Go Back   3000GT/Stealth International Message Center > The Lounge > The A/V Room > Art, Photography, Video
Old 03-11-2008, 06:34 AM   #91 (permalink)
Twin Turbo Owner
97mits3kgtSOHC's Avatar
Drives: 95 Pearl White VR4
Trader Rating: (95)
97mits3kgtSOHC Level 397mits3kgtSOHC Level 397mits3kgtSOHC Level 397mits3kgtSOHC Level 3
Default Re: Camera Selection
well i dont want to get a 40d...too much right now...maybe down the line....so for starters an xti will be good enough...but what lens since the one macky suggested is out of stock? also should i get a 1gb or 4gb memory card...how many pics will fit on the 2gb
97mits3kgtSOHC is online now   Reply With Quote
Old 03-11-2008, 07:12 AM   #92 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (66)
Dude for starters an XT would honestly be good enough. These guys are talking bang for your buck -- but if you spend less bucks on an XT body, you can can always splurge on an XSi or 40d later on and still use all your lenses from the XT. The XT is a great body, and cheap for a beginner.
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts Nov 2008 ROTM
Old 03-11-2008, 07:18 AM   #93 (permalink)
Twin Turbo Owner
Trader Rating: (95)
^im gonna def spend the money on an xti....just need to pick out a good lens for it....something in the 25-75mm range right? with IS....
do i need uv filters too?
Old 03-11-2008, 08:01 AM   #94 (permalink)
Macky's Avatar
Drives: Midsize sedan
Trader Rating: (6)
Macky Level 7Macky Level 7Macky Level 7Macky Level 7Macky Level 7Macky Level 7Macky Level 7Macky Level 7Macky Level 7Macky Level 7Macky Level 7
Originally Posted by Red92vr4 View Post
I know. I was referring to that it at least allows you to see if the images they send are sent with the camera they intend to sell you. It's not a 100% guarantee, but it might give you the heads up on if they are trying to pull a fast one or not.
true. didnt mean it in an offensive way its a 50/50 chance at best though.
Macky is offline   Reply With Quote
Old 03-11-2008, 08:02 AM   #95 (permalink)
Macky's Avatar
Trader Rating: (6)
the range depends on what you will be shooting most of the time.
as far as a UV lens, its pretty much clear cut to buy one just to protect your lens.
good luck
Old 03-11-2008, 08:44 AM   #96 (permalink)
Twin Turbo Owner
Trader Rating: (95)
well i want to shoot cars and homes for now....so any suggestions....
Old 03-11-2008, 08:49 AM   #97 (permalink)
Macky's Avatar
Trader Rating: (6)
in that case stay within 17/18mm wide through at least 50mm long. you would want a wide lens when shooting indoors - 28mm lenses force you to crop off a lot on the sides in indoor shooting unless you are doing crops anyway (like portraits in halls).
Old 03-11-2008, 08:49 AM   #98 (permalink)
Twin Turbo Owner
Trader Rating: (95)
ok so amazon has it cheaper than the other place with shipping
so im gonna get:
-black xti body
-4gb memory card
-and what about this lens http://www.amazon.com/Canon-EF-S-18-...246876&sr=8-38
and just any uv filter?
Old 03-11-2008, 08:50 AM   #99 (permalink)
Twin Turbo Owner
Trader Rating: (95)
i really appreciate all ur help.....i may seem annoying with all these questions but its been a while since ive done stuff with slr cameras (my old 35mm minolta was the last one i used)
Old 03-11-2008, 08:52 AM   #100 (permalink)
Macky's Avatar
Trader Rating: (6)
so im gonna get:
-black xti body
-4gb memory card
for a starter, thats not bad at all. that lens, though a very basic lens with a plastic mount, is quite sharp at f/8 through f/11. the IS will give you more latitude at lower light (the claim is up to 3 stops of compensation but Ive realistically had 2 stops), minimizing blur due to camera shake. any UV filter would do, but if you can afford it, get a reasonably good one.
