Go Back   3000GT/Stealth International Message Center > Events > Regional Events > South East
Old 04-25-2004, 05:28 PM   #1 (permalink)
Fixing what just broke...
$3K_short's Avatar
Drives: 92' VR-4 & 91' RT/TT
$3K_short is an unknown quantity at this point
Exclamation I give up willing to PAY someone to help me!!!
Ok here is the deal...
I just bought a beautiful new VR-4 from GreyGoose on the boards and its giving me a little bit of a headache. I am having trouble with the airflow sensors and possibly my S-AFC wiring. I have been troubleshooting this for a about 2 weeks now in my spare time (not much) and have made progress but not found a cure. In order to get my car registered and "street legal" in time, I have to fix this problem ASAP.
I AM WILLING TO PAY ANYONE WITH AMPLE KNOWLEDGE ABOUT THESE CARS TO COME AND HELP ME WITH MY CAR.
My symptoms are that I have a CEL that my datalogger says was an airflow sensor problem. I swapped my stock MAS out for a MAF-T which should replace the airlfow sensor with a new one correct? Well anyway, the CEL is still on (I have not reset it) but now the car is still acting funny and its smoking now at idle like it is running VERY rich. I believe it has something to do with my SAFC, but i am absolutely hopeless with those things as of now.
Symptoms:
S-AFC is getting NO power to it
Car is smoking at idle (havent run it on the street)
REV's are lower than normal
CEL light for airflow sensor.
Stock boost gauge stopped working but my turbo timer still says it boost and i ca hear the turbos.
As far as how much I dont know what I should offer so give me a call and we can discuss that if youd like.
I have the feeling that this is going to be a simple fix as the car was running amazingly well when i bought it and i have not abused it in any way. I would continue to figure this out on my own, but like i said i am runnig out of time and happen to have some cash so I figured that I will see if one of you guys could help me out, I really need this and would make it worth your while.
If you know these cars and have some spare time, please give me a call ANYTIME day or night at 404-643-8210 and I will tell you everything that I know about the problem.
Thanks as always
-Toby
AND I REALLY NEED SOME HELP ON THIS ONE!!!!
1992 Sandstone Grey VR-4 @80,xxx
Engine:
Fresh Longblock, 13T Turbos w/ 9psi springs, DR SMIC's, SPEC Stage III clutch, 25 Spline Tranny, 680CC Injectors, LS6 MAF-T, Walbro 241w/ re-wire, Greddy e-manage w/ timing control, SMC Alcohol Injection, ATR Downpipe and Catback w/ gutted cats, Test Pipe, Hallman MBC, 3rd gen lifters, Maximal Performance solid motor/tranny mounts, Cianci Performance 3x52mm gauge pod, Autometer Boost and EGTx2, Elec oil pressure gauge, 1G DSM BOV, Palm M100 w/ pocketlogger
Other Stuff:
17" Painted Rims, Intrax Springs, Adjustable Rear Control Arms, 1500W of sound, Chrome Mitsu emblem, shaved "3000GT VR-4"
"Im sure that half the people on this board would get rid of their cars in a heart beat if we werent so far in debt" -Black1995GTBase
$3K_short is offline   Reply With Quote
Old 04-25-2004, 05:30 PM   #2 (permalink)
$3K_short's Avatar
Default Re: I give up willing to PAY someone to help me!!!
Oh by the way, I live in Alpharetta near the North Point Mall area if anyone is around here.
Old 04-25-2004, 08:55 PM   #3 (permalink)
Resident rocket scientist
BigTyla's Avatar
Drives: '93 3000GT ATX TT
Trader Rating: (179)
BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7
There are tons of ATL guys on the forum. Chime in to one of their threads.
1993 3000GT FWD ATX TT - mods coming<---------------->2009 Honda Fit - 40 mpg ftw
Nov/Dec ground wire GB!!!
Old 04-25-2004, 09:27 PM   #4 (permalink)
$3K_short's Avatar
Well i was trying not to hijack another thread by starting this one new, but i might have to to get the attention seeing as how I really need some help on this one.
Old 04-25-2004, 09:59 PM   #5 (permalink)
BigTyla's Avatar
No harm in a shameless plug
Just get into their thread and post a link...I am sure they wouldn't mind.
