#1 (permalink) |
i received the labonte by ther way of a guy on Evolutionm.net
the complete kit with igs10, vcs3G, ifs-10 & boost bypass kit, and dual nozzle kit. ![]() ![]() pics of the kit install. i used 2 0.7 nozzle, equivalent to M5 nozzle, with check valve in 4mm i used some aquamist parts as liquid level sensor, tank adapter and solenoid valve 2 way. the solenoid valve is used to prevent any leak when the labonte system is off. ![]() ![]() ![]() ![]() ![]() the VCS3G install in the car ![]() the covers for the 10Liters jerricans, home made ![]() ![]()
Donnes le meilleur de toi même en toutes circonstances
![]() DN precat & manifold, downpipe, JIC exhaust, TD04 HL15G, IK27, Magnecor 8.5, EGR & canister & solenoids removed, Samco hoses, FIPK air filter, HKS twin power DLI, RPS max clutch & flywheel, DN intake pipes & Paceproducts intercoolers 680cc injectors, emanage ultimate, GM boost solenoid, PLX-R500, MMCD1.8 + palm, 7 gauges + pillar pods, blitz turbo timer blitz DSBC boost controller, tein type S springs, strut bars 3SX & sways bars, DBA brake discs, Goodridge Stainless-Steel Brake Lines carbon pads, shift boot and knob, kevlar timing belt, oil line kit 3SX, supra pump, boost a pump, fuel fiter and fuel rail adapter & modifications 92.5 wiseco pistons, clevitte bearings, ferrea 1mm oversized valves, head porting, fidanza can gears -3/+1, etc... |
#2 (permalink) |
i used a small switch to control a 40A relay for powering on the labonte system. a green led give me the state of the contact of the relay .
![]() on the pillar pod, a red light is flashing if i have the low fluid level in the tank. a yellow led is lighting when the pump is activated. ![]() i installed the boost bypass valve just before the wastegates. i made the check of the install and the pump is runing great without any noize. ( all the documents are easy to understand. this is a really good point ) the touch screen is really good and all parameters are easy to set. now i will need to play with methanol ! @+ fred |
#4 (permalink) |
I like how you did it, you have hide all the proofs that you have it.
'99 Front Bumper, Philips HID's, Infinity Kappa 693.7I & Kappa Perfect 6.1 & Kappa Perfect 12VQ, Dietz Power Cap 1F, Pioneer HU, 2x Kenwood Amplifiers
Apexi AVC-R, K&N AirFilter, Supra pump hotwired, Tein Flex Coilover Suspension Kit, .... more to come ....and yes BORLA, is a romanian. ![]() |
#6 (permalink) |
Fred, great work on your install, thanks for sharing.
I think those white lines are from an Aquamist kit. The ones we ship are black nylon. Best regards, Dan
Labonte MotorSports
Performance Water-Meth Injection Systems since 2002 1-815-315-4823 www.labontemotorsports.com sales@labontemotorsports.com |
#7 (permalink) | |
it is a real 4*6mm industrial white line, and not a intake diameter like 4.2 ou 4.6mm for example. it is good for this setup. i always have the black nylon, dan. @+ fred |
