Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Labonte MotorSports
Old 05-02-2008, 01:39 PM   #1 (permalink)
Paid Member
jba3's Avatar
Drives: mitsu's stock up ^_^
Trader Rating: (15)
jba3 Level 5jba3 Level 5jba3 Level 5jba3 Level 5jba3 Level 5jba3 Level 5
Default Setup for an e16g car?
I am planning on running an evo3 16g setup, with a stock bottom end at the stock 3.0L and either 8.0:1 or 8.5:1 forged pistons and rods. I am hoping to make 600whp on pump and/or pump and injection.
Can you recommend a setup (including nozzle size) to use for this configuration? Would it be the same as the other setup that was recommended to 3KGT2NV?
I have alky injection for my evo but haven't installed it yet, so I am a little familiar with the concept but I definitely don't know enough to piece together a system.
Thanks!
Originally Posted by ImNotSpeeding View Post
when you turn your car on, does it return the favor?
Hi, my name is James, and I'm a VR4 addict
If my posts have been helpful or informative, or even entertaining, rep is appreciated.
jba3 is offline
Old 05-02-2008, 07:41 PM   #2 (permalink)
Drives: 1994 VR-4
Trader Rating: (16)
dlabonte Level 1dlabonte Level 1
Default Re: Setup for an e16g car?
A base system for that power level would consist of
ISG-10 w/ VC-25D controller (if using stock MAF)
M12 nozzle
and recommend IFS-10 Fail Safe unit.
you may or may not want to use our Boost bypass solenoid (BBK-10) with the fail safe unit depending on what you have for boost control.
If you have more questions just ask, glad to help.
dlabonte is offline
Old 07-23-2008, 04:43 PM   #3 (permalink)
Wrks on car btwn classes
Drives: 1993 3KGT VR4
Trader Rating: (7)
jay04 Level 3jay04 Level 3jay04 Level 3jay04 Level 3
wat if you have a manual boost controller for boost control ?
jay04 is offline
Old 07-24-2008, 11:13 AM   #4 (permalink)
Drives: 1994 VR-4
Trader Rating: (16)
With MBC you can use the BBK-10 which will bypass boost around your MBC and send it to wastegate if IFS-10 ever detects a fault.
Best regards,
Dan
dlabonte is offline
