Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Extreme Dimensions
Old 07-18-2008, 02:27 PM   #31 (permalink)
ATL
MK_94_3000GT's Avatar
Drives: 1994 3000GT
Trader Rating: (20)
MK_94_3000GT Level 4MK_94_3000GT Level 4MK_94_3000GT Level 4MK_94_3000GT Level 4MK_94_3000GT Level 4
Default Re: 1999 Replica Combat wing
Originally Posted by JasonY View Post
Also, one thing to note it is likely a lot of the cracking/fatigue problems on the replica wings was likely caused by a shotty install. Since if the holes were even 1/8" of an inch off, once tightened down it will cause constant stress on the wing even w/o the flexing of the wing underload and over bumps and what not.
The only really good way to make the wing is well, gonna be expensive so its unlikely there will be much if any savings over buyin an OEM wing except for a pound or two in weight savings.
For what its worth, the demographic on 3si doesnt support a 900 dollar OE quality replica wing to make it work producing them imo. not to knock anyone, but its true, a 1 thousand dollar wing is, well, a thousand dollar wing lol.
Jason
Yep install will cause a problem in the wing. Not sure if you remember the chameleon colored car at NG with the combat wing. Mine is set forward by about 1/8 of an inch and thus it does not sit flat. Causing some cracking and what not. Its an OEM wing I was told but I am not sure.
MK_94_3000GT is offline   Reply With Quote
Old 07-18-2008, 02:47 PM   #32 (permalink)
Crimson Jihad
Disrupter's Avatar
Drives: An Angry Demon!
Trader Rating: (12)
Disrupter Level 3Disrupter Level 3Disrupter Level 3Disrupter Level 3
Jason
Thanks for raining in on our parade Jason...... I will probably end up getting an oem wing, but no harm in trying right
CAUTION: Over Boosting May Cause Accidental Orgasm.
1993 Mitsubishi 3000gt VR-4
1994 Mitsubishi 3000gt SL mtx..... I miss her!
Dyno: 243awhp/280awt On stock boost(~8psi) mods: K&N/Greddy type-RS (Badly Heatsoaked + Boost Leak).
Mods: K&N filter, HKS SSQV, Redline motor oil 10w40, IPS 3" DP, Custom single shot, SSR GT7's, Tein S-tech,MSD 8.5 Super conductor wires, NGK |X Iridium spark plugs.
Waiting install: Blitz DSBC, , Greddy fatt, Apexi Safc2, Apexi S-itc, Maximal mounts, FMIC, RobBecks 13t's, Maf-t, z06 maf, evo9 560cc, Denso supra pump.
Contemplating: Small ones
Disrupter is offline   Reply With Quote
Old 07-19-2008, 07:05 AM   #33 (permalink)
akamk is an unknown quantity at this point
make it out of wood guys lol jkjk
akamk is offline   Reply With Quote
Old 07-31-2008, 06:41 PM   #34 (permalink)
Supporting Vendor
Extreme Dimensions is an unknown quantity at this point
LOL, that is funny. Wood would definitely not be the best material to make the wing out of! Seriously though, a carbon fiber cross beam wouldn't be a bad idea along with aluminum posts perhaps. What do you guys think?
If you need to get a hold of me when I am not on the forum you can reach me by:
-e-mail: thomasr@extremedimensions.com
-aim, yahoo, or msn messenger: AskExtremeD
-phone: 888-611-2376 ext 17
-Check us out on myspace: www.myspace.com/extremedimensions
Extreme Dimensions is offline   Reply With Quote
Old 07-31-2008, 07:28 PM   #35 (permalink)
constant work in progress
alexw3000gt's Avatar
Drives: '96 base, '91 VR4
alexw3000gt level 6alexw3000gt level 6alexw3000gt level 6alexw3000gt level 6alexw3000gt level 6alexw3000gt level 6
Some kind of inner support would be a must from what I've heard. Aluminum ribbing or something. I wouldn't know what design would give the most support, for the lowest price, and be easiest to incorporate into manufacturing. If I had the spare time, I'd make some designs on CAD or something. But I don't.
If I happen to come across a broken one I would like to play around with different bracing.
'91 VR4 fo' sale! http://www.3si.org/forum/showthread.php?t=392983
Good lord! I'm getting a reading of over 400 Mega-Fonzies!
alexw3000gt is offline   Reply With Quote
Old 08-02-2008, 08:24 PM   #36 (permalink)
Drives: 1999 VR4
Robs99VR4 is an unknown quantity at this point
Yeah, with a semi transparent stain and about a 100 coats of marine spar varnish. Sweet.lol
Seriously though, I haven't had any problems with my wing and I hadn't heard of any cracking problems from any 99VR4 owners. I have put some miles on mine and at pretty high speeds.
I read somewhere that the engineers designed that wing to be functional not just for visual effects.lol
I bet the engineers would have #$%$# their pants at high speed if that wing was flapping all over the place. In fact, seeing how the center is aluminum, it probably did happen with the first wing they put on it.
Last edited by Robs99VR4 : 08-02-2008 at 08:31 PM. Reason: forgot to add something
Robs99VR4 is offline   Reply With Quote
Old 08-02-2008, 08:34 PM   #37 (permalink)
210vr-2beast's Avatar
210vr-2beast Negative 3
Umm what is y'alls take on this wing from aerokits.com? It is full cf and also would a 99 wing fit on a base model in place of the stock wing?
210vr-2beast is offline   Reply With Quote
