Go Back   3000GT/Stealth International Message Center > Events > National
Old 10-19-2001, 09:22 PM   #1 (permalink)
NG09: The Comeback Tour
Alan92RTTT's Avatar
Drives: 1992 RT/TT
Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7
Post Forum Rules
This forum is for Gathering information ONLY threads not related to gatherings will be deleted(unless I'm feeling nice I may move it to where it belongs)
If your event has over 75 cars it can be listed in the national forum as a "national" event. Any posts for other events should go in the appropriate regional event forum.
If your event has over 50 cars or more on average a announcement post will be added to all regional/event forums. PM me with your official post.
If your event has over 25 cars on average it can be stuck at the top of the appropriate regional forum.
NG07 T-Shirts For Sale * NG08 T-Shirts For Sale
NG08 Stuff from Cafepress
Custom 12x18 poster/photo prints
Alan(3SI#601)alan92rttt@mi3si.org Michigan 3SI.
1992 Dodge Stealth RT/TT
My Snake Eyes, 13g Turbos, 450cc DSM injectors, Walbro 255 Fuel Pump, Autometer Boost Guage, Greddy peak/hold EGT, Apexi S-AFC, K&N FIPK, Clean Cats, 3rd Gen Lifters, JVC SX990 CD/MP3 Receiver, JVC CH-X200 12 Disc Changer.
1998 3000GT SL
Alan92RTTT is offline   Reply With Quote
Old 10-20-2001, 12:05 PM   #2 (permalink)
Crazy Biscuit
Crazey's Avatar
Drives: 1996 VR-4
Crazey is an unknown quantity at this point
Default
Sweet, good job man, this is great, Thanks!
Crazey is offline   Reply With Quote
Old 10-21-2001, 08:11 AM   #3 (permalink)
nomovrfo
cdd vr-4's Avatar
Drives: 2004 BMW M3
cdd vr-4 is an unknown quantity at this point
Default New gathering forum
Good idea Alan . Also , how long will you keep a gathering thread alive after the date of the actual gathering ? Or will the forum just keep growing like the rest ?
Again , good job and thanks !!!!
cdd vr-4 is offline   Reply With Quote
Old 10-21-2001, 09:01 AM   #4 (permalink)
Alan92RTTT's Avatar
Drives: 1992 RT/TT
Default
This forum will work like the rest. THe only threads that will get deleted from here are non gathering threads.
Old 02-25-2003, 08:26 PM   #5 (permalink)
3SX FTL
Turbo Tension's Avatar
Drives: smokey/bandit
Trader Rating: (8)
Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7
Default
What about Caravan organization threads? I would like all N and regular East Coast people attending to come through IL preferably on 74, and then we can get a big caravan of them and the guys from Chicago as well. I think that would be very fun. I'm thinking about posting some maps with redlines detailing what could happen
1993 "dove gray metallic" Stealth R/T Turbo
Car is FOR SALE - 13k - PM me
6-speed transmission conversion, 2g front brake conversion, AWS delete with SK VR4 radius rod mod(BIG thanks to Joe G.'s website! )Kormex front LSD, Port matched Upper Intake -> Ported and port matched lower intake -> DR stage ]l[ heads, DR650Rs, ARC2 w/ 87mm MAF $ ARM1, Denso 255 hotwired, 720cc inj. fed by a Home made dual feed system for $800 w/ single hotwired intank pump, DR Weldin DSM sidemounts, DNP Y-pipe, 3SX poly motormounts, Vac hose reduction,, Chipped stock ECU -9000rpm rev limiter, Blitz DSBC in stock tape deck, VDO boost gauge, GREDDY EGT gauge, ATR downpipe - Borla catback w/ custom 3" flanges (3" all the way through), RPS flywheel, RPS clutch, Tein S-tech springs, Saner front and rear sway bars, Cusco adj. rear sway bar, 3SX adj. upper control arms, STEDEBANI front poly suspension bushings, 1995 VR4 front brake caliper conversion, Stillen Rotors,SCE extended wheel studs WELDED IN - THANKS SUPERCAR ENGINEERING! in NEW OEM hubs, Porterfield R4S pads, SILKOLENE brake fluid, Pro N1s w/ S03 Potenzas, 17x9 FNCRO1NFC01RN 5Zigens w/ NITTO 555Rs, POR15 on everything and a ton of new stock stuff...
Turbo Tension is offline   Reply With Quote
Old 07-16-2005, 12:59 AM   #6 (permalink)
Forum user
splstats.com's Avatar
splstats.com is an unknown quantity at this point
Default Re: Forum Rules
So where can I post upcoming car shows?
splstats.com is offline   Reply With Quote
