#21 (permalink) |
IF u aint first you last
Have you replaced your fuel pump with an aftermarket pump? The fuel line end fittings strip out very easy. This will replace those fittings with the AN fittings. This will also replace the rubber section in the fuel line between the tank and filter. I have these available in lager fuel line kits as well. Jason
Jason@PriceMatchedParts.com I can hook you up on car parts!! check it out www.PriceMatchedParts.com 91 vr4- Budget build! stay tuned! 1 of 2 in the US |
#22 (permalink) |
Hey guys,
We just put together a fuel line kit that runs form the tank to the filter using Braided stainless lines and AN fittings.This will come with everything you need to install this kit. This way you can get rid of all that small old rusty line. They will be in stock on Thursday and I will post pictures as soon as I can. we are going to do the first 5 kits for $140 shipped PM me if you are interested. The line is 6-AN (you can upgrade for a little more again PM for details) Has AN fittings to connect the line to the factory fuel pump assembly and an adapter for the factory fuel filter to AN fitting. This also comes with the Brackets to mount the line all the way up the car. Pictures soon! These are not on the site yet so PM me for check out info Jason |
