Go Back   3000GT/Stealth International Message Center > Supporting Vendors > Labonte MotorSports
Old 05-12-2008, 08:40 AM   #1 (permalink)
Fred 62's Avatar
Fred 62 is an unknown quantity at this point
Default my labonte system !
i received the labonte by ther way of a guy on Evolutionm.net
the complete kit with igs10, vcs3G, ifs-10 & boost bypass kit, and dual nozzle kit.
pics of the kit install.
i used 2 0.7 nozzle, equivalent to M5 nozzle, with check valve in 4mm
i used some aquamist parts as liquid level sensor, tank adapter and solenoid valve 2 way.
the solenoid valve is used to prevent any leak when the labonte system is off.
the VCS3G install in the car
the covers for the 10Liters jerricans, home made
Donnes le meilleur de toi même en toutes circonstances
DN precat & manifold, downpipe, JIC exhaust, TD04 HL15G, IK27, Magnecor 8.5, EGR & canister & solenoids removed,
Samco hoses, FIPK air filter, HKS twin power DLI, RPS max clutch & flywheel, DN intake pipes & Paceproducts intercoolers
680cc injectors, emanage ultimate, GM boost solenoid, PLX-R500, MMCD1.8 + palm, 7 gauges + pillar pods, blitz turbo timer
blitz DSBC boost controller, tein type S springs, strut bars 3SX & sways bars, DBA brake discs, Goodridge Stainless-Steel Brake Lines
carbon pads, shift boot and knob, kevlar timing belt, oil line kit 3SX, supra pump, boost a pump, fuel fiter and fuel rail adapter & modifications
92.5 wiseco pistons, clevitte bearings, ferrea 1mm oversized valves, head porting, fidanza can gears -3/+1, etc...
Fred 62 is offline   Reply With Quote
Old 05-12-2008, 08:51 AM   #2 (permalink)
Fred 62's Avatar
Default Re: my labonte system !
i used a small switch to control a 40A relay for powering on the labonte system. a green led give me the state of the contact of the relay .
on the pillar pod,
a red light is flashing if i have the low fluid level in the tank.
a yellow led is lighting when the pump is activated.
i installed the boost bypass valve just before the wastegates.
i made the check of the install and the pump is runing great without any noize.
( all the documents are easy to understand. this is a really good point )
the touch screen is really good and all parameters are easy to set.
now i will need to play with methanol !
fred
Old 05-12-2008, 08:53 AM   #3 (permalink)
work for 3s mod
Fury's Avatar
Drives: on all four
Trader Rating: (19)
Fury is an unknown quantity at this point
Very cool and clean install Fred
92 Red Pearl VR4 - 6G74 Built 3.53L GT4202 in the making - 92 Stealth ES - Peepo Racing -
Fury is offline   Reply With Quote
Old 05-13-2008, 08:13 AM   #4 (permalink)
ely
ely's Avatar
Drives: 95 Stealth R/T TT
ely is an unknown quantity at this point
I like how you did it, you have hide all the proofs that you have it.
'99 Front Bumper, Philips HID's, Infinity Kappa 693.7I & Kappa Perfect 6.1 & Kappa Perfect 12VQ, Dietz Power Cap 1F, Pioneer HU, 2x Kenwood Amplifiers
Apexi AVC-R, K&N AirFilter, Supra pump hotwired, Tein Flex Coilover Suspension Kit, .... more to come
....and yes BORLA, is a romanian.
ely is offline   Reply With Quote
Old 05-13-2008, 08:33 AM   #5 (permalink)
HVY HITR
Erick's Avatar
Drives: 94.99 STEALTH TT
Erick Level 1Erick Level 1
very clean install.
are those polyeurethane lines? I had to use nylon or the meth mix would eat through those lines
Erick is offline   Reply With Quote
Old 05-13-2008, 09:18 AM   #6 (permalink)
dlabonte's Avatar
Drives: 1994 VR-4
Trader Rating: (16)
dlabonte Level 1dlabonte Level 1
Fred, great work on your install, thanks for sharing.
I think those white lines are from an Aquamist kit. The ones we ship are black nylon.
Best regards,
Dan
Labonte MotorSports
Performance Water-Meth Injection Systems since 2002
1-815-315-4823
www.labontemotorsports.com
sales@labontemotorsports.com
dlabonte is offline   Reply With Quote
Old 05-21-2008, 01:00 PM   #7 (permalink)
Fred 62's Avatar
thoses lines comes from a plant who make plastic bootles. it is used to connect some parts of a pneumatic circuit.
it is a real 4*6mm industrial white line, and not a intake diameter like 4.2 ou 4.6mm for example. it is good for this setup.
i always have the black nylon, dan.
fred
