonable compression measurements. They start up very noisy due to excessive clearances but quiet down in a few minutes.)
Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone
Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side)
Overhauled: Starter, IAC, BISS, CV Boots
Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!)
A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger
Pending Projects: Steering Rack
cbatters is offline   Reply With Quote
Old 07-02-2008, 01:43 PM   #22 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7
Originally Posted by cbatters View Post
Also encouraging that all of the cylinders appear to be the same.
Clint
Hey Clint, nice to see you post--though it's unfortunate that you've run into trouble.
I agree that all cylinders sounding the same is a good thing. If you had some valve damage, it would be unlikely for all 3 to sound the same.
You said 1 cam on the rear bank was off 2 teeth, and the front bank was fine? I assume the crank pulley was lined up correctly...?
You also mentioned a spun bearing a few posts back. Just speculation, or a legitimate concern? Have you inspected the oil?
Clint
The Pansy Patrol
1994 Mazda Protege DX: 260K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech XP8/AX6, 15x7 +30 Kazera KZ-M w/ Avon Tech Ra slicks, other crap here and there (like an air filter that doesn't have 1/4 of a million miles), arguably the fastest piece of shit in New England and no one can do anything about it
Struggly is offline   Reply With Quote
Old 07-02-2008, 02:07 PM   #23 (permalink)
3Sfever's Avatar
Drives: '91 Stealth TT
3Sfever level 63Sfever level 63Sfever level 63Sfever level 63Sfever level 63Sfever level 6
All cylinders produced a "hiss" under these conditions: Cams/rockers removed, piston at either TDC or BDC, pressure in sparkplug hole. As mentioned before, this was with cold engine.
My plan was to use the air pressure to hold the valves shut while changing VSS, but found that I could do it with the piston at TDC, and no pressure.
-Ron
'91 Stealth TT
purchased Aug 2004
3Sfever is online now   Reply With Quote
Old 07-02-2008, 05:51 PM   #24 (permalink)
cbatters's Avatar
Trader Rating: (12)
Appreciate the clarification - sounds like a little hissing is normal.
Clint
Old 07-02-2008, 05:55 PM   #25 (permalink)
Forest Gump
cbehnken's Avatar
Drives: 1992 Stealth TT
cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7
Clint
Well, if you pressurize the cylinder with 100 PSI and have only 5% leakdown (good race engine spec) you'd still have 5 PSI of pressure getting past the rings. That should be audible to anyone. Figure a more realistic figure of 10-15% for a high mile stock engine and you have a lot of air going past the rings.
Power: DSM 13G/DR650 Combo, EVO 560cc injectors, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback,
no cats, DN Y-Pipe, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead 8.07 @ 85.55 1/8th mile 1.84 60FT
Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete
Drivetrain: RPS Street Max, M.W. 300m O/S, Seattle F&R Poly Mounts, EK2 ExoCage
Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit
Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing/sideskirts/doorcapsm Scanmaster 3
Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings.
Mobile 1 10w40, Redline MTL in trans, 85w90 Coastal GL5 in transfer case and rear
cbehnken is online now   Reply With Quote
Old 07-02-2008, 07:33 PM   #26 (permalink)
cbatters's Avatar
Trader Rating: (12)
Sounds encouraging. I am going to see if I can scrounge up a timing belt and tensioner to re-install tomorrow and get the beast back on the road.
Just in case I strike out at the Mitsu parts store, does anyone in MA have a timing belt and tensoner they are willing to sell?
Clint
Old 07-02-2008, 11:12 PM   #27 (permalink)
Pearl White 92 Stealth TT
mike92stealthtt's Avatar
Drives: 100+ IDC's
Trader Rating: (12)
mike92stealthtt Level 7mike92stealthtt Level 7mike92stealthtt Level 7mike92stealthtt Level 7mike92stealthtt Level 7mike92stealthtt Level 7mike92stealthtt Level 7
Before I started my 120k I found that my front intake cam was 2 teeth clockwise and my rear intake cam was 2 teeth counter-clockwise. I went along with my 120k (timing belt/oil pump/lifters/VSS) and then at the end checked my compression. I got 150's across the board with a COLD test which really surprised me.
So if I were you I would wait on the new tensioner/timing belt and get the timing marks all lined up and start her up. You could probably get away with using the old tensioner/t-belt for a little while if you are still able to slide the pin in the tensioner after waiting the 5 minutes and the belt doesn't have any cracks.
Edit: Checking the compression before starting it up again is what I meant to say but you knew that. Maybe I just start to become dumber after 1 AM?
Also I would check to see if your cam seals are leaking because they could have potentially led to the belt slipping a few teeth (one of mine was badly leaking).
And yes I did hear hissing while doing my compression test and had each piston be at TDC rather than using air pressure.
Best of luck
Mike
mike92stealthtt is online now   Reply With Quote
Old 07-03-2008, 05:32 AM   #28 (permalink)
cbatters's Avatar
Trader Rating: (12)
So if I were you I would wait on the new tensioner/timing belt and get the timing marks all lined up and start her up. You could probably get away with using the old tensioner/t-belt for a little while if you are still able to slide the pin in the tensioner after waiting the 5 minutes and the belt doesn't have any cracks. If it starts up and idles fine I would do another compression test and hope that taking off the heads isn't the next step.
Best of luck
Mike
Thanks for the friendly advise... I have already cnfirmed that the valves and rings appear to be sealing correctly so the next steps on the path back to driving is to:
1. Install a new timng belt and tensioner
2. test compression
3. Fire up the beast and see if the noise is still there
Note: I have done 2 - 60Ks on the car myself and am 20K overdue for a third so I want to install a new belt. Also, I swapped front head at ~170K with a fully loaded head that only had 40K on it and have another fully loaded head to toss in the rear if I have valve damage. (I have always wanted to toss in the new head - just have not had the time.
Clint
Old 07-05-2008, 02:40 PM   #29 (permalink)
cbatters's Avatar
Trader Rating: (12)
Still scrounging around for parts.
Does anyone in Easter MA have a 60K set of parts that I can borrow and replace when my OEM parts arrive next week?
(I have found some ag\ftermarket parts but still short a couple cam seals and would prefer to use a Mitsu OEM timing belt.)
Clint
Old 08-10-2008, 04:12 PM   #30 (permalink)
cbatters's Avatar
Trader Rating: (12)
Finally got around to installing timing belt and firing up engine. Same nasty sound.
Facts:
1. 150 PSI +/- 2 PSI across 1-6
2. Disabling spark on cylinders one at a time had no affect on sound
3. Vacuum is rock stable at 20 in/hg
4. Sound is REALLY loud and nasty. Sounds like it is coming from rear bank near #2 cylinder.
5. Once in a while the sound stops but then resumes
Appreciate any input.
Clint
