My small aussie build - 3000GT/Stealth International Message Center
Go Back   3000GT/Stealth International Message Center > Regional Discussions > International(NON USA) > Australia
Old 04-20-2011, 06:38 PM   #1 (permalink)
mrgtott's Avatar
Drives: women wild (gto)
mrgtott is an unknown quantity at this point
Feedback Score: 2 reviews
Default My small aussie build
So fellas, just thought i'd make a small write up of what I am doing so far. I am not going nuts with this thing as I cant afford to as I am still in Uni till end of this year so plan is to use the stock engine but support it to make 350+ awkw
Currently:
Unknown turbos, 450cc injectors and a walbro fuel pump, straight pipe 3' exhaust, thats pretty much it. Need to fix radiator thermos as new radiator i installed doesnt have bungs for temp sensors therefor my thermos arent coming on. Also need to do all engine mounts whilst I am doing my turbos.
Build:
Just got my IPS 19ts in the mail the other day, looks pretty swag, but I need to get a clip on the turbine wheel done if I am to push them past 370awkw, so looking to do that sometime soon, Anyone know a good place in melbourne to get this done?
I am completely lost about injectors as I need more than 550cc but less than 680 and its hard to find anything in between, so i'll prob go the the 680s.
Also been tossing and turning in my sleep between an Emanage Ultimate and ARC2, As much as I would love the simplicity of an Arc2, not knowing exactly where my fuel curve is and having timing control kind bugs me so most likely go with an EMU now.
Still trying to sort out my FPR as well, hopefullly can get ROB Beck to make up another adapter for me and stick in a AEM 303
Got the Walbro 255 already in so will need to highflow it
Now the interesting part with my downpipe is its stock, I hate the way the rear turbo enters at 90degress so am thinking about getting it custom fabbed whilst am getting the o2 bung for the wideband installed. Hopefully I can get them to fab it up so it enters at a better angle to the front turbo exhaust stream.
Wideband o2- absolute necessity if your doing any kind of build and running decent power
Still undecided on clutch, hopefully an RPS Max street full face clutch with pp should be able to hold my power, havent bought one yet.
I bought another 5spd getrag box and just waiting for it to be delivered, will probably fix that one up and put it in. My current box is crunching pretty bad.
Well thats about it at the moment, will update as I buy and install things on the way. In a bit of a buying frenzy at the moment cos my target date for the build is mid-July
Maddy
mrgtott is online now   Reply With Quote
Old 04-20-2011, 10:09 PM   #2 (permalink)
GTO-6105's Avatar
Drives: 1998 GTO MR
GTO-6105 is an unknown quantity at this point
Feedback Score: 1 reviews
Default Re: My small aussie build
sounds wicked and good luck. my target build date ie get the car running and registered. is september for the lapsprints i also bought the 15g turbos off jayr and getting some 560cc injectors (i no, u talked me into it) . aswell as the stuff i bought off you. once it all rocks up to my place its going into the shop and it can get done properly (well as properly as people can do on a GTO) i also have the 100km service stuff coming with the kevlar timing belt, thermostat and replacement valve cover hoses. and last but not least get the new DS carrier bearings installed. hope i got enuff cash at the end. make sure u keep adding photo's to this thread. photo's are good. video's are better lol
marcus
GTO-6105 is offline   Reply With Quote
Old 04-21-2011, 02:13 AM   #3 (permalink)
Crap - you got me!
GTO Assassin's Avatar
Drives: 1993 Mitsubishi GTO
GTO Assassin Level 1GTO Assassin Level 1GTO Assassin Level 1
Feedback Score: 46 reviews
You want me to close this now? lol
Scotty
GTO Assassin is offline   Reply With Quote
Old 04-21-2011, 03:27 AM   #4 (permalink)
mrgtott's Avatar
lol Scotty, still going ahead, however if someone buys these turbos I wouldnt mind going either dr750 or 16g.
Old 04-21-2011, 03:43 AM   #5 (permalink)
TUFFTR & JDMBBQ
TUFFTR's Avatar
Drives: Mitusbishi Magna
TUFFTR is an unknown quantity at this point
Feedback Score: 10 reviews
Hey mate, I had the same problem as you in regards to radiator not having the extra bung for the temp sensor. I got a $30 adaptor from super cheap, took it down to an engineering joint with my spare temp sensor where they tapped in a new thread. installed it and works a fkn treat without any modifications needed to the wiring. Give that a shot hombre!