Old 04-26-2004, 05:26 AM   #6 (permalink)
Devoted Darkling
ukyo's Avatar
Drives: Like John M
Trader Rating: (7)
ukyo is an unknown quantity at this point
You can fix this on your own. You are getting the CEL because the car is not seeing a signal from the air flow sensor (be it the stock sensor or the replacement air metering system). The reason you are not getting a signal is because the SAFC does not have power. So, trace the power wire on the SAFC to it's source and make sure it has a good connection (it probably won't). As soon as you get the power wire to make a good connection the car should return to normal.
My car does the same thing when the SAFC loses power. I need to solder those connections in down there, but I still haven't gotten around to it.
I'm way South of you in Newnan right now, so it's a bit of a drive for me to come and look at it, but there are a lot of GA 3/S up around you. Someone up there should be able to help you out. And if not, let me know, and we can work something out.
Good luck with it!
--Travis (AIM: ukyo1714)
97 Eclipse GSX: Daily Driver (aka, SLOW)
94 3000GT VR-4: 12.835 @ 109.40 (I need a better tune...)
97 Supra TT: 13.363 @ 112.40 (100 octane / street tires)
"Wise men wonder while strong men die" -- Breaking Benjamin
ukyo is offline   Reply With Quote
Old 04-26-2004, 07:12 AM   #7 (permalink)
Fire Breather
Tom Wolf's Avatar
Drives: Your Mom!
Tom Wolf Level 2Tom Wolf Level 2Tom Wolf Level 2
Good luck with it!
I'm going to solder my connections soon, Trav. We could make a day of it.
(6 more days).
'92 Stealth TT Green
Kormex 25 Spline Tranny
1995 JDM GTO Engine
K&N FIPK
Greddy Profec Type-S Boost Controller
Greddy Turbo Timer
Greddy Type S BOV
AutoMeter Boost Gauge
AutoMeter Gauge Pod
Apexi S-AFC II Limited Edition Black
Enkei RP02-J's 18x9
Faulken Ziex ZE-512's 265/35-R18
Custom Wolf Gauges by SMO cat
Snake-Eyes
PowderCoated Valve Cover
450cc Injectors
DN Performance Y-Pipe
Intrax Lowering Springs
Custom Rear Control Arms
Pioneer DEH-P7500MP
Solid Motor Mounts
'99 Lifters
Grounding Kit
R1 Concepts Drilled and Stotted Rotors
Stillen Brake Pads
Tom Wolf is offline   Reply With Quote
Old 04-26-2004, 08:59 AM   #8 (permalink)
stlth664 was here
sixsixfour's Avatar
Drives: 94TT/96TT/Qx4/Pickup
Trader Rating: (15)
sixsixfour Level 7sixsixfour Level 7sixsixfour Level 7sixsixfour Level 7sixsixfour Level 7sixsixfour Level 7sixsixfour Level 7sixsixfour Level 7sixsixfour Level 7sixsixfour Level 7sixsixfour Level 7
Let us know how it turns out. There's quit a few people around ATL that know the SAFC. Not to mention, this weekend there will be a ton more 3S members in ATL for track day!! You're coming, right??
Cty // #146 3SI //1994 Grayish White Pearl Stealth R/T TT // 1996 Olive Pearl Stealth R/T TT
sixsixfour.com // Barefoot Racing // GA3S // southeastdragday.com // 1996 Stealth TT production
Taco Bell Crew 4 Life // Nikon crew // Club Blue Tape
sixsixfour is offline   Reply With Quote
Old 04-26-2004, 09:25 AM   #9 (permalink)
Seminole Football
blackga3s's Avatar
Drives: 95 3kGT & 99 CBRf4
blackga3s is an unknown quantity at this point
speaking of the track day, christy im goin on sunday ive gotta work the rest of the weekend so i really cant hang out much besides the actual track day. Where could i meet you guys and what time?
blackga3s is offline   Reply With Quote
Old 04-26-2004, 12:11 PM   #10 (permalink)
stlth664 was here
sixsixfour's Avatar
Trader Rating: (15)
Still working out the details...a PM/email will be going out today...
~Christy
