Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Price Matched Parts
Old 07-05-2008, 04:20 PM   #21 (permalink)
IF u aint first you last
BET-RHD's Avatar
Drives: GTO
Trader Rating: (19)
BET-RHD Level 2BET-RHD Level 2BET-RHD Level 2
Default Re: *New* Fuel Line kit(Tank to filter)
Originally Posted by linchpinjoe View Post
Bump
Have you replaced your fuel pump with an aftermarket pump?
The fuel line end fittings strip out very easy. This will replace those fittings with the AN fittings.
This will also replace the rubber section in the fuel line between the tank and filter.
I have these available in lager fuel line kits as well.
Jason
Jason@PriceMatchedParts.com
I can hook you up on car parts!! check it out
www.PriceMatchedParts.com
91 vr4- Budget build! stay tuned!
1 of 2 in the US
BET-RHD is offline   Reply With Quote
Old 08-03-2008, 02:51 PM   #22 (permalink)
speed hunter's Avatar
Drives: 95 VR4
Trader Rating: (23)
speed hunter is an unknown quantity at this point
Hey guys,
We just put together a fuel line kit that runs form the tank to the filter using Braided stainless lines and AN fittings.This will come with everything you need to install this kit. This way you can get rid of all that small old rusty line. They will be in stock on Thursday and I will post pictures as soon as I can. we are going to do the first 5 kits for $140 shipped PM me if you are interested.
The line is 6-AN (you can upgrade for a little more again PM for details)
Has AN fittings to connect the line to the factory fuel pump assembly and an adapter for the factory fuel filter to AN fitting. This also comes with the Brackets to mount the line all the way up the car.
Pictures soon!
These are not on the site yet so PM me for check out info
Jason
speed hunter is online now   Reply With Quote