3.5L DOHC 24v
Fuel/Brake/Clutch lines all Stainless Steel -5sp w/Exedy HD clutch - DR 272 camshafts and 99 lifters - Fidanza Adjustable Cam Gears - 70mm throttle body - Custom Mitsubishi 380 intake manifold - Complete 3000GT VR4 brake upgrade (inc twin piston rears) - Full poly front end - Whiteline rear sway bar - Koni front struts, KYB rears - EVO 6 rear spoiler - Diamante side skirts/Front bar/headlights, Sigma headlight washers/Ralliart Magna MOMO wheel/ GTO headunit - Soon - Custom Extractors and 3" catback. - Tune - Sexytime with car
Me giving it the beans :P
http://www.youtube.com/watch?v=qJ6Qnhsn1eI
TUFFTR is offline   Reply With Quote
Old 04-21-2011, 05:14 AM   #6 (permalink)
mrgtott's Avatar
lol thats exactly what I was thinking of doing, good to know its the right thing to do though, thanx dude
One question though, if your talking about the same adapter as I think you are, there is only enough space for 1 temp sensor, but our cars had two, how did you get around this?
Cheers
Old 04-21-2011, 05:37 AM   #7 (permalink)
mrgtott's Avatar
Default
My 19t's, most likely go with these, unless someone wants to buy them in which case i'll go bigger
Sent from my X10a using AutoGuide App
Not so small aussie build, forged and billet car
Old 04-21-2011, 06:14 AM   #8 (permalink)
Drives: GTO
OLS_Faust_17 is an unknown quantity at this point
Feedback Score: 0 reviews
Good stuff Maddy, can't wait till see the final figure. By the way, send me a text or something 'cause I lost all my phone numbers when I updated my iPhone. Pete, if you're reading this do the same.
1990 GTO Twin Turbo Jet Black
Induction:
HKS Air filter, CX Racing FMIC, HKS SSQV, Maddy's old IPS 19T Turbos.
Management:
Chiptorque XEDE piggyback ECU.
Fuel:
Hotwired Walbro 255l Fuel pump, 550CC Delphi injectors, AEM FPR.
Exhaust:
Modified BBP Racing downpipe, High flow catalytic converter, 3” cat-back exhaust split into dual 2 ½” exhausts with hotdogs and a pair of twin 3” dumpers.
Drivetrain:
Rebuilt 5 Speed and TC with MP bracket, 18 Spline 300M OS, Exedy HD Cushion Button clutch, Redline oils.
Suspension:
GAB HD Suspension, 3SX adjustable rear control arms.
Interior:
AM Stelung Steering Wheel, Big stereo with custom boot install, Tinted windows, 3SX pillar gauge pod, Saber Smokey lens Boost gauge, 280km/h speedo.
Exterior:
Aftermarket Front Lip, 3SX Hood Vents, 18” Lenso D1R silver staggered rims with 235/40 (front) and 265/35 (rear) tyres.
OLS_Faust_17 is offline   Reply With Quote
Old 04-21-2011, 08:39 AM   #9 (permalink)
TUFFTR & JDMBBQ
TUFFTR's Avatar
Cheers
Well the radiator only had one bung but originally had 2 temp senders. So one went in the bottom of the radiator, the other I cut the hose close to the bottom and inserted the adaptor there. I can get a picture tomorrow if you like lol
Old 04-21-2011, 08:10 PM   #10 (permalink)
mrgtott's Avatar
lol, thats my problem, my stooopid radiator has no bungs, pics would be much appreciated
Also considering the possibility of running e85, probably would need a second walbro and atleast 750cc injectors in this case. I am pretty convinced now to run an EMU so this takes care of the problem of running large injectors with an ARC2. Really dont want to go to the hassle or expense of replacing hard fuel lines and spoke to a few guys who are making 600awhp+ with stock lines so am going to give this a go first. Sticking a second walbro into my sender is going to be a PITA though, as well as figuring out how to merge the two and still connect to stock lines, like I said (Uni student on a budget with minimal time and money). Dont really have the dosh to pay $1k for a dual feed kit from 3sx, that money would rather be invested in my bottom end or even bigger turbos
If anyone has any ideas on how to setup dual walbros to stock hard line, your more than welcome to chime in
Maddy
