February 2017 ROTM! - Page 2 - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Go Back   3000GT/Stealth International Message Center > Automotive Discussions > Ride of the Month/Year > ROTM Winners
Old 02-22-2017, 11:55 PM   #11 (permalink)
Drives: 93 Mitsu 3KGT VR4
marlon.delarosa is an unknown quantity at this point
Feedback Score: 0 reviews
Default Re: February 2017 ROTM!
thanks for the info, good looking out.
marlon.delarosa is offline   Reply With Quote Quick reply to this message
Old 02-23-2017, 07:14 AM   #12 (permalink)
popups FTW
eengler2's Avatar
Drives: 1992 VR4
eengler2 Level 2eengler2 Level 2eengler2 Level 2eengler2 Level 2eengler2 Level 2
Feedback Score: 12 reviews
Yeah, number one detail mod....4Gswap it
NGK non projected plugs. .020"
Stock DSM coils. HKS DLI. NGK wires.
Up to 42psi on the street so far.
Currently one set of 2150 high z injectors. Adding a second set of 1650 high z. Of course, resistor bypass.
Yes, A couple additional ground wires. Lol.
Lots of testing on my launch. And finely tuned AEM settings to get where it is to have the second quickest 60ft on the top 10, one of the heaviest cars and haven't broken a tcase (yet).
1992 Kilder Green VR4 - First 4Gswap in a 3S. 9.65 @ 143MPH (Top5 3S quicklist; Quickest/Fastest single turbo 3S)
eengler2 is offline   Reply With Quote Quick reply to this message
Old 02-23-2017, 10:00 AM   #13 (permalink)
LS3S
MDoe8's Avatar
Drives: LS3S-Stealth LS1 TT
MDoe8 Level 1MDoe8 Level 1
Feedback Score: 9 reviews
What setup were you on for your 9.6?
Project LS3S - '94 Stealth LS1 Twin Turbo
Build Thread
MDoe8 is offline   Reply With Quote Quick reply to this message
Old 02-23-2017, 11:09 AM   #14 (permalink)
popups FTW
eengler2's Avatar
Drives: 1992 VR4
3300lbs.
2150's, twin walbro 450's.
Forced Performance Super99 turbo. ERL cast exhaust manifold (new mani should flow much better at that power level.)
Forrester Cast intake manifold (new one should pick up a little mid-range and probably the same up top. Maybe a little better.)
Auto trans of course. Upgraded by me. (Hope to install the front lsd insert I bought this year, and maybe scratch the coin together for a billet clutch basket)
100shot to get on the converter. (plan to test spraying down the track)
AEM v2. My 4Gswap "pro tune" lol
Old 02-23-2017, 04:35 PM   #15 (permalink)
LS3S
MDoe8's Avatar
Very cool. Such a simple recipe for power with those things. Internals, fuel, intake mani, turbo, trans....in the 9's.
What are your goals for the new setup?
Old 02-23-2017, 10:19 PM   #16 (permalink)
popups FTW
eengler2's Avatar
Drives: 1992 VR4
Default February 2017 ROTM!
Quicker.
Turbo is the same. Mostly just adding more fuel and trying to find some weight reduction that doesn't change the street/strip nature and look of the car.
Old 02-24-2017, 06:23 AM   #17 (permalink)
Marshall Taylor
Marshall Taylor's Avatar
Drives: 95 VR-4/67 Pro Vette
Marshall Taylor Level 1Marshall Taylor Level 1
Feedback Score: 33 reviews
Originally Posted by eengler2 View Post
3300lbs.
Congratulations on your February 2017 ROTM win!
Your 3si thread "4G Swap" presently covers 166 pages, 1,660 posts and has 97,620 views. Sir, you and the work and results of your car has certainly created much interest in the 3si Forum, the other site and Facebook.
Outstanding!
Marshall
Stage 3 80 over Pampena Strocker, Crower Rods, DR Race Cams, UO Cam Gears, A-1 Head Studs, Stage 3 Heads / 1mm oversize valves / flows 300+ CFM / Pampena Headlift fix / Hi Rev Springs / Titanium retainers / 3rd Gen Lifters, Italo's Oil Pump Gears, Twin PTE Billet Turbos rated 590 HP each, Custom T3/T4 Long Tube Manifold Kit, Tial WGs, Tial BOV, Custom Upper Plenium with Q-45 90 mm TB, ID 2000 Injectors, 1100 HP FMIC, Big Weldon External Fuel Pump with street controller, Tank Sump, -12 AN Rus Pro Flex Supply / -8 AN Return, 25 Row Oil Cooler, 6 Qtr. Racing Oil Pan, Bellhousing Brace, RPS Twin CC Clutch, Magnus Launch Control Device, DR 6 Sp End Housing, 300m Output Shaft, M/W Input Spool, 6 Sp TC Brace, CFDS, Rays 300m Rear Axles, Stage 3 Snow Boost Cooler, 75HP NOS Wet Shot, Okada Plasma Ignition Booster, Stewart Electric Water Pump, Meziere Expansion Tank, PWR Raditor, True 3" Dual Exhaust with Electric Cut Outs & X-Pipe, Mechman 220 Amp Alt, Solid Mounts, Pampena built Trans & TC. AEM Gauges, AEM V-2 Stand-a-lone, Twin Spal Fans, HKS Coil Overs, Wilwood Big Brake Kit, Stainless Steel Brake lines, Solid rear diff & shifter bushings.
Marshall Taylor is online now   Reply With Quote Quick reply to this message
Old 02-24-2017, 07:44 AM   #18 (permalink)
popups FTW
eengler2's Avatar
Drives: 1992 VR4
Thanks Marshall! Although those 1660 posts may be mostly me. Lol.
Old 02-24-2017, 06:56 PM   #19 (permalink)
Down and Out
krymeno's Avatar
Drives: '92 VR4|'02 C-Class
krymeno is an unknown quantity at this point
Feedback Score: 2 reviews
Finally some appreciation for one of the most iconic 3S car to date.
Congrats!
'92 VR4 | 3M "Hot Rod" Red
15Gs, Dual core FMIC, Coilovers, APR GTC, Basic weight reduction (AWS Delete, Radio delete, etc.)
krymeno is offline   Reply With Quote Quick reply to this message
Old 02-24-2017, 08:53 PM   #20 (permalink)
wildcatav8r's Avatar
Drives: 92 VR4
wildcatav8r is an unknown quantity at this point
congrats!
wildcatav8r is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
Random Question
